Old 25th March 2008, 14:57   #1
Thanked: 791 Times
Default Safari TCIC Performance mods
I did search the forum but could not find much details so starting a new thread.
1) What all modifications can be done to Safari TCIC to improve its throttle response and power delivery?
2) Changing engine is another option but the mods are too costly and involves gearbox change as well. (I read related threads on this)
3) From what i heard from mechanics including TASC, the turbocharger starts working only after a particular RPM and speed. Say above 60kmph. IS this correct and if so can this be modified so turbo works even at low RPM's so that there is initial pickup ?
Please suggest.
Thanks,
Sunish
sunishsamuel is offline   Reply With Quote
Old 25th March 2008, 18:20   #2
Thanked: 24 Times
Originally Posted by sunishsamuel View Post
you are right, you wont find any.
All I can suggest you to look for any tyre / wheel upgrades.
May be you can max look out for the Performance Air filter or Performance oriented exhaust pipe. But be warned, both these might make your safari a roaring beast but not much performance gains.
Oh! the ICE. The highly respected topic on team-bhp.
(but do read the 10 risks thread before posting in that dreaded section )
RPM, yes.
vehicle speed??? is the guy nuts???
kkr2k2 is offline   Reply With Quote
Old 25th March 2008, 18:50   #3
gd1418's Avatar
Thanked: 656 Times
The turbo in TCIC kicks in at 2100 RPM. You can add a Green Cotton or K&N filters to enhance the performance.
I don't think turbo can be modified to work on low RPM.
Please suggest.
Thanks,
Sunish
Old 25th March 2008, 19:38   #4
Su-47's Avatar
Thanked: 94 Times
Why not look the VGT way . Have you thought about it for your TCIC?
Su-47 is offline   Reply With Quote
Old 25th March 2008, 21:18   #5
Jaggu's Avatar
Thanked: 8,685 Times
get a piggy back ecu most reliable and vfm mod with minimal mod pain.
Old 26th March 2008, 10:14   #6
Su-47's Avatar
Thanked: 94 Times
Jaggu, What exactly is a piggyback ecu?
Old 26th March 2008, 10:46   #7
Blue Thunder's Avatar
Thanked: 335 Times
Post
sunishsamuel, my suggestion would be Free Flow Exhaust with tuned 4X2X1 Headers, and performance air filters.
Originally Posted by Jaggu View Post
get a piggy back ecu ...
Does the TCIC model have an ECU ? I thought only the CRDe models needed one.
Blue Thunder is offline   Reply With Quote
Old 26th March 2008, 10:53   #8
Thanked: 335 Times
Lightbulb Piggy-back ECU
A piggy back ecu takes signals from the existing sensors (of the already existing ECU) and modifies them to trick your ecu into reading a different value.
Old 26th March 2008, 11:09   #9
Su-47's Avatar
Thanked: 94 Times
Sounds similar to Pete's performance box.. Am I right?
Old 26th March 2008, 13:01   #10
gd1418's Avatar
Thanked: 656 Times
Unfortunately, the TCIC Safari doesn't have an ECU.. So what does it piggyback on?
Old 26th March 2008, 13:02   #11
gd1418's Avatar
Thanked: 656 Times
Somehow am not comfortable with retrofitting...
Old 26th March 2008, 13:18   #12
dinu2506's Avatar
Thanked: 349 Times
Not sure whether any mods to the fuel pump and injectors help? This used to be one area where the old mechanics used to work on in diesel ambys
dinu2506 is offline   Reply With Quote
Old 26th March 2008, 14:08   #13
condor's Avatar
Thanked: 4,898 Times
gd1418 : Unfortunately, the TCIC Safari doesn't have an ECU..
My TASS says that the Sumo Victa Turbo with the same engine has one.
Old 26th March 2008, 14:12   #14
Akshay1234's Avatar
Thanked: 7,242 Times
what about something like this
Snow Performance: Home
Old 26th March 2008, 17:27   #15
Thanked: 791 Times
[quote=Blue Thunder;771887]sunishsamuel, my suggestion would be Free Flow Exhaust with tuned 4X2X1 Headers, and performance air filters.
Anyone tried this? Well i know an elephant cannot be turbocharged but still thinking of something that can satisfy me till i sell this off. Do we get performance air filters that can fit the existing box or need to do some mods?
I am not sure if Safari comes with a ECU or something i can add to the existing stock setup. Please advise.
TATA Safari TCIC Maintenance Cost ibm_jennifer Long-Term Ownership Reviews 90 16th October 2011 14:10
Safari TCIC 2.0 Engine swap with 3.0L DICOR Engine gd1418 Modifications & Accessories 34 6th July 2009 15:12
Safari TCIC 4x4 problem gd1418 Technical Stuff 5 11th July 2008 18:01
TATA safari TCIC or the DICOR maheepgupta SUVs, MUVs & 4x4s 24 12th September 2007 11:29
Safari TCIC LX or Safari DICOR LX arindam SUVs, MUVs & 4x4s 19 10th January 2007 17:42
