| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here! |
| | Thread Tools |
| | #16 (permalink) |
| BHPian Join Date: Jul 2007 Location: Dharamsala
| They are not needed on passenger cars. An off-roader or a truck, a vehicle that is constantly going at low speeds at high revs under heavy loads or up hill might need an oil cooler. Usually they look like a small radiator and are positioned right in front of the main radiator. They are small enough so that they do not interfere much with the cooling of the main radiator. Nothing fancy about them, one hose in, one hose out. A transmission oil cooler works the same way.
__________________ The only tyrant I accept in this world is the still voice within. -Gandhi |
| | #17 (permalink) |
| Newbie Join Date: Mar 2008 Location: Jodhpur, Rajasthan
| See.. I am going to fix the headlights in such a way that only the headlights glass is visible (Like in the attached photo). Also if it is possible, I am going to lower down the bonnot by 2-3 inches from the front which means the overall look would be very similar to Wranger. |
| | #18 (permalink) |
| I prefer to go for redial tyres so they can absorbe the shocks to some extend. Can you please advice me some good redials for all terrain. I prefer to have a bit broader tyres (perhaps 215 75 R-16, 235 75 R-16 or even 265 75 R-16). |
| | #19 (permalink) |
| BHPian | dessertking-congrats on getting a mm540 and good to know you doing it up, i do have a mm540 too,4wd, which i bought brand new in 1994,its done 2 lakh plus km,i have modded it[little bit].[pls check my garage].its one hell of a vehicle which can take any terrain with ease even fully loaded.
__________________ The "drive" must go on!!! |
| | #20 (permalink) | |
| BHPian Join Date: Mar 2006 Location: goa
| Quote:
Plus I would love to see how the system is connected by M&M. | |
| | #21 (permalink) |
| Hi desigNation.. I have checked your garage, the roll over cage attract me the most. I want to know that which front bucket seats you have. I mean from which car?? Also pls advice which redial tyre can be fixed on the same rim size (right now it has 16 6.00 nylon).
__________________ Respect the road, join crazy offroads... |
| | #22 (permalink) |
| I have come to know that the new Scorpio and Safari Decor both has a tyre size of 235 70 R16 but their rim is a little bit broader compared to the MM540/550. Can somebody please advice if I have fit the same tyre on the original rim/wheel of my MM540. I have planned to change the rim to the broader one but the problem is that the holes on rim/wheel are of not the same size. Still is it possible to fit the broader rim/wheel. How much should it cost and is it really nacessory to change the rim/wheel.
| | #23 (permalink) |
| The wheels on MM540/550 [if the are the steel disc once] are too small [thin ] to handle the tire you mentioned, you will have to buy wheels for those tires , either alloy or the the steel disc once available for Armada [but they are 15" wheels]. If you want to put 16' only than you will have to design a spacer [ steel plate] to match the PCD of the wheels to the hub. If you want broad radials you will have to change the wheels, or tire deform on the thin wheels. |
| | #24 (permalink) | |
| Quote:
Thank you
__________________ Respect the road, join crazy offroads... | |
| | #25 (permalink) | |
| BHPian Join Date: Nov 2007 Location: Cochin
| Quote:
| | #27 (permalink) | |
| Quote:
| | #28 (permalink) | |
| Quote:
| | #29 (permalink) |
| BHPian | dessertking-the bucket seats i'm using is of the new ambassador,its a perfect fit[regarding the seat height too].i'm using a 15 inch wheel, with 255/70/15 goodyear wrangler tyres.theres a 540 in my town with 275/16 so i dont think tyre size would be an issue,make sure u have power steering.
| | #30 (permalink) |
| Hi, while searching on web I have come accross a modified MM540/550 (having MH no. on it) in which the air inlet it mounted on the top front (close to the windshield). See the photo attached and the video of the same can be seen at YouTube - motocamp's Channel. I think it is very useful and I want to opt it. Since I am not very much sound technically, can you please help me in fitting it. The same kind of air inlet is fitted on the Trex Gorkha also.
| Thread Tools | |
Similar Threads | ||||
| Dream Come True - Our Dream Machine Safari 2.2 VTT | kdeepakk | Test-Drives & Initial Ownership Reports | 53 | 28th February 2008 13:07 |
| MM540 with engine change | croonneck | Modifications & Accessories | 15 | 1st December 2007 09:30 |
| Wanted MM540 in Kerala | jango | Shifting gears | 2 | 26th July 2006 15:28 |
| Mahindra MM540 what say ?? | jango | SUVs, MUVs & 4x4s | 3 | 4th July 2006 13:58 |
| MM540 Rs 80000 | prkothan | Hatchbacks | 5 | 3rd May 2006 01:10 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429
