Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 31st March 2008, 08:14   #1 (permalink)
Default Santro: Return spring for Accelerator and brake pedal?
Hi All,
I own a 4 year old Santro Xing. Having driven an Indica recently I realized the need to add a return spring to the accelerator and the brake pedals to reduce the strain on my ankle when driving long distances. Having looked at the brackets for the pedals, i couldn't think of a simple way to fit one. If somebody has done this before, i would appreciate some photographs of the mod so i can plan one accordingly.
Ajith
ajith is offline   Reply With Quote
Old 31st March 2008, 11:20   #2 (permalink)
Team-BHP Moderator
Jaggu's Avatar
are you sure it doesnt have one in the first place? I think that all cars have em, might be hidden thats all.
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 31st March 2008, 11:41   #3 (permalink)
Will post pics of what the existing setup looks like later today when i can get to the camera. There is one. It is just piddly and they haven't included room there for anything stronger.
Old 31st March 2008, 13:13   #4 (permalink)
Team-BHP Moderator
Jaggu's Avatar
That can be true, they have kept it piddly to make the clutch pedal light to actuate.
Options you can try:
add one more of the piddly springs.
source a better spring.
add another spring at the gear box end on the clutch cable.
__________________
Old 31st March 2008, 15:33   #5 (permalink)
ram_hyundai's Avatar
If you have a tighter spring it wont be comfortable for you to drive as the force required to push it would be more.So just check for the original spring and its tension and if its worn out replace it.
ram
__________________
Become MAD SOON and join the MON SOON Drive.
one more from me-
hey MAN come SOON for the MONSOON drive
ram_hyundai is offline   Reply With Quote
Old 31st March 2008, 16:17   #6 (permalink)
The spring is so weak that i am spending too much energy to hold my feet in the air. It has always been that way.
Jaggu, I am ok with the clutch. It is the accelerator and the brake pedals that i have trouble with.
Though not an option for the brakes, I did consider adding a spring at the other end for the accelerator cable. However, this would be an unnecessary strain on the control cable. Will only go that way if i can't avoid it.
Let me get those pics. I am sure that would be better than explaining.
Old 31st March 2008, 17:09   #7 (permalink)
Sankar's Avatar
Oh! So thats the problem.. hehehe
Well a super strong spring with enough strength to support the weight of your leg would be a bad idea because then you would have lower leg & knee pain trying to push the throttle.
And ideally one should not rest the leg on the throttle. Rest your heel on the floor and use the toes to dab the throttle. That way you won't feel the strain of having to hold your feet in the air.
__________________
Never argue with idiots. They'll drag you down to their level and beat you with their experience.
Sankar is online now   Reply With Quote
Old 1st April 2008, 12:14   #8 (permalink)
Here are some pics of what it is like currently
ajith_k/Santro Pedals - Photobucket - Video and Image Hosting
Old 1st April 2008, 12:18   #9 (permalink)
The promised pics.
Image hosting, free photo sharing & video sharing at Photobucket
Old 1st April 2008, 12:44   #10 (permalink)
Team-BHP Moderator
Jaggu's Avatar
did u weld and extend the acc pedal by any chance???? i would say bad idea, your pedal seem to be at too horizontal an angle for comfort, it should be more vertical so that toe end part of your foot stays on the pedal and heel rests on the floor.
As far as tightening the existing set up, i suggest you try tempering the spring (careful it can break also, so carry a spare in hand)
On second thought, try increasing the load on spring by bending the lever.
Also you can try a diff pedal design, similar to those in Fiats (1100) where the pedal rests on the floor and the top end can move the throttle lever.
__________________
Old 1st April 2008, 12:56   #11 (permalink)
I am sure the pedals of santro is not this horizontal.It maybe due to the photo angle or some one has played with it.Or did you slam it that hard buddie,lol.
ram
__________________
one more from me-
Old 1st April 2008, 13:06   #12 (permalink)
svsantosh's Avatar
ajit, before you get into body work and welding, try some sedans, eg- TATA cars are built like a truck, try some springs from those cars clutch pedals, and try to fit them in your accelarator pedals, may work, you never know. Well if you want to go more extreme, try to get a Enfield Bullet's Center Stand Srping and take your santro;s mechanic to help you out. Any of the idea;s above may not cost you more than 50-100Rs. PS - both car and bike parts are easily available in JC road, Bangalore.
__________________
Dont wear Helmets & Seatbelts to reach Heaven Faster
You hardly have any time left in this world to be a sinner
svsantosh is offline   Reply With Quote
Old 1st April 2008, 14:44   #13 (permalink)
Jaggu, they are totally stock. No modifications. The camera is nearly at floor level. The Tata car springs are straight unlike the circular springs you see here.
Old 1st April 2008, 16:39   #14 (permalink)
Team-BHP Moderator
Jaggu's Avatar
post a 3 D image
What are those weld job/mark then, did that came with the car?
__________________
Old 1st April 2008, 17:34   #15 (permalink)
yeah. not very pretty eh?
Thread Tools
Parabologic Leaf Spring Suspensions - are they good or bad? lalith_ka Technical Stuff 34 3rd March 2008 20:51
Vibration on accelerator pedal while using the horn kaushik_s Technical Stuff 2 8th September 2007 13:59
Paint for disc brake pads & rear brake drums VC12 Modifications & Accessories 6 20th August 2007 16:45
Need Help: Brake pedal pulsating!!! stevie Technical Stuff 4 27th October 2006 20:41
audi Q7 spring 2006 midsize SUV nitroxx The International Automotive Scene 0 16th March 2005 16:12
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
