Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 14th April 2008, 00:39   #1 (permalink)
Shaoni_sonu's Avatar
Unhappy increase handling of maruti 800?
I am having maruti 800 (2000) model,
I want to increase handling of my ride.
she is too much flexible even on small corners also.
What should I do ?
Shaoni_sonu is offline   Reply With Quote
Old 14th April 2008, 01:54   #2 (permalink)
DocG's Avatar
I think the best bang for your buck mod would be a Strut brace
It's a steel bar that runs from one strut tower to the other in the front of the car, within the engine bay.
It helps eliminate chassis flex during cornering...It's a very effective mod
Also upsize rims and tyres...better overall grip
__________________
______
o/_______\o
(OO=00=OO)
0=--------=0
E30 POWER
DocG is offline   Reply With Quote
Old 14th April 2008, 02:38   #3 (permalink)
Team-BHP Moderator
Rehaan's Avatar
From the way you have worded it, it sounds like a strut-brace might be a cost-effective solution to your problem as DocG has suggested.
However, what i would look at before even considering a strut brace is your tyres.
What tyres are you running now?
If you upgrade to some slightly wider rubber, as well as a much better tyre brand/model there will be a night and day difference in handling.
cya
R
__________________
The memory of you will ride by our side forever.
Old 14th April 2008, 06:24   #4 (permalink)
ananthkamath's Avatar
Best bang for the buck is better shocks. Period. Also, for the 800, fiberglass rear leaf springs if you can lay your hands on them.
__________________
Available: Healthy, well-built individual for part-time odd jobs around the yard. Will work for boost.
ananthkamath is offline   Reply With Quote
Old 14th April 2008, 06:50   #5 (permalink)
jkdas's Avatar
Upsize to 155s. It will sure improve handlng to some extend.
__________________
"She may not look like much, but she's got it where it counts, kid."
Old 14th April 2008, 08:18   #6 (permalink)
harry2223's Avatar
upgrade your tyres and stiffer the suspension and feel the difference
__________________
harry
harry2223 is offline   Reply With Quote
Old 14th April 2008, 08:39   #7 (permalink)
Sankar's Avatar
1) Better tyres - 165s would be just perfect.
2) Strut brace.
3) Maruti Zen (not the Estilo) suspension lower arms. They're sturdier. It's bolt on.
4) Install Zen's gas dampers at the rear.
__________________
"Auto racing, bull fighting, and mountain climbing are the only real sports... all others are games."
Ernest Hemingway
Old 14th April 2008, 10:03   #8 (permalink)
Super-Admin
How many kms has your 800 run? It may be time for a suspension overhaul too. That, and better tyres, should do the trick.
__________________
Self-imposed limits are the only type that exist. Break them....then, make it a habit. Exceed.
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 14th April 2008, 10:27   #9 (permalink)
@DocG-thank you for your kind suggestion. please tell me how much it will cost me?
@Rehaan sir-I have already bought 165s . So I think Strut brace will be best option.
@GTO Sir, my M800 has done 60k Kms. What is overhauling.Shall I go for that now.
Old 14th April 2008, 10:45   #10 (permalink)
Team-BHP Moderator
Rehaan's Avatar
Shaoni_son,
What tyres have you bought?? As i mentioned earlier, it is the quality of the tyres that will make the biggest difference.
(See this thread : http://www.team-bhp.com/forum/modify...-your-car.html (ARTICLE: Choosing The Right Set Of Tyres for your Car))
Have you fitted them yet ? Do you notice the difference?
As most people have mentioned, the next best thing you can do it replace/overhaul(=get it re-worked) your existing suspension.
The strut bar is a quick-fix, halfway there solution.
If you feel that your problem is severe, go for the overhaul instead of the strutbar.
cya
R
__________________
Old 14th April 2008, 11:19   #11 (permalink)
humyum's Avatar
All an 800 needs is a bit fatter tyres,Rest if the suspension/steering setup is in perfect stock conditon than the handling is soo direct and awesome that u dont need to touch any of it.
And i totally agree with rehaan,first get the stock setup checked.I m sure with the power/top end the 800 has u ll be happy with the stock setup itself.
__________________
Its not the age,Its the mileage
Old 14th April 2008, 11:39   #12 (permalink)
DocG's Avatar
Everyone has written about meatier tyres, upsizing etc...
The only suggestions that will help his problem are
1) Strut brace / Sway bar, can be made for both front and back
2) Better suspension - Shocks, Coilovers, Uprated springs...
tyre upgrades will help the car hold through corners, however their effect on chassis flex will be minimal.
The strut brace connects both sides of the car at points of maximum flex, the strut towers in front, and the suspension setup at back. This causes force to be transfered from the side of turn in to the outside. This then makes the chassis more rigid, reducing flex. It is extremely effective and not just a halfway fix...[Unless your suspension is too soft!]
New shocks, coilovers or uprated springs all work on the same principle. The stiffer the setup, the less it moves.
Shaoni hope this helps.
To everyone else, no offense, but I did this little write-up for the benefit of Shaoni.
DocG
__________________
______
o/_______\o
(OO=00=OO)
0=--------=0
E30 POWER
Old 14th April 2008, 12:17   #13 (permalink)
Thank you all of you.I have decided to Overhaul suspension And to fit Strut brace.
Does anyone know where I can get strut brace fitted in pune for M'800.
Old 25th April 2008, 15:27   #14 (permalink)
Question
I just want to know............
1.are strut braces for 800 are easily available?
2.approx. cost?
3.which brand is good for quality and look?
__________________
Saurabh is my name......
Drifting is my game........
Thread Tools
Maruti 800 STD & 800 DX..pros & cons ? shapath Technical Stuff 5 15th February 2008 12:13
Maruti 800 Gvozden Modifications & Accessories 22 15th February 2008 11:58
Maruti likely to renew Maruti 800 with a brand new car askicode The Indian Car Scene!! 32 13th February 2007 11:57
Maruti 800 jesal Shifting gears 2 4th November 2004 19:30
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
