Old 27th April 2009, 22:01   #406
Abix's Avatar
Hey guys, just got my car back today from the service center. There was an air block in the radiator which was causing the car to heat up. Drove the car today in heat and the heating up issue has gone. Will try again once more tomorrow. Been advised that if the issue crops up again, will have to change the radiator itself. The gear oils were also low causing slight jerks while shifting, which were taken care of and are now smooth.
Ricky sir, i know what u mean regarding the paintjob, as now i have started noticing swivel marks all over my car, and i make sure my car is always cleaned the proper way. Not very happy about that.
Will write more tomorrow after another drive in the heat.
Abix is offline   Reply With Quote
Old 28th April 2009, 09:14   #407
Ricky_63's Avatar
Thanked: 394 Times
# The gear oil & all other liquids should have been checked / topped up / replaced when the car was being redone at Autopsyche. That is the most basic thing any garage is expected to do.
# Is the paint blistering or getting rough ? That is what had happened to my car. If that is the case - THE ONLY - solution is to have the car scapped to bare sheet metal & then redo the whole paint process.
I do hope you don't need that !! Because then the next thing you know is your interiors will be ruined.
# My observations are posted above
Old 1st May 2009, 09:24   #408
Ricky_63's Avatar
Thanked: 394 Times
Any updates Abix ?? We already are at 43 degrees + !!!!! How is the car behaving ?
Old 1st May 2009, 09:33   #409
Abix's Avatar
Hello sir, its been 4 days since i got my car from the service center, and have been driving it at peak heat time of 12 - 2 and the temperature is stable. The air conditioning is also effective, so i am quite happy with the work done. The paint however, i got it recently waxed and polished and even the guys waxing the car said that there are swivel marks all over the car. This is one thing i really am quite irritated about as there is no other option but to go all the way to sheet metal and repaint the car.
Old 1st May 2009, 18:56   #410
Ricky_63's Avatar
Thanked: 394 Times
If the car has endured the heat on Delhi roads in the past few days - I'd say your cooling system is pretty much home. As we all know it is horribly hot nowadays !
As for the paint. Sorry to hear of substandard work once more. Hope you get a free re-do.
Old 1st May 2009, 21:16   #411
Abix's Avatar
Hey guys, slight mishap the night before, was heading over to Gurgaon after a party and near the Dhaula Kuan petrol pump, there was a hard speed breaker which i did not notice and went over it at a good 120-130kmph, the result of that is the front left rim has a slight bend. The allignment of the car isn't affected nor is the car wobbling (surprising? i know! ) What i want to know is, what can be done to straighten out the bend as much as possible, though im aware it will never be as it was originally. Any suggestions are most welcome, will post pics to show the bend. Cheers
Old 1st May 2009, 21:45   #412
PatienceWins's Avatar
Thanked: 284 Times
Allignment not affected, that shows the german build quality.
These threads would be of interest to you:
http://www.team-bhp.com/forum/tyre-a...-repaired.html (Are alloy wheels prone to damage & can't be repaired?)
http://www.team-bhp.com/forum/tyre-a...-possible.html (Repair Alloy - Is it possible?)
http://www.team-bhp.com/forum/tyre-a...-bent-rim.html (help with bent rim)
PatienceWins is online now   Reply With Quote
Old 1st May 2009, 22:48   #413
Abix's Avatar
Cheers for that patiencewins, will surely try to hit up Karol Bagh market and ask around.
Old 1st May 2009, 23:13   #414
m4ugr8's Avatar
Thanked: 123 Times
Really Sorry to hear about the incident Abix, The Construction happening all over Delhi has surely left many of these "BLIND SPOT" speed breakers and you hit them quite easily specially while driving around in the night.
Is the Tire okk?? Any Bulge or tire wall fracture, You cant try karol bagh, Though the rim wont get back to normal, but can be repaired to some extent. Interchange the rear Tire with the Front, So that at least you have two perfect tires in the front.
m4ugr8 is offline   Reply With Quote
Old 1st May 2009, 23:30   #415
quickdraw's Avatar
Thanked: 1,358 Times
What size tires and alloys are you running Abix? Welcome to my world though.
quickdraw is offline   Reply With Quote
Old 2nd May 2009, 02:01   #416
Abix's Avatar
There is actually no bubbling on the tire. Running lenso 17's on Yokohama A drives 215/45
Old 2nd May 2009, 18:38   #417
Ricky_63's Avatar
Thanked: 394 Times
Just a thought. These rims were sourced by Autopsyche ?
If yes, then all you have to do is ask Arush to get it sorted out or get you one fresh alloy if this one cannot be staightened out...Unless ofcourse you wanna run it at the rear, as it is not bubbling.
Old 2nd May 2009, 20:29   #418
manveet's Avatar
Thanked: 586 Times
Contact Ajit Singh & Sons at 011-24376803 .. AFAIK they are the ones with the proper equipment who everyone (including other alloy dealers) go to to get repairs done
Else, you can keep driving like I've been doing. No harm - been 2 years plus now.
manveet is offline   Reply With Quote
Old 2nd May 2009, 22:09   #419
abhik's Avatar
To add on to Manveet's post, here is the number for Bittoo, a Sardarji who works there and is part of the family-09811209716, the workshop is located in Bawana, which is farther than Rohini or you can leave the alloy at Jangpura market, below the Lajpat Nagar flyover and collect it the next day.
I got my OHC's alloys straightened from them and was really impressed by their work, its basically laythe machine work and a little old school machinery but straightening of alloys is done very skillfully.
abhik is offline   Reply With Quote
Old 2nd May 2009, 23:43   #420
harmon_bro's Avatar
Originally Posted by DocG View Post
Now you know what really amazes me about these "master pieces" is that there are individuals in other countries who are modding these cars in their private garages or backyards, sometimes even on trial and error basis and many of whom are extremely successful!
Why is it then that so called "professional" tuners here in India are making a mess out of it? For someone who's worked on a multitude of cars it should be in essence a piece of cake!
Caution: I realize that there are a lot of personal attacks taking place against the tuner in question. I have nothing against the gentleman, nor his business interest, nor do I intend to defame him in any way.
Hello DocG,
Iam not biased to anyone here. The tuner who is being targeted here is one of the best in the industry and its the same guy who had been producing wonderful cars for a couple of years now. Its not that all tuners or few tuners do a flaw free mod. In a country like ours where modding and performance upgrade is growing and still maturing at a fast pace we should be happy that we have some tuners in existence when compared to other countries where modding is at its peak with advanced technology. Its the same guy who had done wonderful job on Abix earlier projects.
Iam sure this tuner would have some rationale for some issues that has cropped up.
So lets support our tuners in our country and let them help us with a solution to the issues that crop up than putting them down.
No offence to anyone here, just sharing thoughts.
harmon_bro is offline   Reply With Quote
BMW E36 / E46 M3s in Bombay dipen Super-Cars & Imports in India 254 20th March 2018 01:21
Project : E36 BMW M3 1998. And swapping the SMG with a manual digital4u Super-Cars & Imports in India 46 4th April 2017 17:21
What price for a BMW e46 3 series or a 99-200 e36 coupe in delhi? whatcanthisbe Luxury, Imports & Niche 14 11th August 2011 13:09
Red E36 "M3"! =) kbk_75 Super-Cars & Imports in India 49 26th November 2010 12:43
