Old 18th April 2009, 20:13   #376
Abix's Avatar
Hey guys thanks for the suggestions. The car aesthetically is perfect and just the way i wanted it. Mechanically i have been driving it around town and so far id say im happy with 60% of it. I guess with old cars you never know when something might stop functioning. For example the power steering failed as one of the bearings had come of and the power steering liquid drained out. That got fixed within a days time.
Recently on my way back i started to notice smoke from the A/C vents after which i saw the temperature needle and it was all the way to red. I stopped the car and opened the bonnet to find that the pipe leading from the radiator was leaking steam. The car was then towed away to a service station and they found large amounts of rust deposits and absolutely no coolant. The problem has been sorted and couple of other problems with the air flow meter have also been detected which eventually would have given me a headache. Altogether a bit disappointed with the mechanical work done on the car, as i have had to bring the car to the workshop every other day and is a bit nerve wrecking when you don't know what might happen next. Expecting to get the car back on Monday, will update soon.
Abix is offline   Reply With Quote
Old 19th April 2009, 10:53   #377
autopsyche's Avatar
Thanked: 15 Times
Just spoke to Abix, seems like the car suffered a coolant leak. The radiator has already been flushed out once, more rust only means that it has a lot of muck left inside. The AFM which came on the car was already repaired and had been all taped up, thats what causes the unstable idling, had tried to adjust it as much as possibe but i guess replacement is the way to go. Abix how many kms had u logged on since you took delivery of the car, because overheating problems do tend to crop up randomly, if it was a workmanship fault it should have overheated on the first day itself? Would also suggest a double check on the radiator fan wiring and relay, a switched off fan would cause the same.
autopsyche is offline   Reply With Quote
Old 19th April 2009, 14:11   #378
Ricky_63's Avatar
Thanked: 394 Times
Which means that the radiator was obviously not cleaned properly, if at all. I thought that was an area one would address for sure while re-building an engine, right ?
Old 19th April 2009, 15:04   #379
autopsyche's Avatar
Thanked: 15 Times
The engine only serviced, i wonder why the assumption of a rebuild. The radiator can always have some angry muck stuck inside which after cleaning refuses to come out. In such a case the only option is to change it. You can run a coolant flush in a radiator ten times but it wont change the situation much.
Old 19th April 2009, 15:26   #380
Thanked: 37 Times
lol.... the last time i looked into an E36 engine bay i saw a clutch fan and as far as i remember it does come from the factory with a clutch fan and not a fan with wiring and relays. slipped out of your mind maybe. thought i'd tell you before you order an electric fan with a wiring relay to sort it out.
Am out of here. all the best with both your projects.
speedsport is offline   Reply With Quote
Old 19th April 2009, 17:27   #381
autopsyche's Avatar
Thanked: 15 Times
Yes my bad, it definitely slipped my mind on the fan. Thanks for the pointer.
Old 19th April 2009, 19:39   #382
Ricky_63's Avatar
Thanked: 394 Times
The dillema of the alloys never ends....
M3 Sedan Bumper, Skirts & Fender Grills, Projector Headlights, Smoked Tail Lamps, Custom Stitched Black Leatherite Interior, Full Body Refurbish and Paintjob, Engine Refurbish, All New Suspension Parts & Steering Overhaul, New Brake Rotors & Pads, New Windshield & Moldings.
Am i forgetting something?
To quote from your own post : ENGINE REFURBISH, ALL NEW SUSPENSION PARTS & STEERING OVERHAUL
The engine was re-furbished & the steering (which failed) was overhauled
Need I say more ?
Old 19th April 2009, 19:55   #383
DocG's Avatar
Ok, simply to pitch in, yes the BMW 4 cyl engines of yore used clutch fans, but it's one of the easiest things to swap in the car. Almost everyone I know who kept the 1.6/1.8 mill switched to an electric fan, just because it was simpler, and they had the convenience of adding a switch in the car. Something that might just be necessary in India with our summers.
So my question is if so much money was spent, then why was this not done?
Also something I don't understand, NOT TO BLAME OR FLAME anyone!
Why is it that in all these mods and refurbs, reliability issues keep cropping up.
I do agree that even in countries with well established tuning histories there are the occational issues that crop up. But over here in India these are extremely common
DocG is offline   Reply With Quote
Old 19th April 2009, 21:30   #384
Thanked: 40 Times
@ docg - its because in India cost cutting measure are taken a bit extra seriously and the term JUGAD comes into play in fixing cars.
accord masters is offline   Reply With Quote
Old 20th April 2009, 15:26   #385
Thanked: 41 Times
its just if you compare your older car i.e. modded cedia with this beemer, i'd vote out for cedia. that looked better. its just my opinion.
monty9991 is offline   Reply With Quote
Old 20th April 2009, 16:27   #386
lurker's Avatar
Thanked: 678 Times
it doesn't seem cost-cutting, but more like margin-hunting by the tuner which would be very common in India.
lurker is offline   Reply With Quote
Old 20th April 2009, 17:16   #387
Lighthing option on XtraLights - 888-954-4482 Shop for HID Xenon Light Kits, Headlights, Tail & Corner Lights, LED, Mirrors may be interesting!Please check it out if u haven't done so yet.Cheers!Great Build anyways!
Scarface is offline   Reply With Quote
Old 21st April 2009, 00:08   #388
Abix's Avatar
Hey guys, thanks for the inputs, haven't got the car as yet, because there were problems regarding self start which were cropping up. The mechanic told me i should have the car by tomorrow morning. Will update on how it feels.
Monty9991: Its hard to compare the two monty that one was made out to be an out and out loud tuner car, with my beemer if i had gone through a similar approach i feel id be beaten up by team bhp members and rightly so because with the BMW i wanted it to be sober which actually suits it the most. Believe you me the car still turns heads.
Scarface: Thanks, the car already has phillips HID kit on low beam and on the fog lights.
Old 21st April 2009, 13:54   #389
Abix: Checked out the low beam and the fog lamp pictures!Looks wonderful!Was suggesting an upgrade for the tails thats available at xtralights!Cheers!
Old 21st April 2009, 15:23   #390
Thanked: 41 Times
well yeah you are right. thats what i had in my mind after i posted that. you might not wanted your beemer to be loud as you already had one earlier.
BMW E36 / E46 M3s in Bombay dipen Super-Cars & Imports in India 254 20th March 2018 01:21
Project : E36 BMW M3 1998. And swapping the SMG with a manual digital4u Super-Cars & Imports in India 46 4th April 2017 17:21
What price for a BMW e46 3 series or a 99-200 e36 coupe in delhi? whatcanthisbe Luxury, Imports & Niche 14 11th August 2011 13:09
Red E36 "M3"! =) kbk_75 Super-Cars & Imports in India 49 26th November 2010 12:43
