Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 14th April 2008, 12:49   #1 (permalink)
Default INNOVA VVTi RPM meter & upgrade
Dear all ,
I got a 2005 INNOVA VVTi.It is an amazing vehicle.
But I am surpised that it does not have a RPM meter. I am so used to it.
I know that the diesel Innova has it. Can I get that fitted on to the petrol?
Also I want to get the AC changed to Dual A/C is that possible and if yes what kind of changes does that require? Do you have know any place I can get that done around Andheri , Mumbai .
Yea also want to get the upholstery shampooed and waxed.
Any help would be appreciated.
__________________
KITNA BHI KARO KUM PAD HI JAATA HAI
rash28 is offline   Reply With Quote
Old 14th April 2008, 13:08   #2 (permalink)
akshay1234's Avatar
as far as i know all innovas have had rpm meters unless yours is an e grade (the one with black bumpers). in that case youll have to get an aftermarket one or you can try and get toyota people to get the innova rpm meter fitted on. also for dual ac approach the toyota people.
akshay1234 is online now   Reply With Quote
Old 14th April 2008, 13:32   #3 (permalink)
Actually Petrol version does not have a E model. Its a G1 . which is the base for Petrol.
It has body coloured bumpers. Shoud I go to toyota for the rpm . Cause I think that will charge me alot for it.
__________________
Old 14th April 2008, 13:54   #4 (permalink)
akshay1234's Avatar
you can go for any tachometer. toyota would charge more but if you want a stock look then that is the best.
Old 15th April 2008, 10:41   #5 (permalink)
kaush666's Avatar
@rash28
if u want the stock look of the tachometer then approach toyota...but there is the cost factor as akshay1234 said...an aftermarket tachometer should be around 4-5k...as far as the dual a/c is concerned approach toyota...no idea about aftermarket dual a/c's....anyway pal..all the best..
kaush666 is offline   Reply With Quote
Old 13th May 2008, 12:43   #6 (permalink)
It seems the entire loom has to be changed to upgrade the Tachometer it would cost around 25 K at toyota. So thats out of the question.
I want to try outside . Does anyone know a place where I can get that done ?
__________________
Thread Tools
wheel & tyre upgrade for Innova BikerSG Modifications & Accessories 22 12th July 2007 13:40
RPM Meter for WagonR Lxi ravi@64bhp Modifications & Accessories 11 25th June 2007 15:58
HELP-How to connect RPM meter in SWIFT tabrez02 Modifications & Accessories 28 11th April 2007 14:25
Mods for Innova 2005(petrol, VVTi) Mr.Bangalore Modifications & Accessories 4 8th February 2007 15:32
Wanted RPM Meter ! khaadu75 Shifting gears 7 15th August 2004 11:30
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
