Old 15th January 2009, 15:59   #16
Rehaan's Avatar
Thanked: 25,040 Times
Thanks me_sid.
Originally Posted by PaulBarber View Post
...is it possible to put a high power (say 130W) bulb into the fog lamps and use it for flashing?...
PaulBarber,
The wiring + relay might have to be redone since in most indian cars the "fog lamps" are more of an visual accessory than anything else. (17w bulbs etc).
Secondly, the issue you might face is finding higher powered/130w bulbs that fit the foglamp sockets. (H2 etc... unlike the main beams H4s etc)
Lastly, given that you will be using the foglamps for flashing (i see no issues with extra heat etc) -- however, it might be a little inconvenient for flashing since the switch is not on the steering stalk like the high/low beam & flash.
cya
R
VW Polo DIY: Upgrading cabin light, headlight switch & installing footwell lights Gannu_1 DIY - Do it yourself 81 28th May 2018 14:29
headlight and fog light bulb specs (Skoda Laura 1.8 TSI) hvishwanathan Technical Stuff 0 15th January 2010 11:08
intelligent ECUs. how intelligent? blacmagic Technical Stuff 13 27th November 2009 19:19
Intelligent Car Door rranjith_kum Technical Stuff 15 15th April 2009 11:53
How intelligent is the 'engine check' light? akash_m Technical Stuff 6 29th May 2008 00:13
