Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 14th May 2008, 20:05   #46 (permalink)
wolfinstein's Avatar
Sorry for the delayed entry,
To begin with a TAP processor is for 3 generation Kits which are primarily Open loop control, Under a closed loop system a TAP is made redundant.
The latest Sequential Systems come under the 5 Gen class, and have a seprate ECU Control unit which overrides the OEM car ECU.
For basic Starts- Easy modifications to extract the best performance are :
1) Cooler Air Intake
2) Platinum Plugs or Super 4 Bosch, Although a multi Prong plug will not neccessarily create a Heavy spark, it will last longer and will require less Gap adjustments.
3) Throttle-Air Filter cleaning at regular intervals of 5000 Km.
Now for the serious burners;
1) Cold Air Intake System.
2) Enlarged Throttle.
3) Powerful Ignition Coil, with High Cap Spark Wires
4) Iridium or Platinum Plugs
For the Major Mods;
1) Sequential Injection Kit with ECU Controller
Although you can have a TAP processor installed, its use becomes negated with a Seprate ECU controller.
__________________
" When was the last time, You did something for the first time "
wolfinstein is offline   Reply With Quote
Old 14th May 2008, 23:47   #47 (permalink)
Gangsta's Avatar
For the Major Mods;
Oh wow! thanx for the information bro. Can please be more descriptive with the stuffs like enlarged throttle and sequential injection kit with ecu controller and their outputs and prices.
__________________
Hyundai Elantra CRDi
Hyundai Accent 1.6L GLS
Maruti Suzuki Wagon R
Maruti 800
What's Next?... Yamaha R15 :-)
Gangsta is offline   Reply With Quote
Old 15th May 2008, 19:42   #48 (permalink)
Very Very Expensive...! lol
An enlarged throttle has to be customised, since it has to be made in order for the calculated Ratio you are looking at, plus also at the same time it should not be large enough so as to not fit in the engine space bay.
Sequential Injection systems are now becoming common, The range starts at 75,000 for a Sequential 4 injection Kit complete with ECU Controller.
However The models available in India are not AI ready in terms of Coupling along with the Car OEM ECU unit. They act as Stand alone engine management.
Early next year, you should see more 5th generation Systems coming in, with the New emmissions norms approaching.
TAP processor is for around 2000-3000 rupees depending on Make, a chinese one is cheaper provided its compatible.
Iridium Plugs are for around 650 per plug and Platinum at around 400.
A Cold Air Intake system can be created with a Air Scoop, but the added costs of a Fibre top bonnet can price to around 10,000-15,000.
A K n N filter mod with Cooler spacing extension will cost around 5000-7000 including the filter itself.
I don't know how much would an MSD ignition Coil and Heavy Wires cost.
I'm pretty much happy with my Stock 1.4 XETA- All I do is to clean the Filter/Throttle and Spark Plugs every 5000, and my performance along with FE are great.
__________________
Old 16th May 2008, 10:38   #49 (permalink)
Gangsta's Avatar
thanks for such useful information on the mods.
75,000k will hurt a lot ouch!!
Well..!! I have a TAP installed in my Accent, now what about its combination with the Lambda sensor? I just have a TAP not Lambda. Planning to install a lambda. Any idea about this combination?
__________________
Maruti 800
Old 16th May 2008, 12:18   #50 (permalink)
TAP ideally does not function with a Lamda, unless you have a ECU Controller and Wire Harness.
TAP is needed for Open loop systems only, with a closed loop a Lamda Controller does the work.
__________________
Old 16th May 2008, 16:27   #51 (permalink)
Gangsta's Avatar
Oh boy! from where you are getting such good informations? Do you have CNG shop or what? lol kidding.
Actually open and close loop thing had gone above my head. Can please be more descriptive on this part if possible.
I wanna remove sluggishness which i'm getting till 1.5K-1.6K RPM. Lambda will do the trick?
__________________
Maruti 800
Old 19th May 2008, 00:12   #52 (permalink)
A closed loop system performs much better than an Open loop control with TAP, since it modulates the Gas flow to the Throttle- by reading the Emissions of O2 in the Exhaust- High O2 means Rich Mix..poor performance, so the system automatically controlls the flow with the Stepper.
To increase the performance, I suggest you keep 3 things in Mind:
1) It will not be as fast as a Petrol in Intial Pick-ups, so you will have to get used to it.
2) Keep the Throttle and Air Filter Clean, Clean them up every 5000 KM, considering Delhi- It is advisable.
3) Check conditions of your Spark Plugs, an OEM may not be doing the Job well, so adjust the gap- also try a different plug- Say with my XETA-The OEM was champion or Bosch, At 15,000 KM I replaced them with Denso U Groove-OEM for Baleno and got better power,pick-up and efficiency.
This time around, after 1000 KM I will be moving to either Bosch Super 4 or Bosch Platinum.
Would also advise you to check the Valve clearence, if the plugs are getting sooted or excessive Black smoke is emitted.
A CNG vehicle needs care and pre-emptive maintainence to keep it Trouble Free.
And I don't run a CNG shop yaar, Just simple Intrest..!
__________________
Old 21st May 2008, 20:29   #53 (permalink)
Gangsta's Avatar
cool bro..
I'm having problem that my car getting tuned at regularly like every 2 weeks. Should i go for the lamba to control that? also, if lambda will help me in getting more intitial pickup than what i'm getting now. because TAPs kicks at 1,5K RPM. I wanna finish this sluggishness below 1.5K RPM.
Any more suggessions on it?
__________________
Maruti 800
Old 25th May 2008, 18:35   #54 (permalink)
whymeonly's Avatar
Well, I have a Cedia with 7k on odo and I wish to get a CNG kit with Sequential Injection Kit with ECU Controller and other filter shilter mods. With what system I can hope for best performance on CNG.
Any suppliers since again and again the people doing it seem more important than the kit.
What size the cylinders come in?
I am in a hurry, before the petrol touches 60.
whymeonly is offline   Reply With Quote
Old 25th May 2008, 23:47   #55 (permalink)
I suggest you speak to people at Green Gas first. Find out the reputed local installers.
I've not come across any lucknow CNG BHPian so far - our knowledge is all Delhi related. Plus CNG cedias are *quite* rare!
__________________
My dream: An india where even a CD100 runs HID to teach insensitive full-HID dudes that HIDs are a zero sum game.
Old 27th May 2008, 23:24   #56 (permalink)
whymeonly's Avatar
Respected sirs,
I have no hope in Lucknow and I would be getting it done from Delhi. I have already chosen suppliers for few filters, iridium plugs etc for performance boosting but yet can not find a CNG kit with sequential & ECU to match it all. Please help me find one fast we may be crossing 60 on petrol real soon.
Old 27th May 2008, 23:43   #57 (permalink)
Seriously, I have not yet seen a Cedia on CNG - though many Innovas run on CNG, as do even a couple of CRV.
Speak to wolfinstein. He has a lancer in the family - plus is CNG guru. He can guide you if at all there are competent cedia CNG installers.
__________________
Old 28th May 2008, 02:56   #58 (permalink)
alias's Avatar
hi people i wanted to know if we can add cng/lpg to a turbo charged car
i am actually considering this very seriously as the prices of petrol are going to go up by rs 16 (read this today on the newspaper)
are there any mods required or some thing to do this
experts please comment
alias is offline   Reply With Quote
Old 29th May 2008, 19:07   #59 (permalink)
My Home Town is Lucknow, I really wonder in Lucknow, if you really need a CNG kit-Since the Immediate Distances are small.
Remember whatever you choose, it has to be planned and your car prepared for the same.
Choosing Iridium plugs will alone not help, Infact all it will do it is give better spark but not much noticable difference- CNG will never ignite in the same propensity as a Petrol- You will have that lag.
To reduce the after effects, I suggest the following mods in the above post, they should work well for you- But trust me, Going Stock ain't that bad either.
1) Go for a Cooler Air Intake System
2) Spend your money on Sequential system from Landi Renzo.
3) Source a Better ignition coil along with Denso or NGK Iridium plugs.
4) Suggest a Free flow- To impress the folk in hazartganj or gomti nagar.
But before you forget let me advise you of the most important thing:
You may not be able to service the Sequential CNG kit in lucknow, till the time the dealerships don't start stocking the OBD and Scanner terminals. You will have to come at least once or twice in a year to get the system tuned in Delhi and ofcourse if issues happen, get it here either by Tow or disconnection of the complete kit.
If you ask me,I suggest you look for a Simpler mod along with a closed loop system.
__________________
Old 29th May 2008, 19:14   #60 (permalink)
You can..! However your FE will go haywire on CNG. Then ofcourse you will also need a ECU Remap or a Standalone CNG ECU control system so the Ratio of Gas:Air is maintained for efficient O2 readings.
Ideally, a Sequential Kit is best suited, since it is possible to regulate the flow of Gas. However the Turbo will increase the Air flow into the Mix so that is why the Ratio will have to be balanced with precision.
Else you will face: Check Engine/ Back Fire / Miss Fire and at the max-Engine Head Damage.
For better view, Suggest you first try your hand at a FFE system, this will reduce the power loss to an extent.
__________________
Thread Tools
mods and performance mods for unicorn please give your views rider60 Motorbikes 101 25th March 2008 19:04
Performance Mods In Kerala HAFI Modifications & Accessories 41 1st January 2008 18:47
Performance mods for bullet !!! ac 427 Motorbikes 9 22nd September 2007 15:02
Performance Mods for Octavia RS S600BENZ Modifications & Accessories 21 3rd April 2006 09:10
performance mods chandan Modifications & Accessories 10 17th December 2005 14:48
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
