Old 6th March 2010, 01:19   #691
recshenoy's Avatar
Thanked: 104 Times
looks cool ambat! was there a paint job done? paint looks neat!
Which are these alloys? what is the cost?
recshenoy is offline   Reply With Quote
Old 26th March 2010, 22:18   #692
b_ambat's Avatar
Thanked: 109 Times
Hi recshenoy, yes a recent paintjob was done. Alloys are league and was around 16,000.
b_ambat is offline   Reply With Quote
Old 28th March 2010, 13:01   #693
Zen2001's Avatar
Thanked: 18 Times
Question
Hi Zen owners. Does anyone have any ideas for :
1. Changing dash illumination from the boring green to amber/white? More importantly, has anyone actually done it? Removing the speedo console/speedo wire is quite difficult/tricky!
2. LED bulbs (custom made/DIY) for rear combination lamp ? Opening the plastic moulded reflectors from the assembly is also quite difficult (which will be necessary for inserting a PCB with mounted LEDS).
Any help?
Zen2001 is offline   Reply With Quote
Old 28th March 2010, 17:08   #694
Thanked: 61 Times
Hi Zen2001,
1. Changing dash illumination from green to other colour is difficult as the numbers are itself painted in green. I guess if you install white LEDs, it'll increase the illumination definitely - but no idea about the effect.
2. Why don't you buy LED back light assembly for Zen from Neolite instead?
gaddiwale is offline   Reply With Quote
Old 28th March 2010, 19:43   #695
Zen2001's Avatar
Thanked: 18 Times
Originally Posted by gaddiwale View Post
Hi Zen2001,
Someone has mentioned removing the green stickering from the inside, but I need step by step info from someone who has opened the speedo of the old zen. It's not as easy as in other cars as I'm told. Once inside the console, we can try all colour combinations to get the desired effects.
Regarding Neolite, sent them a query but no reply. Also no car accessory shops in Pune seem to stock their stuff.
Old 6th April 2010, 16:20   #696
DesertKing's Avatar
Thanked: 20 Times
I have gone through almost 43 pages of this thread and this was interesting to hear very detailed discussion on the various modifications.
Infect I have recently bought a 1998 Zen Carb and want to go for LPG kit. Pls advice if sequential injection LPG kit is good for carb engines too. If yes, please advice me the estimated cost + pros and cons.
Note I have had a M800 earlier with the normal LPG kit and I had a various issue such as starting trouble, switching over from LPG to Petrol and vice versa. Pls advice if in sequential kit, the same problem is going to occur.
DesertKing is offline   Reply With Quote
Old 6th April 2010, 22:12   #697
archat68's Avatar
Thanked: 290 Times
I'm also thinking to fix a LPG kit in my 2000 carb Zen. The car has run 85K KM - in good shape except the rattlings. My daily run is about 70KM - I'm getting 14KMPL with 50% AC. At present LPG is 40% cheaper than petrol (is it correct?). So, in a year I'll reach breakeven point and start making savings.
Is it advisable?
archat68 is offline   Reply With Quote
Old 6th April 2010, 22:33   #698
speedsatya's Avatar
Thanked: 710 Times
Is it advisable?
I used a BRC LPG kit with a 50 liter tank in my mpfi zen.I used to get around 12-13kpl on highways .Yeah ...already non existent dicky space will now make ur zen a 2 seater ..as you will have to place luggage on the rear bench
speedsatya is offline   Reply With Quote
Old 6th April 2010, 22:46   #699
Zen2001's Avatar
Thanked: 18 Times
I have installed a lovato LPG kit almost 2 years ago on my carb zen, I don't think its a sequential injection one. However, I've had absolutely no problems with starting (although its advisable to do cold starts on petrol & then switch to gas) & switching between petrol/LPG. I guess the important thing is to "adjust" the settings optimally and keep a clean air cleaner at all times.
I'm also thinking to fix a LPG kit in my 2000 carb Zen. The car has run 85K KM - in good shape except the rattlings. My daily run is about 70KM - I'm getting 14KMPL with 50% AC. At present LPG is 40% cheaper than petrol (is it correct?). So, in a year I'll reach break even point and start making savings.
Is it advisable?
Probably you will spend the first 6 months trying to re-adjust your driving to suit LPG, so the mileage figures will not be consistent. With your current mileage of 14km/l with 50% AC, it seems you drive more in traffic than on highways. Then, you will have to accept the sluggishness of the accelerator especially in conditions where you need short bursts to overtake.
Old 8th April 2010, 22:34   #700
archat68's Avatar
Thanked: 290 Times
Thanks for the input guys.
Boot space is not that important to me - I need the car to be economical. But the age of the car and carb version is holding me back at present.
Old 15th April 2010, 12:00   #701
skyliner34's Avatar
Thanked: 63 Times
guys, need some help here -
http://www.team-bhp.com/forum/techni...-door-zen.html (strange water leak via door in ZEN)
skyliner34 is offline   Reply With Quote
Old 2nd May 2010, 21:01   #702
itsmesuraj's Avatar
Default Mods for a lovely Zen
Hi all,
I finally picked up a 2005 model Zen, it's very well maintained and zen has always been my first love.
Please find the pics below.
existing Interiors with Front Arm Rest fitted - Thanks to Satya (blueraven) - PM me for the price
The top portion of the arm rest can be extended to suit your comfort. I found it a good VFM.
The momo Gear knob:
Mods Lined up:
  • Seat Covers - Pensee leathers (pending)
  • Interiors with carbon fibre trim (pending)
  • Universal Front Arm Rest - done
  • Momo gear knob - done
  • White Alloys - 155/70 R13 Apollo (pending)
  • K&N Stock filter - done
Did some photoshop on how I want my interiors to look like...plz do give me your comments....
I got hold of some Carbon Fibre 3M sticker, so the interior trim could be accomplished, however I'm worried about the red strip on the dashboard. I would love to have a shiny red strip of custom fibre stuck on the dashboard, but how practical is it?....any pointers would be appreciated.
Note from the Team-BHP Support : Please note that it is now imperative for you to upload pictures directly to the Team-BHP Server. Click here to view our simple help article on uploading pictures.
Last edited by Dippy : 6th May 2010 at 15:45. Reason: See the note at the end of your post.
itsmesuraj is offline   Reply With Quote
Old 3rd May 2010, 09:57   #703
need_for_speed's Avatar
Default 1995 Zen Modified
Hey Guys, Jus got my car modified, let me know how is it and please do suggest some concept or stickering to enhance its look.
need_for_speed is offline   Reply With Quote
Old 3rd May 2010, 10:03   #704
prince_pervez's Avatar
Thanked: 34 Times
Pretty good. Smoke the tail lamps. The mirror casings should be red. The alloys are super. w/ red lining as well. Paint the calipers and the rear drums to red.
prince_pervez is offline   Reply With Quote
Old 3rd May 2010, 11:18   #705
bugatti_86's Avatar
Thanked: 19 Times
Smile
Super Cool ride need_for_speed,well need to know the total expense you spent on your Mod as well as please highlight those Projector Setup of your Headlamps.
bugatti_86 is offline   Reply With Quote
Modifications for Gypsy King - Does the sequence of modifications matter? khan_sultan Modifications & Accessories 18 6th September 2009 14:02
Thunderbird - Modifications thread - Pics please. agbenny Motorbikes 5 15th June 2009 14:34
Zen external Modifications nicejits Modifications & Accessories 19 25th November 2007 01:41
Zen Modifications Kaizer Sozay Modifications & Accessories 5 11th September 2005 20:24
