Old 14th September 2009, 21:12   #511
rjstyles69's Avatar
Thanked: 793 Times
Originally Posted by skyliner34 View Post
since this was a very small DIY I didn't want to create a new thread in DIY section.
Good one there skyliner, however the mesh is a tad too thin and I suggest you get a thicker mesh. You've already been there and done that, so its just that you gotto find a thicker mesh and DIY.
Take a stroll on JC Road, am sure you will find something even better.
Old 15th September 2009, 03:19   #512
bigmoose85's Avatar
I forgot to mention. That is really neat work, Skyliner. And now every one knows whome to go for a good looking mesh work.
bigmoose85 is offline   Reply With Quote
Old 15th September 2009, 08:29   #513
recshenoy's Avatar
Thanked: 104 Times
Cool
Originally Posted by bigmoose85 View Post
Skyliner34, RX 135 and Zen? Is that it? If so, it is the same me as well.
Me too, RX135 and Zen carb
They are old but i wont sell these classics
recshenoy is offline   Reply With Quote
Old 15th September 2009, 09:20   #514
prsnck's Avatar
Default without the suzuki logo
Skyliner,
Does it look tad unfinished without the suzuki logo. Or you have it mind to add on later.
I have seen the similiar ones on Baleno..in bnglr and Tbhps well...
rgrds
prsn
On a gloomy weekend I had absolutely nothing to do, so thought of making my own mesh grill for my zen.
since there is no rocket science involved in this DIY I'm simply posting the pics.
Let me know if anything more can be done to make it look even better.
Total Cost -
Mesh - 50rs (15" x 4ft)
new scissor - 60rs
Already had Bosny flat black tin.
prsnck is offline   Reply With Quote
Old 15th September 2009, 13:13   #515
evo
evo's Avatar
Thanked: 23 Times
Nice, I didnt know its that simple to do a mesh grille. But I`m scared about how long it`ll last before ruptures.
evo is offline   Reply With Quote
Old 15th September 2009, 19:14   #516
Thanked: 61 Times
Time has come to replace my 2003 Mpfi Zen's spark plug (NGK BKR6E). Thinking about NGK G-Power (BKR6EGP) or Iridium IX (BKR6EIX), does anybody used these spark plugs in stock zen? Any difference in engine performace? I'm just trying to understand whether it is worth to spend extra money in these spark plugs for normal running?
gaddiwale is offline   Reply With Quote
Old 16th September 2009, 09:50   #517
skyliner34's Avatar
Thanked: 63 Times
No, it doesn't make any difference if you put high end spark plugs on a stock car and it's not worth spending that kind of money for nothing.
There are various threads regarding this, you can go through them for more details.
skyliner34 is offline   Reply With Quote
Old 16th September 2009, 10:02   #518
skyliner34's Avatar
Thanked: 63 Times
yes buddy, that's my garage
yes rj, even I too wanted a thicker one, but as I mentioned earlier thicker ones had bigger holes and I dint like them. anyways I shall search until I get one.
anytime bigmoose.
Originally Posted by prsnck View Post
Skyliner,
rgrds
prsn
yes, I wanted to, but the ones that are available in Maruthi are a lil bigger than I wanted, so I thought of getting suzuki bike logo, lets see I will update on that.
hmmmm, lets wait and see. Anyways got the company grill in perfect condition, if this gets deformed earlier than I thought then I will go for either thicker mesh or stock.
Old 16th September 2009, 10:40   #519
bigmoose85's Avatar
I had actually searched for bigger mesh some time back and I think for the standard size(length * Breadth) that they come in, you have to pay some where around 700 0r 800 rs. That was what they told me.
Old 6th October 2009, 03:08   #520
Originally Posted by need_for_speed View Post
Recommended Tyre Size for Zen
12" - 145/80/12
13" - 155/65/13
165/60/13
145/70/13
14" - 195/45/14
hey needfor speed, could you also quote the ideal running tyre pressures for each of the profiles mentioned above.
Gypsyman is offline   Reply With Quote
Old 6th October 2009, 11:30   #521
need_for_speed's Avatar
I am not exactly sure about the tyre pressures, sorry.
need_for_speed is offline   Reply With Quote
Old 6th October 2009, 15:46   #522
Thanked: 152 Times
For the 145/80 r12 maruti says 24 .
For the 145/70R13 another zen owner can help as this tyre was also a standard by Maruti .
Trust_In_Thrust is offline   Reply With Quote
Old 7th October 2009, 01:35   #523
12" - 145/80/12
13" - 155/65/13
165/60/13
145/70/13
14" - 195/45/14
needfor speed,
thanks for the list above, could u also give the recommeneded tyre pressure/PSI details as well
Old 7th October 2009, 04:18   #524
needfor speed,
I was so engrossed in reading the posts that I dint notice that "need for speed" had already replied my post about the PSI. Does any one know the correct PSI for a 155/65 stock rims, I have filled it with nitogen when i was suggested about the same by MSM Chennai, however am feeling bumpy rides at times and really need to know the correct PSI and get the same checked on my ride.
Old 7th October 2009, 11:21   #525
motomaverick's Avatar
Thanked: 864 Times
I have recently got a second 2004 zen lx. I find that the headlights are woefully inadequate for night travel even within bangalore.
I have a karizma with 100w headlight connected via a relay and that gives more light than the zen. Hence, my immediate quest is to get a decent power in the headlight. Some options I have identified are as follows.
1. Fix Osram nightbreaker bulbs which are 60/55. (apprx: Rs 1500)
2. Fix 100/90 Philips rallye with ceramic holder and relay. (apprx: Rs 600)
3. Fix fog lamps in the front bumper at the slots provided (apprx: Rs ????)
Any suggestions will be helpful. Any ideas about a place which has a good auto light mech in bangalore.
Modifications for Gypsy King - Does the sequence of modifications matter? khan_sultan Modifications & Accessories 18 6th September 2009 14:02
Thunderbird - Modifications thread - Pics please. agbenny Motorbikes 5 15th June 2009 14:34
Zen external Modifications nicejits Modifications & Accessories 19 25th November 2007 01:41
Zen Modifications Kaizer Sozay Modifications & Accessories 5 11th September 2005 20:24
