Old 20th May 2008, 16:42   #1
Thanked: 28 Times
Lightbulb Changing ignition system for gypsy - will it help fuel economy?
Greetings to all Team-BHPians
I want to change the contact breaker to distributor less ignition system of my 1998 model 1000 cc gypsy. I read it somewhere that it has improved the mileage by approx. 3 km/lt and considerably increased the performance.
Pls guide me whether it is possible to change and if yes what benefits I will get, what is the procedure for changing it and how much it will cost
Thanks & Regards
Crazy4Power is offline   Reply With Quote
Old 21st May 2008, 11:26   #2
Thanked: 52 Times
hey, Crazy4power, welcome to Tbhp.
converting an ignition system is not a small job, also CB to CDI is possible but getting an engine to run on distributor less ignition is a very tricky and expensive job, as it requires a computer and couple of sensors to control the ignition timing/distribution.
The benefits are clean burning of fuel every time and hence efficiency will be consistent, pick up will increase,no miss fires,etc.
dinar is offline   Reply With Quote
A/C and fuel economy & How to use aircon optimally. Lukeskywalker Technical Stuff 115 15th June 2014 12:09
Alto Fuel Economy Woes ScarySkulls Technical Stuff 261 16th March 2013 13:21
Does Weather Affect Fuel Economy wolfinstein Technical Stuff 34 20th August 2009 00:57
Electronic ways of IMPROVING fuel economy Godfather Technical Stuff 8 1st October 2006 08:50
Tyre pressure vs fuel economy sbasak Technical Stuff 15 27th February 2006 23:31
