Old 22nd May 2008, 13:24   #1
mobike008's Avatar
Thanked: 8,319 Times
Default Viva CRDi- ORVM Issue
I had a small incident last week. While at a signal with a bus on my right side, on green i was slowly taking a right and the bus was also taking right and what he did was take a wider turn and this stupid manovuer resulted in emitting a crunching sound and to my shock saw the ORVM glass come off and lay shattered on the ground.
I quickly stopped and checked to fortunately find that only the glass came off and the assembly was intact.
I went to a car decor and got a glass for Rs.170 and fixed it. Within a day the glass keeps coming out and i went again and today morning again the glass came out. What do i do? Go to a different shop and get a good fixer to fix it or something wrong with the assembly mechanism inside and will it burn my pocket even more? Please suggest
Old 22nd May 2008, 13:57   #2
spadival's Avatar
Thanked: 16 Times
Try to fix it back. I think the shop wala didnt fix it properly. I had the same problem with the OVRM in my car. Fixed it now. Are you using the old plastic surround around mirror or did you buy mirror + plastic surround? if its the first case where you just bought the mirror and fixed it to the old plastic surround, then maybe the plastic surround is broken and need to be replaced.
Worst case scenario, fix it with super glue (Feviquik).
spadival is offline   Reply With Quote
Old 22nd May 2008, 14:21   #3
bhp
bhp's Avatar
Thanked: 152 Times
u can also get side mirror lock installed then hence forth the mirror would never fall again even if there is a loose fit
bhp is offline   Reply With Quote
Old 22nd May 2008, 14:26   #4
spadival's Avatar
Thanked: 16 Times
what is this contraption? Can you post a pic and let me know where is it available ?
Old 22nd May 2008, 14:31   #5
mobike008's Avatar
@Spadival, i got the glass which has some kind of rubber frame around it. The shop wala was just trying to shove it into the 4 bracket spaces in the assembly ( even the back side of mirror had 4 hook types that will fit in perfectly). but, somehow it seems to last only for a day or two and then again it comes away. I will try sticking it with a glue and see if it works.
@bhp, heard of locking facility but never for a ORVM. Can you elaborate?
Old 22nd May 2008, 14:34   #6
bhp
bhp's Avatar
Thanked: 152 Times
side mirror lock is available at any Accessory shop....the side mirror in my baleno always used to come off since its an aftermarket mirror but after getting a mirror lock it doesnt come out even in the worst case
Old 22nd May 2008, 14:41   #7
vnabhi's Avatar
Thanked: 1,311 Times
Can we have the benefit of a picture?
Old 22nd May 2008, 14:48   #8
bhp
bhp's Avatar
Thanked: 152 Times
pic will come soon ......
Old 4th June 2008, 14:09   #9
bhp
bhp's Avatar
Thanked: 152 Times
pic of the mirror lock
Old 24th June 2008, 22:13   #10
AbhiJ's Avatar
Thanked: 536 Times
I have another more low tech idea which I used on the mirror on my indica... and it worked wonders..
My mirror too kept falling out ... so I resorted to fevikwik..
I carefully applied it to the assembly side.. to make sure that I do not jam up any moving parts. And then I fit the mirror. Too be doubly sure, I kept moving the mirror for about 3-4 mins (the way we adjust it) so that it does not get jammed.
It stayed on for about 2 years till I sold the car.
AbhiJ is online now   Reply With Quote
Gettings brothers Accent VIVA CRDi but a mysterious issue and clutch plate problem... ajai_dev Technical Stuff 1 3rd December 2009 22:17
Help : Viva crdi or Verna crdi nitindangoria Sedans 15 10th March 2009 22:50
Accent CRDi or Accent Viva CRDi Looks abhibh The Indian Car Scene 4 8th November 2005 17:43
Accent CRDi or Accent Viva CRDi abhibh Sedans 16 8th November 2005 05:58
