Closed Thread
Old 8th April 2008, 12:44   #1
DieselFan's Avatar
Thanked: 233 Times
Default Horns for my Swift D
Folks,
Need your recommendation on reliable Horn for my Swift D. My horn is not working the way it should and giving out a very feeble sound (as if it has got a sore throat). need some advise on -
1. I want a highly reliable but pleasant to hear horn which is not very expensive. Suggest the brand and the shop in Bangalore where I can buy and get it fitted.
2. On under what conditions rewiring is needed.
3. Should I replace my existing horn if they are suboptimal and utilize the same wiring/relay etc...?
4. What would be the typical fitting cost onto my Swift D.
Thanks.
DieselFan is offline
Old 8th April 2008, 12:48   #2
theMAG's Avatar
Thanked: 1,470 Times
Please search around and you'll find what you're looking for. Thread closed.
theMAG is offline
Closed Thread
The Best & Safe location for Power Horns mithun Modifications & Accessories 4 30th July 2013 10:40
Yippie - reverse horns = illegal normally_crazy Shifting gears 68 9th May 2011 13:45
Steble Nautilus Horns sounds great! willy Modifications & Accessories 20 10th August 2006 13:03
Will the Air Horns last as longer as Electric Horns ? mithun Modifications & Accessories 4 15th June 2006 11:05
Stebel Nautilus air horns John Technical Stuff 3 11th April 2006 13:37
