Old 14th March 2008, 14:37   #16
brraj's Avatar
Thanked: 354 Times
Originally Posted by Gangsta View Post
Ques1. K&N Typhoon is better or Universal Twin Conical Green Filter is better? I think Green one have more surface area and green is ahead of K&N in terms of performance. Your Suggesions please
Ques2. What about CAI on Elantra CRDi?
Gangsta - I use Green cotton stock replacement filter and is better than a K&N. In green cotton noise levels are less compared to a K&N when you are blasting the beast.
If you are going for the conical air filter then you are losing the advantage of CAI.
brraj is offline   Reply With Quote
Old 14th March 2008, 14:44   #17
Akshay1234's Avatar
Thanked: 7,239 Times
gangsta - get the green storm CAI.
Old 14th March 2008, 15:49   #18
Gangsta's Avatar
thanx for the kind reply guys.
So which one will give better performance?
Green Twin Conical Filter or GReen Storm CAI?
Gangsta is offline   Reply With Quote
Old 14th March 2008, 16:44   #19
Akshay1234's Avatar
well if the pipe is put to a place where it can get fresh cool air from outside the car it would perform better than a conical that is sucking in hot air from your engine bay.
Old 15th March 2008, 18:29   #20
Gangsta's Avatar
thanx bro. I will surely go for Green Storm. changing Headers, Manifolds and Exhaust is recommendable? Because High Rev is not there.
Old 19th March 2008, 10:48   #21
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
Here is some very interesting news for all you elantra owners. Those who want more power, can get hold of a boost controller and up the boost a bit.
I know someone who uppped the boost from 7psi (stock) to 1bar and the car felt insane. Only trouble is that the clutch didn't hold up for long. But at 10psi the car does feel like a dream. Id recommend this to anyone with a common rail diesel engines. Apparently this made a wonder of a difference to the drab Skoda Tdi.
Old 19th March 2008, 12:35   #22
Awaiting Email Confirmation
Thanked: 20 Times
this sounds interesting! where can i find one? and is it a 1 size fits all component? I have 3 CRDI engines at home all hungry for more boost!
Old 19th March 2008, 13:37   #23
Akshay1234's Avatar
wont the longevity of some engine components be reduced?
Old 19th March 2008, 18:21   #24
ram_hyundai's Avatar
Thanked: 48 Times
Definitely you would have to compromise a bit on the life of the engine depending on the extend of mods done -IMO.Elantra is wonderfull with the petes and the filters.
ram
ram_hyundai is offline   Reply With Quote
Old 19th March 2008, 18:28   #25
Psycho's Avatar
Thanked: 95 Times
I know this sounds too good to be true but how sure are you that the fuel pump can handle that much boost. I don't think Hyundai would have had the maps updated to handle double the boost.
I can agree about increasing boost upto 20% as the engineers would have factored that much in but 50% is too hard to believe. I do know of 1 person who did do this on a Safari and promptly blew his engine going up 4 PSI extra.
Did also hear of 1 elantra that went up 5PSi and had problems. The clutch was always a bit suspect for the existing torque hence any upgrades on boost will require a better clutch.
Old 19th March 2008, 20:31   #26
Gangsta's Avatar
That means we need to spend money on the performance clutches too?
Old 20th March 2008, 12:22   #27
brraj's Avatar
Thanked: 354 Times
Hi keshav,
elantra crdi stock is 7psi, if we can add just 3psi total will be 10psi.
can elantra crdi handle 3psi extra boost?
i am asking this because i don't want to go for 1bar, i want power aswell as be in the safer side.
I am also ready to install performance clutch for the power it gives.
Any other upgrades to be done to be in safer side.
one more question?
will it work with petes box which is already installed.
Old 20th March 2008, 19:09   #28
Thanked: 20 Times
the elantra's engine is supposed to be hyundai's best attempt at CRDI(prev gen) is'nt that so?
anyway, double the boost on stock internals will be suicide!
just a teensy weensy bit wont hurt will it?
what happens if the fuel pump cant deliver? i mean, other than it going bust or car not performing as expected due to poor fuelling, what else can go wrong with regards to the fuel pump?can the lack of fuel cause trouble elsewhere in the engine(running too lean)
what about the turbo? will it be able to take 3-5psi more?
installing a new turbo kind of defeats the purpose of using a boost controller doesnt it?
wont a standalone ECU help with new fuelling maps? is that kind of service available? how much would it cost?
ofcourse the clutch will have to be upgraded.DUH!
but think how delicious this elantra could be!
@mclaren1885
how much does this boost controller cost?
can you adjust the boost levels via a switch/dial from within the cabin?
Old 20th March 2008, 19:51   #29
brraj's Avatar
Thanked: 354 Times
Originally Posted by rippergeo View Post
@mclaren1885
He told me that for boost controller and fitting charges its 22k and to fit it takes around 4hours. The fun part is if you need power switch on the boost controller or else switch off to make it a normal car. He also recommended that not to go more than 10psi to be in safer side and it works with petes
Old 20th March 2008, 21:21   #30
Psycho's Avatar
Thanked: 95 Times
interesting to see till where one can go just to go quicker. Looks like your mind is made up but i would tread carefully above 9 psi even more with petes box as i am not sure till when it will hold.
Elantra Petrol vs Elantra CRDi palani81 Sedans 1 24th October 2006 13:59
Elantra GT vs Elantra Crdi(Was skoda vs elantra) azifali Sedans 39 17th August 2006 12:56
elantra crdi gtd vs elantra crdi (leather pack) super_700a Sedans 3 10th August 2006 07:38
Suggest me, Elantra CRDi or Elantra GLS hsmraj Sedans 16 11th April 2006 02:28
Elantra CRDi v/s Used Elantra CRDi v/s New Ford Fiesta 1.4 TDCi lamborghini Sedans 36 30th January 2006 00:03
