Old 12th April 2008, 09:39   #16
viper's Avatar
Thanked: 9 Times
Originally Posted by dipen View Post
Get a flood damaged Accord in your city whose engine has died but exterior and other electronics are good. Then import and plonk, overhaul and mod the best engine you want in it. This will be a better option.
Conversion from auto to manual tranny, you are looking at upwards of 1.5 lak minimum.
I would suggest go for a RS or old gen civic. I am assuming you only quoted the figure for the gearbox as cost including engine + gearbox + modding will be prohibitive.(upwards of 4-5 lakhs minimum depending on how wild he wants to go)
Cheaper option buy a really old gen accord/civic/prelude/crx and plop a B20 engine and you are set. Cost of car + engine + mods max approx 6-7 lakhs including repaint, suspension, tyres and all.
Viper
Viper
viper is offline   Reply With Quote
Old 12th April 2008, 11:03   #17
v1p3r's Avatar
Thanked: 27 Times
Buy an OHC Vtec, spend a couple of lakhs, and you should be getting close to B series engines.
Old 13th April 2008, 12:56   #18
how good would a 2003 ford mondeo 2L inline 4 cylinder 16v engine be?
it puts out ~138BHP@6000rpm and 192Nm@4500rpm and has manual 5speed transmission.
i have read only good things about the engine. apparently it can be modded to 200whp NA!
and TC versions go right up to 360BHP without much effort and there is even word 500BHP mods.
the killer is the 1400kg weight. if i could plant this engine in a ikon.......sighhhhhhhh........
gautamz is offline   Reply With Quote
2002 Honda Accord 4 cyl idling issues! aditya.86 Technical Stuff 10 21st June 2011 20:32
Honda Accord VTi vs Honda Accord V6 Dinesh99 Technical Stuff 48 9th March 2010 02:08
Wanted - Honda Accord 2001 or 2002 model deepug Shifting gears 0 21st September 2007 11:45
Honda Accord Coupe Concept (Possible new Accord) amit The International Automotive Scene 3 10th January 2007 10:04
