| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here! |
| | Thread Tools |
| | #46 (permalink) | |
| Newbie Join Date: Mar 2008 Location: Jodhpur, Rajasthan
| Quote:
How much should it cost?? Where to find one?? Is it a 4x4?? Also can you please advice how much mileage does this engine normally gives (offcourse on road)??
__________________ Papa always emphasizes on making my own path..... So I bought a 4X4 Jeep. | |
| | #48 (permalink) |
| BHPian Join Date: Mar 2006 Location: goa
| You should get one near your place, I have seen some pretty good good stuff coming from Rajshtan , to goa[4X4 goddies] including jongas, engines ,etc. Delhi will be most likely place to find it... as for the price, it depends no the condition and once bargaining power and most of all once luck. One of the mechanic got a gear box for 10 grand from mumbai. You can except a mileage of around 12 KMPL. By the way M&M launched the XD3P engine with the BA10 gear box combo on the Armada grand, and it had a 4X4 variant, so it won't be a problem sourcing stuff. |
| | #49 (permalink) |
| Senior - BHPian | The BA10 5-speed gearbox's case used to be manufactured out of aluminium and it wouldn't hold stresses and would just break . Mahindra realised the fault and then started making the BA10 with a Cast Iron case which is now very successful and very rare to come by in the chopshop market. The one used BA 'box 'jyobeb' found was picked up for 42k. A new one should cost 75k and the one here with the mahindra distributor is going for 65k.
__________________ hindu.com/mp/2008/08/25/stories/2008082522220200.htm |
| | #51 (permalink) | ||
| Senior - BHPian Join Date: May 2006 Location: Chennai..the city of cars..
| Quote:
@ nitrous: Aluminium will hold stresses too if mounted properly..MOst modern vehicles have switched to 100% aluminium..FYI Quote:
When it comes to SLUSH, NDMS rulez..Sandgrips dont have that capability!
__________________ RWD Rocks! | ||
| | #52 (permalink) |
| BHPian Join Date: Nov 2007 Location: Cochin
| Regarading BA10 gearboxes I did some reasearch and was told my the Purchase Manager at India Garage in Bangalore that most of the internals were imported from Peugot in France and it is a pain to get replacement parts. He quoted me an NGT30 5-Speed with a Mechanical Borg Warner T-Case (Similar to Mahindra major i guess) for 80K. Besides he said that Mahindra doesn't sell it new anymore since they shifted to NGT20/30 series. |
| | #53 (permalink) |
| Hey 4x4addict, thanks for the info, So what happens to the BA10 customer??? I know many people who have Armada grand. What gear box does Bolaro have?? I mean the first models, did they change the gear box on these too or it change has been resent ? |
| | #54 (permalink) | |
| Quote:
Personally, If I got a good used BA10 4x4 at a reasonable price. I would still go ahead rather than spend 80K on a new NGT30. Last edited by 4x4addict : 5th April 2008 at 10:23. | |
| | #55 (permalink) |
| BHPian | Hello desert king, Good to see you going full throttle with MM540 modifications. Few golden rules i would suggest from my little experience- 1. Do not try to make a Utility vehicle a mini suv like wrangler, thats because after all the money spent u will still not be satisfied 2. Have a clear picture of what you want to make your jeep look like. The theme should be clear and must not look confused. Theme may be wrangler look alike, basic rugged off roader, top notch stock mm540 with fat tyres etc etc 3. 5 speed gearbox is primarily for on road use. Decide how much u want to be on-road and how much u want to cruise. Slow speed driving, winding roads, stop go traffic, hard core off road useage 4-speed is sufficient. If you are facinated with NVH, shift quality etc, etc then go in and get your 5-speed gear box even by paying premium for it 4. Since you are fitting a power steering for your vehicle fo and get your self broader rims and tryes. Since you stay near dessert you must opt for sand grip or say any good make A/t tyres. Fat tyres will provide u good flotation on sand 5. Get yourself a good winch if budget permits. Plonk in an A/c as this is your every day car. But i doubt if engine will have enough power to pull strongly with 4.27 ratio with A/c on. 6. Get your self booster brakes to provide good stopping power and control both on road and off it. 7. As i always say resist your temptation on fancy stuff. First make your jeep road worthy. Good attempt and your experince will help me modifying my MM540 i suppose.
__________________ Go anywhere do anything! |
| | #56 (permalink) | |
| Quote:
Thanks a ton for the tip. I am picking up the 5-speed and the XD3 engine. The engine looks in pretty good shape and the seller told me that it came out of a Dec 2006 Bolero. Of-course we can't verify this, but it looked in pretty good shape. BTW, he also had some good Scropio engines including the CRDe and the non CRDe Turbo, but I am not sure if the mm 540 chasis, brakes etc can handle the power from the Scorpio engine so I thought I will stick with the XD3. The gearbox was not a BA10, but an NGT20. Mahindra stopped selling BA10s a few years back. But the NGT20 has many improvements over the BA10 including the cast iron case and some enhancements to the syncro cones. Plus it is locally manufactured and since it is the standard on the Major and Invader 4x4 it should be easier to souce parts if needed. The NGT20 transmission and Borg Warner mechanical transfer case comes as an assembled unit so I am not sure if the older T18 transfer case can be mated to the NGT20. In additional to the Engine and transmission, I am also changing the clutch to hydraulic from the mechanical one and the installing a power disc brake kit. Unfortunately I won't be here in chennai when the work is being done so I won't be able to post any pictures. | |
| | #58 (permalink) | |
| Senior - BHPian | We all are so glad that the super good XD3 and the 5-sp Gearbox is going to an enthusiast. Quote:
__________________ hindu.com/mp/2008/08/25/stories/2008082522220200.htm | |
| | #59 (permalink) | |
| Quote:
My existing KMT90 gear box and T-18 is going to a friend in Nagercoil who needs to replace the one on his MM540. Need to figure out what I will do with the XDP engine. The engine chap offered me only 10,000 for the engine so I thought I will just hold on to it rather than sell it for 10,000 Rupees. Last edited by 4x4addict : 7th April 2008 at 13:36. | |
| | #60 (permalink) | |
| Quote:
I am planning to drop of the Jeep in Ali's place on Thursday. | |
| Thread Tools | |
Similar Threads | ||||
| Dream Come True - Our Dream Machine Safari 2.2 VTT | kdeepakk | Test-Drives & Initial Ownership Reports | 55 | 4th August 2008 14:23 |
| Need help Regarding MM540/550 | sreerajunnithan | Modifications & Accessories | 26 | 31st July 2008 12:44 |
| Your Dream Car / Dream Garage | tsreekaranrao | The International Automotive Scene | 62 | 18th June 2008 21:35 |
| Mahindra MM540 what say ?? | jango | SUVs, MUVs & 4x4s | 3 | 4th July 2006 13:58 |
| MM540 Rs 80000 | prkothan | Hatchbacks | 5 | 3rd May 2006 01:10 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
