Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 6th May 2008, 12:02   #1 (permalink)
rajatkumar's Avatar
Default Modding Maruti Versa, Need HELP!!!
Hi Guys,
I have a 4 yr old Maruti Versa, which is not being used much at my place. The resale value of Versa is pathetic, so am looking for some great modification idea, so that I can drive the vehicle and feel great about riding it.
The car has been run about 40K kms, and still holds the stock tyres and electricals. No chnage or modification has beed done on it.
I am looking for the following type of modification-
1. Change in Tyres, stock is 13" rims which are just toooo small. Suggest me some fitting tyres, which give it a good look.
2. Any possible changes in looks, exterior as well as interiors. I was thinking of removing few seats from rear!
3. Some great "audio" work
4. How about carputer?
The list of modifications doesnt really end here... I am nt looking to play around with bhp, but i would like to have modifications on the visual side and features ...
Also, looking for some decent motor works in delhi, preferably near Dwarka...
Guys... help me!
__________________
I can only understand Binary Clocks....
rajatkumar is offline   Reply With Quote
Old 6th May 2008, 17:15   #2 (permalink)
The Versa's ride quality is not exact the best, so you should stay away from upsizing the wheel size to 14 inch.
__________________
Change the way you think, and watch the world change around you.
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 6th May 2008, 17:34   #3 (permalink)
V-16's Avatar
Originally Posted by rajatkumar View Post
Hi Guys,
Guys... help me!
Visually I think you would only make it look more pathetic if you did anything with it. The Versa is a great and practical car but then there is not much one can do to it. I just love the responsive engine and the near short shift gear experience.
You can plonk in some good Ice, what im not the right person to advise. Maybe Navin or Bass & Trouble may be able to shed more light on that issue.
Why dont you want to add some more Bhp to it. Ideally it has the right heart to get things like this done. The Versa is the only Rear Wheel Drive car in the Maruti Car/Van range, now you know why I am smiling. The issue is the tall body and the centre of gravity. These things make the Versa a near forbidden fruit to modify. If one could do something to keep it planted and probably cure its roll happy tendencies, I would think it as the best Indian car for a turbo set up. RWD Turbo, wow. Unfortunately only a dream as not worth it.
By the way whats a Carputer??
__________________
Dear God, Why Is Life So Unfair??!!!!
V-16 is offline   Reply With Quote
Old 6th May 2008, 17:44   #4 (permalink)
SohailPistawala's Avatar
gogi bhai by carputer i think he meant computer in the car!! correct if i am wrong Rajatkumar!!
SohailPistawala is offline   Reply With Quote
Old 6th May 2008, 17:51   #5 (permalink)
Technocrat's Avatar
Originally Posted by V16
The Versa is the only Rear Wheel Drive car in the Maruti Car/Van range.
You forgot the humble Omni
__________________
The Holy Trinity: Traction, Torque and Tarmac
Old 6th May 2008, 17:54   #6 (permalink)
n_aditya's Avatar
What about the gypsy? IIRC the gypsy is rear wheel drive too.
Old 6th May 2008, 19:37   #7 (permalink)
ramie2400's Avatar
if you can please post a good profile pic of your Versa may be some of us can photochop it and you can see it visually before planning in the make-up for the exteriors,this might help you cheers
Ramie
Old 7th May 2008, 11:26   #8 (permalink)
rajatkumar's Avatar
Well,
I happen to own a swift(petrol) too... and sometimes i really feel that Versa gives me a better pickup than the Swift.
I am in still in love with Versa, and its utility factor cannot be ignored. The vehicle becomes a little scary on high speed and thats due to it "too tall boy" design... CG is much higher and u really feel scared of taking even slight turns at high speed.
How I can get the same vehicle done with CG lowered a lot and be able to make it more stable?
GTO has strictly advised "not" to upgrade the tires...
ICE is what I am planning to put on.
Btw guys, Carputer is having a computer system in your Car... more like a full fledged PC! I guess Carputer and ICE will get me lots of new features in my car!
The main query which i still have is... How do i improve the ride quality? Make the vehicle more comfortable? More attractive?
regards
Rajat
__________________
Old 7th May 2008, 14:42   #9 (permalink)
prabhuav's Avatar
Rajat,
Try a single fibre spring at the back ..
Discussions are in the attached thread
http://www.team-bhp.com/forum/modifi...af-bolero.html (single rear leaf on bolero??)
__________________
89' Premier Padmini;98 Bullet 500;02 Honda Hornet - cb919;03 Activa;04 Elantra CRDi - Peted;07 Scorpio DX
prabhuav is offline   Reply With Quote
Old 7th May 2008, 14:45   #10 (permalink)
Yes, please dont upsize on the Versa. What you could do is opt for better quality rubber of the same size.
__________________
Old 7th May 2008, 19:56   #11 (permalink)
prabhuav's Avatar
GTO - as long as the sidewall height is not reduced, what is the issue in upsizing? The versa could definitely use better grip.
__________________
Old 7th May 2008, 20:12   #12 (permalink)
manikjeet's Avatar
i think the gypsy is a 4x4 vehicle only
__________________
MANIK NANDA
manikjeet is offline   Reply With Quote
Old 7th May 2008, 23:47   #13 (permalink)
Some time back, Channel [V] had modded two Versas for their all-India-something tour.
What they had done to Exterior may not be practical (They had put in lots of graphics in every colour possible with flowing waves and other patterns, etc).
But, the interior was done up very well. I don't remember it exactly though - they had put up a big LCD screen on the roof after the driver area and a big, comfy sofa in the rear, making it a 4(or 5) seater only.
You can try something like that.
Anyways, modding a Versa sounds like a good idea, but something needs to be done about that ride quality first.
Cheers!
Jaspreet Singh
jsrakkar is offline   Reply With Quote
Thread Tools
Any Maruti Versa lovers on-board? dtgada The Indian Car Scene!! 36 28th January 2008 13:58
New Maruti Versa on the cards newcoolgadgets The Indian Car Scene!! 31 31st July 2007 20:31
Bangalore - Maruti Versa DX - LPG Gas Kit recommendation aa9031 Technical Stuff 16 27th December 2006 17:37
Maruti Versa @ 3.55 Lacs normally_crazy The Indian Car Scene!! 4 9th March 2005 23:50
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478
