Old 9th June 2008, 13:32   #16
jaysmokesleaves's Avatar
Thanked: 1,258 Times
I have seen a mirror hanging off from the top of the boot(outside) of suv's like innova scorpio safari crv etc... what is that mirror for and how does it help?
jaysmokesleaves is offline   Reply With Quote
Old 9th June 2008, 15:49   #17
Thanked: 245 Times
Sorry, asthedivx, it seems I was misinformed about the installation.
But as i was searching for benefits I found it is indeed beneficial if installed properly.
The initiative by former Road Safety Minister to tackle 'side-swiping' incidents involving left-hand drive trucks has shown a 59% reduction in accidents and work is now underway to roll it out across the country, current Road Safety Minister Jim Fitzpatrick announced on 6th December.
The results follow the distribution of 40,000 window-mounted lenses - known as Fresnel lenses - to left-hand drive trucks entering the UK across the Dover Straits. The Highways Agency will now distribute a further 90,000 lenses, targeting major ports in both England and France.
Source
Feature of wide angle rear window fresnel lens
* Easily applied and removed by using water only.
* Easy installation on rear window of your vehicle.
* No tools required.
* Need no adhesive, just use water only
* The lens is better working for vertical rear windows
Thickness: 1.2mm
Weight: 70 grams
Material: Soft PVC
Groove pitch: 0.5mm
Focal Length: -300mm
View Angle:
upward:13 side:25 down:27 degree
How to install?
* Apply the quality lens to the inside of the rear window near the botton edge.
* Make sure window is clean, then wet it with water
* Apply smooth side of lens on the inside of window
* Remove air bubbles from the lens
* Hold firmly in place for a few seconds.
* The lens will turn crystal clear until peeled off.
Old 9th June 2008, 16:44   #18
bblost's Avatar
Thanked: 6,979 Times
I guess you mean this
More About the Hawkeye
Old 9th June 2008, 16:52   #19
snaronikar's Avatar
Thanked: 23 Times
[quote=dadu;859416
Does it help improve the visibility of the hidden areas at the back ??.
I have seen that many people use it but need feedback from someone using it, Pro's & Cons please.[/quote]
It sure does increase the visibility. It is used mainly for hatchback cars like yours. 3M does have the same product and many people using it are satisfied with the visibility it provides. Only thing is you need to fix at the correct angle. Go for it, Dadu.
snaronikar is offline   Reply With Quote
Old 9th June 2008, 17:23   #20
Thanked: 103,537 Times
I have used the circular convex (stickon) mirror in my Accord, and it greatly helped toward maximising the field of vision.
For reversing.
Old 9th June 2008, 17:37   #21
Sankar's Avatar
Thanked: 4,651 Times
People lets not confuse between lenses and mirrors. The thread is about lenses that is to be stuck on the rear wind shield of the vehicle.
Old 11th June 2008, 14:16   #22
Thanked: 29 Times
Hi Snaronikar,
I have used the lense in my Bolero and Scorpio and found it useful. The key is to ensure that the person who drives most, sit on the drivers seat and guide the instalation of the lense to ensure that you get the optimum view. One drawback that I faced was while looking through my rear view mirror, I could not see the traffic very clearly through the lense.
However it was very beneficial to me while reversing so I overlooked the drawback. Just fyi there are 2 kinds of lenses. One where you wet and fix the lense entirely while another which has a frame and a handle and only the handle gets fixed. I found the former better.
Trust the above helps.
indianrunner is offline   Reply With Quote
Old 11th June 2008, 16:06   #23
Thanked: 7 Times
Originally Posted by indianrunner View Post
Hi Snaronikar,
Where to purchase these lens from in Mumbai ?
Rgds
emkay456 is offline   Reply With Quote
Old 11th June 2008, 16:38   #24
Thanked: 245 Times
At your friendly neighbourhood accessories shop or a 3M outlet (if you can find it out).
Rgds
Old 15th June 2008, 13:03   #25
Thanked: 245 Times
After much search and thought I ordered from Ebay which was delivered promptly and then with much of R&D (Since safari has the Spare wheel right in the center) fixed as below:
Wide Angle/Magnifier Rear Window Lens-picture-009-large.jpg
You can buy it from 3M too, but twice as costly and smaller the size. I bought 11x14", cut it into half.
For 3M, had to call their regional office - then got a salesguy number, called him - got the distributor number, called him- got the dealer number.
Dealer had no stock (slow moving) but the distributor assured of delivering the stocks soon.
First Impressions:
Using the arrangement I used, the top glass is very clear and provides natural view, left about an inch from the bottom with the same clear view.
- The fresnel WAL, does capture more area than you can see through the rear glass without it, from both the road below and the sides.
- Just like the ORVM, things are closer than seen, so will need to develop a judgement for it.
- Fulfills the purpose of showing up the hidden things on the road and side's apprx 3-4ft below and away from the rear of the rear glass.(big rocks, bicycles, scooters, motorcycles, kids).
- It would be very very useful for hatchbacks and vehicles without a spare tyre mounted/boot on the back and at unimaginable costs.
- No extra mounting required, easy install and removal, no wires, no warranty problems for new cars.
Old 17th June 2008, 17:59   #26
Rocky_Balboa's Avatar
Thanked: 66 Times
Smile
Dadu,
Thanks for the recommendation buddy, have bought one from ebay after reading through your post. Shall check out the use and update here.
TChau,
+Rocky_Balboa+
Rocky_Balboa is offline   Reply With Quote
Old 17th June 2008, 18:25   #27
diwa's Avatar
Thanked: 45 Times
What is the cost?.
Is it advisable for a Swift with dark Sunfilms?
diwa is offline   Reply With Quote
Old 17th June 2008, 20:36   #28
Thanked: 245 Times
Its no longer available on ebay so check your nearest acc shop. 3M costs around 550Rs for a 6x8 and 1000rRs for 8x10.
Its just a wide angle lens, so it will show a picture of a wider and hidden areas collated in the lens as you would see through the dark glass naturally.
Originally Posted by diwa View Post
What is the cost?.
Old 18th June 2008, 12:19   #29
Thanked: 7 Times
If anyone still interested in the Fresnel product, as the listings are removed from Ebay, the vendor can be contacted directly at autobahnindia@hotmail.com. The person's name is Mr. Devan. You may have to check out with him regarding the modalities of the transaction.
I have purchased the product, like Dadu did. It has been delivered and am waiting for the weekend to find time to do a "precision fitting" !
My only apprehension is how the lens would stick to the glass by just using a water coating as mentioned in the literature ?? It may fall off whenever cabin temperatures are high under the sun !!
Old 18th June 2008, 12:58   #30
rjstyles69's Avatar
Thanked: 795 Times
Just drove a car with this thingy stuck on the rear glass. Couldn't find much of a difference coz once you are accustomed to the RVM's(L&R) IMO you hardly tend to look into this.
I found it easier to use the RVM's and maybe it takes time to get used to this concept. Well thats just me.
Piaggio 3 wheelers - Camber angle of the rear wheels? sivadas Commercial Vehicles 4 5th June 2014 16:22
Power Window Failure? How to manually roll your window up lsp Technical Stuff 36 13th April 2014 15:24
Knocking/Crunching noise on reversing at an angle abhi182 Technical Stuff 6 11th March 2008 14:16
Multi-angle Valve job manveet Modifications & Accessories 13 18th April 2007 06:20
