Old 7th July 2008, 12:22   #1
viky_s's Avatar
Default Esteem Suspension Problem...
Hello Guys,
I have the new MPFi Esteem bought just 2 years ago. Its running on Yokohama Sports series 195/60/R15 eversince.
When 4 people ( approx weight = 75kg/person i.e Total 300) are seated in the car( Front 2 + Rear 2) and we are driving on some uneven road at around 60-80km/hr ;the rear wheel of the car touches the suspension.
I know this is due to the upsized tyres.
But i love them and replacing them with 14" or 13" is not an option
So what kind of mods can be done to the suspensions(Front and rear) to solve this problem and also have a smooth ride on dirty uneven roads.
Preferably i want to retain my original suspensions (Cost saving purposes)
Awaiting your valuable suggestions.
regards,
vikram.
viky_s is offline   Reply With Quote
Old 7th July 2008, 13:51   #2
nitrous's Avatar
Thanked: 285 Times
The correct upsize for the esteem is 195/50/R15.
I believe 'godfather' had this size in his esteem.
Old 7th July 2008, 13:57   #3
headers's Avatar
Thanked: 464 Times
Originally Posted by viky_s View Post
Hello Guys,
Hi, you could add spacers to the suspension and fit the bump stop on it. this will reduce the stroke lenght of the suspension though!
Simple alternative is to drive slowly on bad roads!
Old 7th July 2008, 23:53   #4
CaliforniaKnight's Avatar
Thanked: 46 Times
can we do this upsize on stock suspension? what would be the correct rim size then?
CaliforniaKnight is offline   Reply With Quote
Old 8th July 2008, 00:13   #5
speedfreak7116's Avatar
Nitrous was talking about the perfect rim and tire upsize.. U cant upsize suspensions..
U can harden the stock suspension though but will lose out on ride quality.. Putting 16'' was not the best thing you did but if you like them then u have to make a compromise on something..
speedfreak7116 is offline   Reply With Quote
Old 8th July 2008, 00:21   #6
JayD's Avatar
Thanked: 2,008 Times
I really don't think he was talking about Upsizing the suspension!
He was asking whether the specific tire upsize was possible with the stock suspension!!
Old 8th July 2008, 02:19   #7
JRD
JRD's Avatar
Thanked: 11 Times
I think to solve the issue probably stiffer shocks or may be set of performance springs might help.. not too sure you will be able to keep the ride quality the same after those things..
My corolla had TRD lowering springs and 17inch rims and YIKES!! the dashboard started to rattle.
thats the same reason im sticking to 185/60/r13s on my esteem
good luck with it
Hello Guys,
regards,
vikram.
JRD is offline   Reply With Quote
Old 11th July 2008, 15:47   #8
Thanked: 46 Times
I perfectly know that, as JayD said, I want to know if I can fix 15inchers, on my car which I have upgraded with Konis.
Old 14th July 2008, 10:59   #9
viky_s's Avatar
Sorry guys, the correct tyre size is 195/50/R15. A major typo. on my part.
I am reluctant to add spacers as this will hinder the shock absorbing capacity of the car. I was thinking about replacing the rear springs with new ones ;but little stiffer as i dont want a hard suspension.
Which type and brand of springs should i go for? and what will be the cost?
Time for Suspension Re-do for my Esteem esteem_lover Technical Stuff 26 3rd March 2010 01:42
NHC Suspension at 62,000KM - Want a better alternative to the OEM Honda suspension anandpadhye Technical Stuff 15 13th September 2008 18:56
95 Esteem Engine, suspension and chassis good condition IronWolf Shifting gears 0 2nd July 2007 02:25
Esteem Suspension invincible7 Modifications & Accessories 11 6th June 2007 19:58
Kindly Advise - Esteem Done 80k Needs Suspension + Cluth Plate passion4cars Modifications & Accessories 4 8th December 2006 02:13
