Old 20th March 2008, 10:15   #16
mithun's Avatar
Thanked: 59 Times
Originally Posted by sandeep joshi View Post
Hi
What is a battery consumption causes due to installation of autocop or any other car security system ? Since car security system is ON 24x7 , I heard that battery's life reduced due to this system , if any expert can throw some light on it then it will be useful.
Is battery life reduced drastically due to installation of autocop or any other car security system ?
Sandeep
The battery life is not reduced due to security systems although the life will get reduced by 1% !
Old 20th March 2008, 11:42   #17
Thanked: 37 Times
Default Battery life reduced due to security systme
Hi
I work for Amaron and with my experience in batteries, there is a permissable leakage in all cars which is as per standard which is 100ma (Milli amps) and if checked with a Multimeter in Current mode it should show below the above parameter, if its beyond that there is draining of the battery...There are other symptoms apart from Security system they are:
1. Trunk light switch failure - The light inside the trunk keeps glowing without our knowledge draining the battery
2. Side repeator wire chipped due to rodents which is common in India, due to vibration the wire rubs the fender panel
3.Improper earthing.
4.Alternator wire becomes hard due to heat & resistance becomes high reducing life...
mridul is offline   Reply With Quote
RATTLING sound in car due to audio system... torque.steer In-Car Entertainment 4 9th March 2010 10:14
Query : Accessory Usages and Battery Consumption nicejits In-Car Entertainment 13 29th June 2009 10:05
Battery consumption and installing LCDs varunj Technical Stuff 12 15th April 2009 15:14
Battery Effect due to ICE Usage mobike008 In-Car Entertainment 64 2nd February 2009 07:56
BlueTooth Car Audio System + Security System venky6009 In-Car Entertainment 1 2nd November 2007 04:45
