Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 9th April 2008, 16:24   #31 (permalink)
Gangsta's Avatar
Originally Posted by directinjection View Post
You can switch over from CNG to petrol or vice versa whenever you want. In petrol mode, the original ECU works ensuring that you get the same performance you got before fitment of CNG. In CNG mode, the kit's ECU works. In either mode you get optimal performance because of dedicated and independent ECUs.
Approx what % of power loss you found your car running on petrol ecu and cng ecu?
Gangsta is offline   Reply With Quote
Old 19th April 2008, 22:22   #32 (permalink)
Default Where is wolfenstein ?
He is the CNG guru. I wonder why he has not posted here. What is CAI ?
innersky is offline   Reply With Quote
Old 19th April 2008, 23:55   #33 (permalink)
Team-BHP Moderator
Rehaan's Avatar
Originally Posted by innersky View Post
What is CAI ?
Please see this thread for that answer and more :
http://www.team-bhp.com/forum/announ...-team-bhp.html (Commonly used Abbreviations on Team-BHP)
cya
R
__________________
The memory of you will ride by our side forever.
Old 20th April 2008, 03:03   #34 (permalink)
abhik's Avatar
Thank God i found this thread i thought it was deleted or something.
Well i drive a stock IKon 1.6 ROCAM on CNG.
TAP only, no LAMBDA and it performs better than on petrol.
Did 170KMPH on CNG and i return at 4am from my office so do speeds of 100-140kmph in the morning easily.
Rev-limiter somehow got removed with the TAP so the engine revs all the way to over 7000RPM so acceleration is good and have given quite a few cars in the same segment a run for their money in standstill acceleration and top-end speeds.
If CNG setting is not tuned then a prominent lag is felt when on the run car is shifted to petrol mode, this is denoted by a drop in speed, slight rise in engine temperature as well.
Once doing 120kmph i tried the same and to my surprise no lag, i tried it so many times and for once even thought the switch might not be working but it was and there was absolutely no difference in performance. The engine is smoother on CNG as compared to petrol.
As for performance mods, try google or Wikipedia and you would find that a Turbo works best on Diesel,CNG, LPG engines than on a petrol engines.
__________________
ABHIK
<<<If everything seems under control, you're just not going fast enough>>>
abhik is offline   Reply With Quote
Old 20th April 2008, 09:09   #35 (permalink)
Gangsta's Avatar
CAI = Cold Air Intake.
That's a good top end speed on CNG. My "Advancer Device" is working like a pete's box installed in a CNG car. Just after 1.5K RPM, my car goes crazy on CNG, i really can't feel much of a difference if the car running on CNG or Petrol . Really don't know it's performance on other engines but on Hyundai 1.6L DOHC engine it works like CRAZY.
Looking for some alternatives to remove this lag bet. 800 to 1.5K RPM.
I think CAI will do the trick, because my car runs better at night when the temperature is down. So, CAI will do the trick.
I had a talk with someone in Hyundai, he told me that Lamda is not good in 1.6L accents but it is good in 1.5L accents. He was talking about some ECU for CNG.
When i had been to Deep Hyundai, Wazirpur, New Delhi. They were installing Lamda in Accent 1.6L Viva and were tuning it with a laptop. I felt the difference bet. a Lamda car and a Non Lamda car. Intial pickup was smooth unlike my Accent (non lamda) and ideal RPM was rock static as the car is on petrol. My Ideal RPM always fluctuates very very slight fluctuation. hardly 50 rpm approx fluctuation. I think i should go for Lamda or ECU. They told me that whenever they will install ECU for CNG on any Accent they will call me up to check the performance. First i will drive the car with Lamda + CNG and they will install ECU for CNG and then i will drive it. Just to feel the difference.
Anybody can throw some light on CAI or ECU for CNG on CNG Installed Cars. ?
Old 20th April 2008, 19:28   #36 (permalink)
can anyone post the contact details of a person specializing in doing these mods as i have tried to find such a guy but have so far failed. there are numerous cng/lpg fitting shops around delhi but ask them anything related to lamda or performance mods they look at you like ur talking about some aircraft parts!!
__________________
My Rides - Maruti SX4 Zxi, Chevy Spark, Hyundai Santro CNG, Hyundai Verna CRDI, Honda Accord 2.4 MT
coolmob is offline   Reply With Quote
Old 20th April 2008, 20:09   #37 (permalink)
abhik's Avatar
LAMBDA is an alternate ECU for CNG but it works in conjunction with the car's original ECU. I would not know of a standalone piggyback for CNG but a remap of the original should work wonders, but that again would turn out to be an expensive job.
@Gangsta- As u mentioned the car runs better at night, i would definately second that as i have experienced the same, so i too was thinkin of a CAI as when on CNG every fitter will also tell you to clean the air filter as frequently as possible to get maximum efficiency and performance out of the engine.
There is a definate lag in my Ikon as well till 1500 RPM but it just picks up like mad after that, the RPM just swings towards 7000 in a jiffy.
I guess the CAI should help with that too.
I am going to my fitter tomorrow to try out the lambda. I was advised that the IKon's own ECU is powerful enough to adapt to changes occuring due to CNG and adjust accordingly and fitting a Lambda might result in a conflict but what the heck lets give it a shot, no harm in trying and if it results in busting some serious petrol A** and proving wrong all who believe CNG cant perform then i am definately game for it.
__________________
ABHIK
Old 20th April 2008, 23:35   #38 (permalink)
neo_trace's Avatar
well i have LPG turbocharged baleno
works Gr8
neo_trace is offline   Reply With Quote
Old 21st April 2008, 09:57   #39 (permalink)
ashthedivx's Avatar
Can you post a pic of TAP for have a better understanding of the same.
I hope you are talking about Timing Advance Processor (TAP).
Even i am inclined towards installing CAI, talked to arush for the same. He also acclaimed that to have a better performance with CAI in a CNG fueled car.
Dealer people are piece of crap whenever we talk about CNG with them, it's still more or less a rocket science for them. Or we can they are so much rigid to share there experiences with CNG. For my car i have tried allmost all major GM dealers in delhi like Autovikas, Regent, Triumph but no where i could find a person who is capable enough of more then doing small tunings in the car. Though in this regard i found shrimankar people very much capable as they know what they are doing and troubleshooting a problem stated to them.
I suppose i have got that ECU along with Lamda installed in my car. When i say "I suppose" i mean i am not sure, as when trying to get information about the TAP online i got some pics around which looks like a gadget installed in my car too. Though weekends aren't too much free now-a-days so as i can poke into the hood.
As far as performance is concerned i am pretty happy with my car, but i want to be more happier
Mate, trust me being a hard fact, even professional modifiers aren't so much informative regarding CNG tuning and modding.
Old 21st April 2008, 21:18   #40 (permalink)
Gangsta's Avatar
Bro. wait for few days, let this thread gets mature with some reviews on the performance mods on CNG, then decide and bhpians can give clearer picture of the performance mods.
Lambda is like an oxygen sensor for CNG Cars, controlling Fuel Air Ratio.
CNG can be a threat to Performance mods for petrol cars if done in a right way. Because we can do some changes in ECU to increase more HP on CNG, and it mileage part wont hurt the pocket as well. Now i'm getting around 1.10 Rs per km if double the amount of cng can be used to increase the power (which is an extreme), max we can get 2 Rs per km which is very decent enough for an enthusiast and it wont hurt the pocket too in the mileage part. I bet it can beat the hell out of any stock petrol car in it's class or may be a modded one (only depends on the type of mods done),
here are some pics of TAP from the net, I think i have TAP installed in my Car. Today my car is there in the service station so will post the pics tommorrow.
__________________
Respect The Man's Car and the Man will respect You.
Hyundai Elantra CRDi
Hyundai Accent 1.6L GLS
Maruti Suzuki Wagon R
Maruti 800
Old 21st April 2008, 22:45   #41 (permalink)
Gangsta's Avatar
Timing advance processor is used in CNG/LPG vehicles. It sends specific signals to ECU of car and as a result the ECU itself advances the spark timing. This results in good pickup and mileage on such alternate fuels.
Oh yes!! Advancer in my car is TAP only. 100% confirmed because the device in my car also do the same.
__________________
Maruti 800
Old 22nd April 2008, 18:56   #42 (permalink)
gravity_sucks's Avatar
Can anyone tell me the cost of Timing advance processor??.. I hd already installed lamda to my car's LPG kit.. Can anyone plz give a proper light on CAI
[Cold air induction/intake].. is dat a device if yes hw would it works & hw it helps in improving the performance..!!! Even i had noticed this that at night car run better on lpg...
gravity_sucks is offline   Reply With Quote
Old 22nd April 2008, 20:43   #43 (permalink)
Gangsta's Avatar
TAP in my car costs me around 2500 RS.
that's due to the fact that we have Cold Air at night and engine is getting cold (denser) air.
About Cold Air Intake:
Cold air intake - Wikipedia, the free encyclopedia
You can get everything about it from here.
__________________
Maruti 800
Old 10th May 2008, 10:47   #44 (permalink)
How much does the CAI cost? I have a Landi Renzo kit in my Esteem with a lambda controller. Im not sure if it has TAP. How do i confirm weather it has a TAP or not? Also im planning to install a CNG kit in my Wagon R. Which is the best kit right now and if you guys know a good place to get it fitted in delhi, it would be great!
kalpik is offline   Reply With Quote
Old 11th May 2008, 11:07   #45 (permalink)
Gangsta's Avatar
For CAI contact Arush, Autopsyche in this forum. He is that man for such mods in delhi.
Tap is a device, i had posted the pics. Open your hood and search for such device. around 4 X 3 inch black device.
tomasetto cng kit is the best right now with 12 kg cyl. I had get it done from Tilak Nagar Area.
__________________
Maruti 800
Thread Tools
mods and performance mods for unicorn please give your views rider60 Motorbikes 117 6th September 2008 12:39
Performance Mods for Accent Gangsta Modifications & Accessories 26 24th June 2008 14:43
Performance mods for bullet !!! ac 427 Motorbikes 9 22nd September 2007 15:02
Performance Mods for Octavia RS S600BENZ Modifications & Accessories 21 3rd April 2006 09:10
performance mods chandan Modifications & Accessories 10 17th December 2005 14:48
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
