| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here! |
| | Thread Tools |
| | #16 (permalink) | |
| Senior - BHPian Join Date: Sep 2007 Location: New Delhi
| Quote:
@ Kahaadu: This 'solution' will be very short lived. The 'intelligence' network of these drivers is not inconsiderable; they will pass on the information to each of their 'members' that this car runs out of fuel at exactly so-and-so point on the fuel gauge. What do you have in mind? Are you trying to catch them out on filling malpractices or for doing extra mileage? | |
| | #17 (permalink) | |
| Newbie Join Date: Nov 2007 Location: shenzen
| Quote:
the solution is simple the car must be fuel injection and must have obd2 connector then i can make a device were u can connect this to odb2 it will simply record all functions including millage etc this device can be password protection so can be tamper proof but 1 must not remove connector will driving other wise data is lost br narry ![]() | |
| | #18 (permalink) |
| Senior - BHPian | It is quite rare for the fuel sensor with float located in the tank of modern-day cars to go bust to know much about it and in some of these cases mostly they are replaced than repaired. I'm saying this because I posed this query of Khaadu's to the electrician at my garage (whom I think is competent), and he said it involved too much of electronics to tamper with. Probably, he was either not knowing much about or unwilling to experiment, plus you need a guinea pig to to do R&D that many may not be willing. What he otherwise told me cocked my ears. He said that the fuel sensor in cars of yore like Ambys & fiats were of simpler make like a cistern's ball cock contraption and repairable. He said that by adjusting (bending) the arm of the float the meter could be made to display wrong readings.
__________________ Royal Enfield Bullet 1962 All Black 1998 Safari 4x4 All Black 2004 Scorpio GLx |
| | #19 (permalink) |
| BHPian Join Date: Mar 2006 Location: goa
| you may have to recalibrate the fuel gauge itself, do not touch the sensor , or you will get wrong reading on the additional gauge to, you can connect two gauges in parallel [ie: the wires go to both the gauge from same point], modify the internals of the standard gauge by opening it up, theres a coil around the gauge needle which has to drop the current faster then the factory setting, any local gauge wala will know this [or car electrician will know it]. this will give you the reading you want. |
| | #20 (permalink) |
| BHPian Join Date: Jun 2005 Location: ERNAKULAM
| Get one ordinary meter and one resistance sensor for the tank. Do not connect any circuit in parallel. It can be done but requires a lot of physics/mathematics and I know zilch in mathematics to help you any further. Forget tampering with electronic fuel gauges. Fitting two sensors in the tank is going to be laborious as you will have to make a 2 or 3 inch hole to put in your new sensor which means removing your tank and emptying it of all flammable fluids ( petrol/kerosene) in your case. Calibrating it to the way you want is very easy for the fuel gauge repair guy though they are a dying breed as repairs are hard to some by these days since majority are using electronic meters these days.
__________________ Bye and wear your seat belts. |
| | #22 (permalink) |
| Senior - BHPian Join Date: May 2007 Location: Vadodara
Infractions: 0/1 (4) | A good electrician can handle this and this is possible. However its better to go with stock. You might end up in troubled judgement by yourself or someone else by these modifications. go in for the GPS. This GPS device is installed in many of pvt. travel's taxis like Indica ( travelled in one ) and busses also.
__________________ EVENTUALLY FATE DECIDES EVERYTHING. |
| Thread Tools | |
Similar Threads | ||||
| Wagon-R Fuel gauge Problem | zoom_vroom | Technical Stuff | 8 | 14th July 2008 15:04 |
| Lancer fuel gauge indicator | vid6639 | Technical Stuff | 9 | 13th December 2006 19:38 |
| Swift - Fuel gauge indication | MC Mayank | Technical Stuff | 19 | 28th October 2006 11:00 |
| Help : How to read an OHC fuel gauge? | Dippy | Technical Stuff | 17 | 13th October 2006 18:24 |
| Problem with fuel gauge in Esteem | frankmehta | Technical Stuff | 3 | 14th April 2006 18:05 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
