Old 4th June 2010, 16:52   #736
NOS Power's Avatar
Thanked: 55 Times
Originally Posted by devrajman View Post
I think you guys are right. Its better to make a way around it than over it.
Im planning for ezen in abt an year, so some basic doubts:
Also, how easy is to procure a esteem engine? Where are these generally found? Like scrap, total loss cars, etc?
Is it easy to get mpfi esteem engine fit in an carb zen? From what i have heard, carb to carb and mpfi to mpfi is easy.
However, imp is what is more fun, carb or mpfi?
is zen w/o power steering OK?
You will get esteem engine's from scrap dealers and from second hand parts markets. Dont know how much they would cost you in your city, but expect it to be around 15 to 30K for an mpfi unit. Carb units will be far cheaper. I was quoted Rs. 2000 for a carb esteem engine once here in Kolkata.
The esteem engine is a direct fit regardless of whether its an mpfi unit or a carb. Just that you have to procure all the parts for the mpfi unit like ECM, wiring, sensors etc. (don't know exactly what all, other's could you please confirm). Whoever told you that carb has to be replaced by carb and likewise for mpfi is just talking in the air. No such concept.
A mech who knows what to do with an mpfi engine can complete the swap without issues.
To answer your question regarding fun, the mpfi is 20 bhp more powerful. A carb engine can be made as powerful with some mods, but you should also know that with similar kind of mods the mpfi will still be 20 bhp more. Now if throttle snatch is something you like then stick with carb, if linear power delivery is what you prefer then go for the mpfi.
NOS Power is offline   Reply With Quote
Old 4th June 2010, 17:23   #737
devrajman's Avatar
Thanked: 116 Times
Thanks for the detailed reply. It was eye opener for few things.
With engine change, its equally important to upgrade brakes and suspension, right?
Also, whats better, power steering or manual (in all respects)?
devrajman is offline   Reply With Quote
Old 4th June 2010, 17:31   #738
pulsar56's Avatar
Thanked: 319 Times
Zen as such has a light steering. Its not very tight during parking too!
Changing a non PS zen to PS is not recommended and if you still plan to go ahead, it will be a very expensive affair.
pulsar56 is offline   Reply With Quote
Old 4th June 2010, 17:59   #739
NOS Power's Avatar
Thanked: 55 Times
Devang,
Rather you could say that the stock zen anyways needs better brakes. So you know that an ezen will need a good improvement in stopping power. Check the thread on fitting Esteem Type II brake booster. Also would help if you go in for Esteem rotors, pads and calipers.
Regarding suspension, it depends on how much money you are willing to spend.
The cheapest option is to get 3 strut braces, one front lower, one front upper and one rear. Along with that get gas shocks all round and zen diesel springs for the front.
Second option is to go for a set of Koni shocks. This will greatly improve handling and stability.
Old 8th June 2010, 09:54   #740
shreyasma's Avatar
As most of you know I have a 2005 zen MPFI. I wanted to know if a Baleno gearbox will be a direct fit.
If yes, what will be the difference in performance?
shreyasma is offline   Reply With Quote
Old 8th June 2010, 11:39   #741
devrajman's Avatar
Thanked: 116 Times
Thanks everyone for your inputs. I will come back to you folks shortly once i have Vitamin-M ready!
Old 8th June 2010, 11:50   #742
Mr_Bean's Avatar
Thanked: 133 Times
Aint the short ratio on the zen more fun to drive? What are the other mods u are doing on the zen, baleno engine on the zen?
Mr_Bean is online now   Reply With Quote
Old 8th June 2010, 15:16   #743
pramodkumar's Avatar
Thanked: 858 Times
+ 1 to mr.bean, why would you do that on a zen the baleno engine will surly rock but a baleno gear box will make the zen a difficult car to drive.
Pramod
pramodkumar is online now   Reply With Quote
Old 8th June 2010, 16:42   #744
rjstyles69's Avatar
Thanked: 791 Times
Pramod
Considering the kind of raw power and torque the G16B gives you am sure the short gear ration will take a back seat in case he plans a swap. Only problem I see would be the brakes of the zen.
shreyas are you serious about an engine swap ? BTW there is a B-zen around my area and I kinda see that thingy fly past always, giving a few 1.6's a run for their money.
Old 8th June 2010, 17:34   #745
Mr_Bean's Avatar
Thanked: 133 Times
Not only the brakes, how about the chassy and drive train, will it hold up to the G16B.
Reliability & handling would be a question mark..
Old 8th June 2010, 18:19   #746
rjstyles69's Avatar
Thanked: 791 Times
I don't think chassis reinforcement is needed though, unless its throwing out some real raw power like fordrocam's city. Am sure with the GB swap even the drive train warrants a swap( need to confirm though).
Reliability shouldn't be a problem if its done by the right person. There are quite a few swaps like the ezen running in town without any reliability issues.
Old 9th June 2010, 09:56   #747
shreyasma's Avatar
Not yet decided to swap. But I want to know if the differece between the gearboxes will be positive or negative.
My question is only about a gearbox swap and will retain the zen engine.
Old 9th June 2010, 11:39   #748
need_for_speed's Avatar
You cannot fit a baleno gear box on to the zen engine. The bell housing will not seat, the two sizes will vary.
need_for_speed is offline   Reply With Quote
Old 9th June 2010, 14:44   #749
nithin_86's Avatar
Can someone tell me what the approximate cost of an MPFI esteem engine would be? And would it be necessary to go for the transmission as well?
nithin_86 is offline   Reply With Quote
Old 9th June 2010, 15:15   #750
NOS Power's Avatar
Thanked: 55 Times
Generally the engines come for anywhere between 10K to 30K depending on condition & availability.
Actually the gearbox which gets the best out off an esteem engine is infact the zen gearbox. Ask INRC guys, they prefer zen gearbox's over the esteem's. Simply because the esteem gearbox has taller ratios which takes away accelaration and low end torque.
Modifications for Gypsy King - Does the sequence of modifications matter? khan_sultan Modifications & Accessories 18 6th September 2009 14:02
Thunderbird - Modifications thread - Pics please. agbenny Motorbikes 5 15th June 2009 14:34
Zen external Modifications nicejits Modifications & Accessories 19 25th November 2007 01:41
Zen Modifications Kaizer Sozay Modifications & Accessories 5 11th September 2005 20:24
