Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 2nd June 2008, 16:42   #1 (permalink)
invincible7's Avatar
Default Which Car - CNG Installation
Ok Guys, i want to know which is a better car in terms of overall performance and realiability for installing CNG kit.
By performance i mean, the car should be not very sluggish in lower gears with AC. this is the reason i am not listing any small/hatchbacks here.
Baleno, Accent(which models), Honda City (Vtech/1.3/1.5), Lancers, Icon(1.3/1.6).
Cheers.
invincible7 is offline   Reply With Quote
Old 2nd June 2008, 18:54   #2 (permalink)
abhinav.gupta88's Avatar
I guess the CNG kit for the CITY VTEC Will be an insult to the cars performance
I think if u can get the OHC , go for the 1.5 one, install a CNG
I think that should give decent efficiency and the performance drop wont be too much
__________________
VTEC NHC AND RED SKODA OCTAVIA vRs (LAAL PARI)
WHY IS EVERYTHING ELSE SO SLOW !!!
-=]|Do The Dew|[=-
Old 2nd June 2008, 18:59   #3 (permalink)
Eddy's Avatar
http://www.team-bhp.com/forum/hatchb...6-car-cng.html (Which car for CNG?)
__________________
Car is no longer a luxury; parking space is.
Swift VDI(ABS) Sep 07 - 31K Kms
Ford Ikon Flair Sep 04 - 54K Kms
Eddy is offline   Reply With Quote
Old 2nd June 2008, 19:15   #4 (permalink)
abhinav yaar,
I have seen Honda CRVs with CNG kit
There's enough Toyota Qualis 2.0P with CNG in Delhi as well.
__________________
3300km, 1 month, 20.1 kpl (80% expressway) - Livin the VDi loca!
Old 2nd June 2008, 21:31   #5 (permalink)
abhik's Avatar
Sorry bro i would like to differ your POV here, an OHC VTEC/NON-VTEC with a TAP/ FFE/ CAI will perform better than petrol.
I have an Ikon 1.6 on CNG with TAP and it performs better than petrol. The only problem with CNG is initial lag in the lower rev range till about 1500RPM-1800RPM which can be sorted out with a custom designed header.
Unfortunately CNG is looked down upon as an inferior fuel, which is very sad to know when its benefits surpass that of gasoline in most respects. I have posted this statement before aswell that turobocharging an engine on CNG/LPG/Diesel is far better than one on gasoline in terms of performance gain.
__________________
ABHIK
<<<If everything seems under control, you're just not going fast enough>>>
abhik is offline   Reply With Quote
Old 2nd June 2008, 21:32   #6 (permalink)
abhik's Avatar
Cheers.
All the cars mentioned here will perform good on CNG but as much as i have seen and experienced with these cars, Baleno is the best on CNG in terms of performance.
__________________
ABHIK
Old 2nd June 2008, 21:45   #7 (permalink)
Mpower's Avatar
Pick a car with plenty of extra power and torque because you will lose quite a bit after conversion.
For example, a Palio 1.1/Maruti 1000/Ikon 1.3_OHV are all bad choices because they are underpowered as it is.
__________________
The difference between the men and the boys....................is the speed of their toys.
Old 2nd June 2008, 22:19   #8 (permalink)
abhik's Avatar
abhinav yaar,
I would like to add Corolla 1.8, Accord 3.0 iVTEC, Skoda vRS, BMW 316i amongst a few others with CNG. In delhi there is a CNG filling station at Kalkaji/Nehru Place and if you go there at 11.30pm-1.00am you might catch these big boys there, i have seen them there quite often.
__________________
ABHIK
Old 2nd June 2008, 23:11   #9 (permalink)
ashish22's Avatar
what abhik is saying is right. CNG has a higher octane value than gasoline and hence better performance with tuned up engine. But you need right kind of settings and installation. TAP is absolutely necessary to negate pickup issues.
But i'm really curious to know that what would be the performance of an octavia vrs on CNG, i dont think it will remain the same unless it is a sequential kit installation.
ashish22 is offline   Reply With Quote
Old 2nd June 2008, 23:31   #10 (permalink)
abhik's Avatar
The vRS was being fitted by the same guy who fitted my car so coincidently i was there when it was being done along with the BMW 316i.
A bigger kit comes for cars over 140BHP so even if you dont get seqential injection, the bigger kit wit a TAP or Lamda(depending upon closed or open loop operation) will give equivalent performance as compared to stock petrol, and anyways Skodas come with 4 point spark plugs which further help effective combustion of CNG. The owner after taking a drive after fitment said he could'nt make out any difference between performance on petrol and CNG even when he switched fuels on the go.
__________________
ABHIK
Old 2nd June 2008, 23:39   #11 (permalink)
ashish22's Avatar
accha abhik tell me onething. I have this tomasetto kit installed on my OHC 1.5, got it installed in Tilak Nagar. There's a slight drop in performance in CNG mode but only slight. I'm now planning to make it as good as petrol mode. So would installing a TAP will take care of the whole issue or should i have additional things also?
and how should i find out that my current CNG setup is in open or closed loop because if its in closed loop than i would prefer lambda as TAP would be useless in this case.
and from where did u get your CNG installed?
also i want to get rid of this fluctuating ideal RPM which occurs sometimes.
Old 3rd June 2008, 00:12   #12 (permalink)
abhik's Avatar
TAP(timing advancer) would make a lot of difference in performance, infact you might even see better performance than petrol.
Go to your dealer and enquire about the kit, most kits are installed in open loop operation where TAP does good and Lamda is good for closed loop ones.
TAP would be for Rs1000-1500, they come with 3 settings like a tuning box and have 3 remaps(dont confuse it with ECU remaps which play around with AFR signals etc,its just for timing ) as option.
I will PM you my fitters details.
__________________
ABHIK
Old 3rd June 2008, 02:45   #13 (permalink)
abhinav yaar,
Oh God CRV's. Why Do People Buy such cars when they cant fill 'em up and run them
@abhinav boss thanks... arey baba.. insult kahe ka.. engine ko bura lage toh petrol pe chala lo..lolz
Vtec Will always feel insulted bro.
Gosh, I thought 3.0V6 and vRs's owners bought the cars for performance and not looking at efficiency, even if they can get great performance installing other components with CNG
__________________
-=]|Do The Dew|[=-
Old 3rd June 2008, 10:49   #14 (permalink)
hmm so i think i would start my search for used baleno or city to get this operation completed. I was willing to go for a new car (Swift VDI), but the increase in fuel prices have left me with no choice at the moment.
I head about Lamda and TAP out here and also on another thread which talks about performance mods for CNG cars.
Can anyone guide me from where can i get more information on this and where to contact to get it installed in Delhi.
Cheers.
Old 4th June 2008, 20:31   #15 (permalink)
abhik's Avatar
@invincible ill PM you my fitters details, he is a person with excellent knowledge about CNG.
__________________
ABHIK
Thread Tools
Which car for CNG? Haste Hatchbacks 31 11th April 2008 08:10
Car Partition like New York Taxis - Installation advice please Murugan Modifications & Accessories 16 13th June 2007 22:16
CAR PC installation ddawg DIY - Do it yourself 7 31st January 2007 03:51
For sale: CNG and LPG kits (with installation) Minardi Shifting gears 3 3rd October 2005 15:51
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478
