Old 26th June 2008, 19:16   #76
abhik's Avatar
Originally Posted by abhik View Post
Try an expansion chamber after the headers, will surely boost torque and that should translate into better low-end grunt.
Oh! BTW by the above i meant headers then expansion chamber then intermediate pipes then muffler.
abhik is offline   Reply With Quote
Old 26th June 2008, 19:37   #77
The Wolf's Avatar
Thanked: 58 Times
One more solution guaranteed to work and wouldnt cost much at all, over size the throttle body venturi by giving it a nice port job and then a shining polish work.
If you have money to put in, get yourself a bigger throttlebody itself and follow the other instructions I have stated earlier like Fuel pressure regulator and heat shielding your filter. You should be more than happy with this!!!
The Wolf is offline   Reply With Quote
Old 26th June 2008, 20:06   #78
Torqueguru's Avatar
Thanked: 161 Times
Alright, I am not fully aware of all what you said, but you have given me enough food for thought.
Thnks,
TG.
Torqueguru is offline   Reply With Quote
Old 26th June 2008, 20:07   #79
Thanked: 3,508 Times
Oversizing the throttle body would drop the low end torque even further.
Old 26th June 2008, 20:18   #80
The Wolf's Avatar
Thanked: 58 Times
Oh yeah?? Says who??
Old 26th June 2008, 20:25   #81
Is my name hidden from your view?
Old 26th June 2008, 21:13   #82
abhik's Avatar
Chill guys!! Both of you can give your respective POVs on your theories. No need to be rude here!!! In the process others can learn something as well.
Old 26th June 2008, 23:22   #83
theMAG's Avatar
Thanked: 1,471 Times
How about a TB enlargement?
Old 26th June 2008, 23:28   #84
RedMM340's Avatar
Thanked: 23 Times
Wolf,
I have to agree with Sankar, he is right on with what he says about the throttle body (and every thing else that he has commented on).
Larger size is really for high engine speeds where the throttle diameter becomes a restrictive factor on maximum power. By the way, this is why all rally race specs. have a max allowable throttle body diameter specification.
Stock cars have small throttle bodies that are sized to give good air velocity at low rpm, thereby providing good low end throttle response and torque.
Another point to consider is the fact that some high performance engines actually use 2 sets of intake runners. Small diameter for low rpm with secondary large diameter ones for higher speeds.
Even older carberator engines use the same principal. I used to have a chevy with a 4 barrel carb., and the front two barrels were tiny little ones that gave good low rpm response, and then there were 2 huge secondary barrels that opened up for high engine speeds.
RedMM340 is offline   Reply With Quote
Old 27th June 2008, 00:19   #85
pawan's Avatar
i am guessing it has to do with velocity with a larger t.b the velocity decreases since it has more place to travel through
(like a water pipe when the hose is covered the water flows with more force but at less volume) but would benefit at higher rpm that is why i think ford rocam also suggested going with a smaller diameter near the t.b to possibly increase the low end torque.
pawan is offline   Reply With Quote
Old 27th June 2008, 01:39   #86
iceman91's Avatar
Thanked: 22 Times
yeah.. Finally gaurav. Somethin we both agree on bigger throttle body does not mean more torque necessarily
iceman91 is offline   Reply With Quote
Old 27th June 2008, 13:05   #87
crazydiablo's Avatar
Thanked: 21 Times
I am seconding Sankar on the TB issue.
Iceman: Looking forward to your baleno development.
crazydiablo is offline   Reply With Quote
Old 27th June 2008, 13:07   #88
Torqueguru's Avatar
Thanked: 161 Times
I too am totally with what sankar said.
Old 27th June 2008, 15:57   #89
Shan2nu's Avatar
Thanked: 87 Times
An ECU would be your best bet. But personally, just let a high revving engine do what it's designed to do. It would be much easier to change your driving style. All it takes is one downshift!!!
Shan2nu
Old 27th June 2008, 16:35   #90
Thanked: 23 Times
It's the opposite that will happen. With a heavy flywheel the top end more or less remain the same but acceleration would definitely suffer. The heavy flywheel makes the cruising in top gear and top speed easier as the crank stores reserve energy and it's momentum keeps it going. Acceleration would increase with a light crank.
How about going for a lightened flywheel?
Please any one explain the effect of lightening the stock flywheel or replacing it with a lighter one.
raj.
kkr2k2 is offline   Reply With Quote
Ritz modification - How to increase low end torque funda2max Modifications & Accessories 35 3rd March 2015 13:41
Repeat EXAMM! The ghost of 1st low vs 2nd low descent haunts us again... and how! Tejas@perioimpl 4x4 Excursions 41 23rd September 2010 14:16
Increase Low end torque in Swift Petrol pshyamsundar Modifications & Accessories 5 4th April 2007 12:30
How to increase the pick up and top speed of a Machismo? Rayden Motorbikes 1 3rd April 2006 10:55
