Old 24th May 2008, 22:50   #1
gopinathann's Avatar
Thanked: 20 Times
Default Echo horns for SX4
I could not find echo horns in the thread, so starting a new one.
I installed Stebel horn 9 months back which sounded like Optra, loved it, but lost its sound recently. The electrion advised not to go for air horns as their life is not good. So this time I wanted to go for some good ones also a louder one. I was advised to go for Echo horns with melody tones. Is the echo horns similar to Roots Vibrsonic/Vibromax horns ? Otherwise I would go for the roots red grill ones, which is enough to make deaf people. I will be using OEM horn as default, and if some one doesn't give way then I will switch to the secondary, so this horn should be very loud.
Need your advice
gopinathann is offline   Reply With Quote
Old 25th May 2008, 02:31   #2
arpandiv's Avatar
Thanked: 27 Times
well i dont know what are echo horns. but if you using planning to use these horns as a secondary measure; i would suggest trying Hellla air horns.
arpandiv is offline   Reply With Quote
Old 25th May 2008, 22:46   #3
abhik's Avatar
Switch your OEM to Roots Vibramax or Red Grill, sound would be enough to make people steer aside give you way.
IMO stay clear of air-horns.
abhik is offline   Reply With Quote
Old 28th May 2008, 18:10   #4
Thanked: 20 Times
Thanks for your suggestions, I will be going for Roots red grill horns with music switch costs around 600.
Old 4th June 2008, 13:54   #5
ultimatechamp's Avatar
Thanked: 95 Times
As far as I know,Red Grill was originally from Hella stable and not roots!!Nowadays,original Hella Red Grill are not available in the market,cheap chinese imitations are ruling the roost!
ultimatechamp is offline   Reply With Quote
Old 4th June 2008, 14:53   #6
Fillmore's Avatar
Thanked: 141 Times
Checkout this thread
http://www.team-bhp.com/forum/modifi...wer-horns.html (Power Horns!)
Fillmore is offline   Reply With Quote
Yippie - reverse horns = illegal normally_crazy Shifting gears 68 9th May 2011 13:45
Steble Nautilus Horns sounds great! willy Modifications & Accessories 20 10th August 2006 13:03
Will the Air Horns last as longer as Electric Horns ? mithun Modifications & Accessories 4 15th June 2006 11:05
Stebel Nautilus air horns John Technical Stuff 3 11th April 2006 13:37
