Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 8th May 2008, 23:39   #16 (permalink)
vikid's Avatar
My friend in pune had put a tremendous amount of effort into this setup, not only to make it work for road use, but also for racing applications. We had were group of fiat freeks with modified cars, back in 90's
The electronics controls the dwell with such perfection, that it takes the primary resistance of the coil into account, the battery voltage and the temperature of the electronic-circuitry, in order to deliver the maximum amount of energy to each sparkplug.
The energy is exactly the same for each cylinder, always. This, and the spark-balancing feature, leads to a wonderfully smooth running engine, that will perform as never before.
These features will enable the knowledgeable tuner to easily optimise the performance of the engine!
This set up was done in long time back and since then i havent changed a thing.. cant remember the dwell angle... you should change the plugs with performance plugs for better results; i am using the NGK stainless steel plugs and the gap between the center electrode and the ground electrode is more than the stock..(cant remember how much)..
__________________
Jeep XJ 2000:
4x4fury.com
vikid is online now   Reply With Quote
Old 9th May 2008, 12:04   #17 (permalink)
chiragh_bir's Avatar
if possible get the car bit lowered
chiragh_bir is offline   Reply With Quote
Old 9th May 2008, 12:43   #18 (permalink)
dhirajs's Avatar
Thats quite a cool fiat you got there.v well maintained & neatly modded.
__________________
Sept'00 OHC-sapphire silver
dhirajs is offline   Reply With Quote
Old 10th May 2008, 00:17   #19 (permalink)
vikid's Avatar
thanks guys.. its being preserved
__________________
Jeep XJ 2000:
4x4fury.com
Thread Tools
Swift Mods : Post all queries / pics of Swift Modifications here. blindrage Modifications & Accessories 1194 13th May 2008 14:34
95 Premier Padmini S1: Problem with Ride height & front suspension kavesh55 Technical Stuff 10 2nd May 2008 10:51
Need a Premier Padmini S1 kavesh55 Shifting gears 0 27th December 2007 13:48
Used Maruti800, premier padmini , premier 118ne ? sakharamcool Hatchbacks 5 11th August 2007 21:08
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407
