Old 25th June 2008, 22:19   #16
RedMM340's Avatar
Thanked: 24 Times
Originally Posted by crazydiablo View Post
This is a reasonable request. Infact probably should be part of the tuning process. It works out if the owner has done his homework and can reasonably understand what the tuner is explaining.
My thinking is that if a shop is genuine, and knows how to do really high quality work, they should be somewhat transparent on what is done. This type of work is an art more than just a mechanical job. It is not something that if I look at what is being done, I can just turn around and start copying it.
This is just not the type of work that you can blindly trust someone to drop off the car and pick it up a week later and hope that the work was done properly or done at all!
Perhaps I should look at tuners in Mumbai, Bangalore, & Chennai. There seems to be so much more technical skill for tuning in those areas. And from what I understand the work ethic there is much better, in terms of doing really quality work.
RedMM340 is offline   Reply With Quote
Old 21st November 2008, 11:31   #17
drvhplyevraftr's Avatar
Thanked: 16 Times
Guys,
Does anyone has any idea on where to get the porting polishing job done in
Hyderabad?. Also some inputs on the cost involved.
Thank you.
drvhplyevraftr is offline   Reply With Quote
8 Valve SOHC vs 16 Valve SOHC shineshine Technical Stuff 6 12th February 2016 22:23
Porting and Polishing!!! Edmund Technical Stuff 61 22nd November 2012 20:56
effect of grinding EGR valve in diesels reachbennym Technical Stuff 1 23rd December 2008 09:05
Hi every1 - Porting / polishing in mumbai? cancerm Modifications & Accessories 2 18th October 2007 01:52
Engine Porting, Ploishing & Valve Cutting Kaizer Sozay Modifications & Accessories 6 15th March 2006 23:36
