Old 30th April 2008, 14:10   #1
Thanked: 38 Times
Default Gypsy and Sunroof fitment
Hi
I have decided to redo my hard top gyspy on lines on suzuki jimmy a modded one whose pic i captured on my recent visit to bangkok.
Since my gypsy has a A/C and also since i often visit forest for plant and animal photography i was planning to install a sunroof to stand up and click pics
i do no wnat an electronic one and i am considering manual. I want to ask a few questions
1>Can i design some wokable solution myself where i cut a proportiantae hole in the top and sandwich a sliding metal or glass or plastic frame inside
2>Do i get a sunroof from CST (mumbaikars will know) and get it fitted
3>Do i go the expensive way to professional
4>The whole idea of mine is stupid enough and i should not waste my time considering a sunroof
I am converting my gyspy to two seater module with the cabin pack going atleast 1/6 way as opposed to normal 2seaters.
Hope u guys can input me on this
Thanks in advance
Gypsy status: Work Already started today. so quick inputs are fine
lodhra is offline   Reply With Quote
Old 30th April 2008, 15:27   #2
iraghava's Avatar
Thanked: 156 Times
The problem I see in DIY is proper sealing between the roof metal & the sunroof beading. A lot of professionally fitted sunroof's (like the RS's for instance) have had problems reported with water leaking into the cabin during rains. So unless you or your mechanic know in depth about this & have experience doing these kind of installations, I would stay away from DIY.
A professional job would be better but much more expensive.
Old 1st May 2008, 08:19   #3
Thanked: 655 Times
Go for the fabric roof. Webasto has this type too.
Folding Roofs, Webasto Sunroofs India
jyobeb is offline   Reply With Quote
Problem with Contessa Power steering - Aftermarket fitment quicksilver Technical Stuff 11 10th August 2015 11:13
Tyre upgrade/alloys fitment - NHC AshOnTheRocks Tyre & Alloy wheel Section 21 26th July 2014 19:18
Sun Roofs : As an after-fitment ShaKo Modifications & Accessories 54 2nd June 2010 11:17
Motorized Winch and Jerry can fitment for mahindra classic moodswings Modifications & Accessories 5 23rd August 2006 22:18
K&N Filter fitment!! Edmund Technical Stuff 34 25th June 2006 22:13
