Old 26th March 2008, 17:36   #16
Akshay1234's Avatar
Thanked: 6,670 Times
[quote=sunishsamuel;772608]
Originally Posted by Blue Thunder View Post
sunishsamuel, my suggestion would be Free Flow Exhaust with tuned 4X2X1 Headers, and performance air filters.
Anyone tried this? Well i know an elephant cannot be turbocharged but still thinking of something that can satisfy me till i sell this off. Do we get performance air filters that can fit the existing box or need to do some mods?
I am not sure if Safari comes with a ECU or something i can add to the existing stock setup. Please advise.
i dont think making 4x2x1 headers will be very easy for a safari since its turboed. try a green storm air filter.
Old 26th March 2008, 20:16   #17
Thanked: 52 Times
My TASS says that the Sumo Victa Turbo with the same engine has one.
Is there a new model I do not know off???? as far as I know the sumo victa has mechanical injection system even the new DI.... they are trying to fool people...
dinar is online now   Reply With Quote
Old 26th March 2008, 20:38   #18
Su-47's Avatar
Thanked: 91 Times
Off topic, but, howz the suction noise with the greenstorm on the innova? Is it like too loud?
Su-47 is offline   Reply With Quote
Old 27th March 2008, 06:01   #19
Ignazio's Avatar
I do not know what is TCIC, but if refers to the 2 liter turbo diesel engine, well, a lot can be done!
On my TL I just replace original paper filter with Finner filter, fit the same box but gives you much much better performance and not noise increase.
Next step is my exhaust, I'm going to get rid of catalyst, and build a much more free muffler. Then once this is done I'll start to work on turbo, but this must be done together with the injection pump. Increasing just the turbo pressure will not get too much and will also increase the operating temperature of the engine. A lot can be done to Mico (Bosch ve) pump. It is possible also on those engine equipped with lucas pump, but I do not know too much about...
Ciao ciao
cheers:
Ignazio
Ignazio is offline   Reply With Quote
Old 27th March 2008, 06:18   #20
gd1418's Avatar
Thanked: 655 Times
Might be since Sumo was a later model. The TCIC Safari that I've is sans the ECU. You may like to check with your TASS about this..
Old 27th March 2008, 06:23   #21
gd1418's Avatar
Thanked: 655 Times
If you remove the catalyst, then what about emission control? As it is, the 2.0L Safari finds it pretty difficult to pass the emission test; with the catcon removed it may have to be kept in the garage and taken out only in the dead of the night..
Originally Posted by Ignazio View Post
Ciao ciao
cheers:
Ignazio
Old 27th March 2008, 06:34   #22
Ignazio's Avatar
well, is not 100% true! A lot friends from Tataclub Italia did the mod, with a proper balancing of turbo and pump, you can get almoust similar emission of my euro2 engine. Been 10 years old, the tollerance of smokes is not that bad. Some of the friends pass already MOT without trouble...
Ciao!
Old 27th March 2008, 08:09   #23
Akshay1234's Avatar
im using a stock replacement at the moment. but when i had the green storm and the pipe was connected in the normal hole it was irritatingly loud. but when it was near the grill the noise was much less. with the stock replacement the noise is barely noticeable and with no perceivable drop in performance.
Old 27th March 2008, 08:24   #24
condor's Avatar
Thanked: 4,337 Times
Ignazio : I do not know what is TCIC, but if refers to the 2 liter turbo diesel engine, well, a lot can be done!
TCIC here refers to the Turbo Charged Inter-Cooled 2.0L engine.
Ignazio : On my TL I just replace original paper filter with Finner filter, fit the same box but gives you much much better performance and not noise increase.
Can you pls post more details of this filter ?
Ignazio : A lot can be done to Mico (Bosch ve) pump. It is possible also on those engine equipped with lucas pump, but I do not know too much about...
Could you pls give us more details on this - I am intrested more in the Lucas pump.
TIA !
Old 27th March 2008, 09:32   #25
SUV
SUV's Avatar
GD - My Truck (a 05 Model) never came with a Catalytic Convertor.... This i beleive is something unique to Tata Engines equipped with a Mico-Bosch FIP...
Also the throttle response and NVH is better with a Mico FIP... The Lucas One's make a hell lot of Noise ....
SUV is offline   Reply With Quote
Old 27th March 2008, 10:23   #26
Thanked: 23 Times
Then once this is done I'll start to work on turbo, but this must be done together with the injection pump. Increasing just the turbo pressure will not get too much and will also increase the operating temperature of the engine. ...
how about keeping the Turbo thingy aside, its too complicated.
how about the Intercooler, I heard some of the earlier fighter planes had a water reserve, with which cold water can be sprinkled on the IC, thereby increasing the amount air intake. I think this kind of facility is/was there in a scooby / skyline. Btw, was this method used for running the engine with colder air or increasing the power??
Is it feasible? Also to cool the water, route it through the Aircon ducts. Easier said than done. Anybody tried this.
"just throwing some stones in the dark."
kkr2k2 is offline   Reply With Quote
Old 27th March 2008, 10:33   #27
condor's Avatar
SUV : GD - My Truck (a 05 Model) never came with a Catalytic Convertor.... This i beleive is something unique to Tata Engines equipped with a Mico-Bosch FIP...
@SUV, do re-check. My truck is a 2005 baby, TCIC, and has a Cat-Con. FIP is Lucas, though. I dont think a MICO FIP will make the Cat-Con redundant.
Old 27th March 2008, 12:40   #28
SUV
SUV's Avatar
Condor - I am positive ..... Even Tata Service confirmed the same...
Old 27th March 2008, 15:05   #29
Thanked: 761 Times
Ciao ciao
cheers:
Ignazio
Can you throw more light on this."?
sunishsamuel is offline   Reply With Quote
Old 27th March 2008, 15:14   #30
condor's Avatar
SUV : Condor - I am positive ..... Even Tata Service confirmed the same...
@SUV, how can it be ? The FIP comes into play before combustion. The Cat-Con is acting on the exhaust gases. How can a FIP subsitute the Cat-Con action ? THere's no logic to it.
TATA Safari TCIC Maintenance Cost ibm_jennifer Long-Term Ownership Reviews 90 16th October 2011 14:10
Safari TCIC 2.0 Engine swap with 3.0L DICOR Engine gd1418 Modifications & Accessories 34 6th July 2009 15:12
Safari TCIC 4x4 problem gd1418 Technical Stuff 5 11th July 2008 18:01
TATA safari TCIC or the DICOR maheepgupta SUVs, MUVs & 4x4s 24 12th September 2007 11:29
Safari TCIC LX or Safari DICOR LX arindam SUVs, MUVs & 4x4s 19 10th January 2007 17:42
