Old 9th April 2008, 20:53   #1
4x4addict's Avatar
Thanked: 2,668 Times
Default XD3P or DI Turbo Engine upgrade for MM540
I was all set to install the XD3P engine in my MM540 but now I just found that a DI Turbo Engine is up for sale?
What do you all think? Slow reving lower bhp/higher Torque engine (DI Turbo) or High Reving higher bhp/lower torque engine?
Has anyone driven the DI Turbo engine? How is the pick up?
DI Turbo => 68 bhp Peak Torque 18 Kgm @ 1800 rpm
XD3P => 75 bhp Peak Torque 15.5 Kgm @ 2000 rpm
4x4addict is offline   Reply With Quote
Old 9th April 2008, 23:07   #2
nitrous's Avatar
Thanked: 285 Times
Isn't this the "DI turbo" version of the NA XD3P?
Old 9th April 2008, 23:10   #3
4x4addict's Avatar
I don't think so. Its the DI Turbo version of the old international engine.
Old 9th April 2008, 23:22   #4
nitrous's Avatar
Thanked: 285 Times
Oh!
That international engine is a torquey tractor engine,i've heard.Never driven one.
Im very well familiar with the XD3P from Arka's jeep and I'd say its a lot smoother than the peugeot engine.And the one you've found is a super smooth XD3P.
Old 10th April 2008, 00:13   #5
Thanked: 53 Times
I have driven the DI and the old XD3P in a bolero, there is a difference , the XD3P is quit good compared to the DI, I did find that the low end grunt is better in the DI, but thats about it[ not much of a difference ]. But I am a big fan of XD3P engine, as I had the 2 liter engined Jeep Myself... If you like low reving engines, and you are not going to travel on highways much than DI is the way to go[ it's the rev band thats the problem]. Also the XD3p is good even off road, smoother than the DI, quiter, and more BHP when you need it.
dinar is offline   Reply With Quote
Old 9th September 2009, 00:20   #6
fireblade007's Avatar
Thanked: 56 Times
i am a bit confused about the engines that are found in the mahindra jeeps. can some body put details of jeep models with their engines specs in chronological order , in a separate thread.I have found these details here and there in several threads but not together.
fireblade007 is offline   Reply With Quote
Old 9th September 2009, 17:22   #7
Thanked: 103,537 Times
I'd recommend you to go through with the XD3P install. Its way more revvhappy (well, as much as a Mahindra can be) compared to the DI Turbo. Friendlier on the highway too and has a wider revv band. The DI Turbo only has forced induction to meet emission norms. Plus, when you are getting more power + simpler ownership with a non-turbo, why bother with the turbo alternative at all?
What is the weight of the two engines? Isn't DI Turbo the heavier as well?
Old 9th September 2009, 20:28   #8
4x4addict's Avatar
Mr. Behram has given the chronological order of the International derived Engine which is the forefather of the current DI Turbo Engine.
http://www.team-bhp.com/forum/4x4-te...eed-jeeps.html (Hi-speed and Low-speed jeeps?)
I finally went with the Turbo DI engine and am happy with my decision. I do a lot of driving in the hills and the Turbo comes in handy. The torque is good. However, in the highways it runs out of steam after about 100 kmph as the engine doesn't not rev beyond about 3300 rpm.
MM540 2wd to MM540 4wd and Restoration Rajith 4x4 Vehicles 48 1st October 2015 23:45
XD3P Engine & 5-speed Gear Box kd7202 4x4 Technical 46 7th January 2014 19:48
XD3P turbo? ringoism 4x4 Technical 19 1st August 2012 17:06
MM540-4WD wish list - what you really want in your MM540-4WD? DHABHAR.BEHRAM 4x4 Vehicles 299 7th January 2010 13:02
