| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here! |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: May 2006 Location: bangalore
| Hi All, I have a 800,1988 model. Would it be possible to replace the 800 engine with a Alto engine. Was planning to do this as the pick up is low in 800 . Thanks in advance. Hemanth |
| | #2 (permalink) |
| BHPian Join Date: Sep 2005 Location: Chennai
| Hi Hemanth Its is possible to retrofit an Alto Engine (Maruti 800 5 speed Engine) but the cost of doing it would be high as lots of work needs to done which includes changing the wiring system , ECM etc...It would be better if you could let me know the condition of engine currently that is used...if the pick up is low it could be various reasons: Poor Engine Compression - Piston ring wear out or bore wear out which would require you to change the block or re-bore/Overhaul Engine Head might require a overhaul Carburettor clogged the list is endless...before venturing into changing your engine..check with an authorised service dealer on the condition of the engine by doing a compression test...based on the inputs if its weak..i suggest you can change the engine which is supplied by Maruti as HALF ENGINE which includes - Crank shaft/con rods, Pistons, rings & main bearings... The build would take approx 24 hrs along with overhauling the engine head & changing the other components...The cost to have this done would be around 15-17K with all expenses inclusive... This would mean you have new engine with a year warranty... Retro fitting an old engine would have to be done by a skillfull team of engineers which is expensive.... I guess this explanation would be of some help... To boost performance after doing the engine job...you can go in Free Flow exhaust & filter mods ... Good Luck Mridul |
| | #3 (permalink) |
| BHPian Join Date: Sep 2006 Location: Bangalore
| Mridul is right here hemanth and he has listed out the major components that need to checked. Considering that your car is almost 10 yrs old there could be n things that just need to be relooked into unless u have already checked all these out with a good service station. How much has ur car done till date?. Pbbly if its run quite a bit by now then you might want to check out compression components, I doubt if carbs may be the problem since you own the car for quite a long time and u would have caught that by now and this is the very first thing any service person will look at. |
| | #4 (permalink) |
| The other way i look at ur question..if you are not happy with the M800's response(considering everthing is fine with the engine, carbs etc) and want to go for a more responsive car then i guess i guess it depends on how much more responsiveness u are looking at and how much of budget u have. You could try out the basic free flows to start off with in the M800 itself . If you could just put ur exact requirements then we might be able to help you better |
| | #5 (permalink) |
| Newbie Join Date: Sep 2007 Location: Trivandrum
| I have a 1998 model carb. 800. Is it possible to retrofit the Alto 4-valve head and the EFI/ECU on the same block? The car has run only 43000 km. There seem to be a lot of crashed Altos around. I was thinking of buying the head, gearbox etc. as a full unit and fitting it into the 800. Is it possible without extensively modifying the bay? |
| Thread Tools | |
Similar Threads | ||||
| Engine Swaps for M800 | Tazzy Boy | Modifications & Accessories | 9 | 19th October 2008 17:29 |
| landing diesel engine in m800 and other mods | harry2223 | Modifications & Accessories | 18 | 16th January 2008 19:26 |
| Need a m800 engine | samybravo | Shifting gears | 0 | 12th April 2006 00:16 |
| Suggestion for engine performance & modification ..... | viper dude | Modifications & Accessories | 4 | 28th October 2005 22:48 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478
