Old 7th February 2007, 12:09   #1
kousik's Avatar
Thanked: 36 Times
Question Wide Angle/Magnifier Rear Window Lens
I am curious about a small magnifier lens (that's what it looks like from far) people fit in their rear window (I have seen a few scorpios, and maybe incidentally only scorpios). What good it is for ... do they give a better visibility when backing up? Any idea of cost & availability? It may look bad, but if it improves reversing experience, I'd like to fit one in my innova. Again, I have seen one that had bubbles/almost peeling off, so would like to know if that is a common case (it'll last only 6 months).
Kousik
kousik is offline   Reply With Quote
Old 7th February 2007, 14:45   #2
Thanked: 103,537 Times
Hi Kousik
The small convex mirrors are great to increase area of coverage, and eliminate blindspots. I used a pair on my Accord, and it was a boon on the american freeways.
Old 7th February 2007, 15:41   #3
Thanked: 24 Times
hi koushik
its a wonderfull idea, as i have a indica, i purchased one from ebay for around 150/-. But the glue thing isnt good enough to hold to the rear glass. It fell off many a times. I even tried with fevi-quick, it wont stick.
Can anyone give me some idea, to stick it.
kkr2k2 is offline   Reply With Quote
Old 7th February 2007, 15:56   #4
Akshay1234's Avatar
Thanked: 7,242 Times
the only thing i can think of is celotape. but if you have sunfilm of your windscreen wont it mess it up?
Old 7th February 2007, 20:41   #5
CrAzY dRiVeR's Avatar
Thanked: 19,819 Times
Who would put sunfilm on the rear view mirrors???
Old 7th February 2007, 20:46   #6
Akshay1234's Avatar
read the title.. it says rear window
Old 7th February 2007, 20:48   #7
Rudra Sen's Avatar
Thanked: 4,294 Times
He didn't say rear view mirror but windscreen.
Why can't someone put film on windscreen? Be it front or rear. Whole idea is to cut the heat. Isn't it?
Old 7th February 2007, 20:53   #8
Please correct me if iam wrong,but i remember seeing this thing on Ambassador's and Fiat's apart from other car's way back when i was a kid!
Is it the same Square opaque looking thing we are talking about?
Desert fox is offline   Reply With Quote
Old 16th February 2007, 21:21   #9
gd1418's Avatar
Thanked: 656 Times
Yes, it is the same Square opaque looking contraption..
Old 9th June 2008, 12:20   #10
Thanked: 245 Times
Question Wide Angle Rear Window Lens
Does it help improve the visibility of the hidden areas at the back ??.
I have seen that many people use it but need feedback from someone using it, Pro's & Cons please.
Old 9th June 2008, 12:40   #11
ashthedivx's Avatar
Thanked: 22 Times
We tried it in our innova, but sadly the so said lens fell apart inside usually. I suppose it costed somewhere around 300-400 rs. Though once installed, i didn't found it so much useful while reversing.
Better option - To have a reverse camera. Serves the purpose very efficiently.
Old 9th June 2008, 12:59   #12
Thanked: 245 Times
Its a convex lens and needs to be put on the outside and not inside.
No doubt, it wont make any difference as per your installation.
Old 9th June 2008, 13:06   #13
Rough Square's Avatar
Is this lens stuck to the rear glass?
Rough Square is offline   Reply With Quote
Old 9th June 2008, 13:16   #14
ashthedivx's Avatar
Thanked: 22 Times
Installation was done properly i.e. as per installation guide provided in the box. However major problem was things behind seems to be too much convexed towards center point, which otherwise creates confusion while reversing in rush.
Later (since it was avoided) it was permanently removed due to hindrance in rear view.
Old 9th June 2008, 13:22   #15
trrk's Avatar
Thanked: 13 Times
Hi dadu,
I have used it before. It has to be put inside and not outside. I never had the problem of it coming off. The problem is that it changes from transparent to yellow in about an year's time.
It definitely improves the rear vision to an extent.
trrk is offline   Reply With Quote
Piaggio 3 wheelers - Camber angle of the rear wheels? sivadas Commercial Vehicles 4 5th June 2014 16:22
Power Window Failure? How to manually roll your window up lsp Technical Stuff 36 13th April 2014 15:24
Knocking/Crunching noise on reversing at an angle abhi182 Technical Stuff 6 11th March 2008 14:16
Multi-angle Valve job manveet Modifications & Accessories 13 18th April 2007 06:20
