Old 15th February 2005, 10:48   #1
Awaiting Email Confirmation
Default How to reduce the Idle RPM
Is any body reduced/changed the Idle RPM of diesel cars -- Indica,Indigo.
What are implications of reducing the rpm arounf 5% --apart from reduced fuel usage.
I observed with idle rpm , I can move the car on a horizontal road(without pressing the accelarator). So I think the Idle RPM is
high. Do the manufacturers, deliberately keep the Idle RPM little
high -- so that initial start would be easier.
Suryam
Suryam is offline   Reply With Quote
Old 15th February 2005, 10:59   #2
tabrez02's Avatar
Dear Suryam
I would recomend NOT to change this setting. This is however called the timming adjustment in deisel indica. Whatever they set it in the service would be the ideal for indica as it depends on the various aspects. like when you switch on the A/C (if u have DLS and above) the RPM would reduce little cause of the load. So they always keep it on the higher side. This is what i have noticed in my X V2 Indica. Even sometimes when you switch on the headlights the rpm changes.
tabrez02 is offline   Reply With Quote
Old 15th February 2005, 16:31   #3
Originally Posted by tabrez02
Dear Suryam
I do agree manufacturer will set higher limit to accomodate headlights, AC,etc(I have even observed if I swerve steering wheel, I do observe the rpm change).
My observation are:
If any of these are kept-on -- AC, headlight, steering wheel, rpm goes down(obviously because of higher load)
If any of these are kept-off -- AC, headlight, steering wheel, rpm goes up(obviously because of lower load)
The Idle rpm also goes up when temperature goes up -- as viscocity of oil is less at higher temps. When enigine is started from cold conditions, the rpm is lower(as oil visocity is higher)
So I was wondering, is there anybosy done some research on this area.
Old 18th February 2005, 10:56   #4
Rehaan's Avatar
Thanked: 25,038 Times
This is due to the powersteering pump running off the crankshaft.
R
Old 19th February 2005, 17:16   #5
Deeps's Avatar
Thanked: 68 Times
Most of the reasons why not to reduce the rpm have been mentioned. Also, if u decide to lower the idle rate 5%, its possible that the technician may screw up and reduce it further than 5%. This could be very bad for the engine. Another thing is that even the manufacturers set the idle rate at the minimum while considering the extra load that the engine will have to tolerate. So it makes absolutely no sense to reduce it even further!
Deeps is offline   Reply With Quote
Swift VXi - What is the idle rpm? clevermax Technical Stuff 8 3rd March 2008 08:58
Vibrations in Baleno at all times (Low varying Idle RPM) rohanmeets Technical Stuff 8 25th February 2008 11:36
RPM doesn't return to idle soon dj_2006 Technical Stuff 24 25th July 2007 20:20
rpm below idle rpm tortoise Technical Stuff 12 2nd April 2007 00:51
Baleno Idle Rpm shobhit15 The Indian Car Scene 13 24th October 2005 22:40
