Old 18th October 2010, 09:45   #31
@ 4x4addict - My jeep's a 2WD although I suspect that it used to be a 4WD some time in the past. It still has a opening on the floor next to the gear lever.
The reason I was thinking of a 5 speed gear box was because the engine rises when I cross 60 kmph on 4th gear although there is still enough and more power.
Anyway, if it's not possible, I'll just live with it as suggested by you.
KD
kd7202 is offline   Reply With Quote
Old 18th October 2010, 21:20   #32
@ 4x4addict - Just wanted to tell you.
Your MM540 was the role model for mine when I was getting it tinkered & painted. Looks exactly like yours minus the extra lights & broad tyres but with a black soft top.
Old 24th October 2010, 13:41   #33
Hi guys,
Can anyone help me in sourcing a used, fairly good XD3P engine and 5 speed gear box ? Its for my 2WD MM540.
My mech says some repairs are necessary for the existing XDP4.9 engine and 4 speed gear box which would cost me approx. 20K.
Alternatively , he suggested that I upgrade to the XD3P engine + 5 speed gear box. He says this may be available for around 40K to 45K in Bangalore but we'll have to search around as we may not get both together at the same time.
He also said that he would be able to mate a 5-speed gear box to the existing engine. One of the early Bolero gear boxes. I need to do a cost analysis on this.
Used XD3P engine + 5 speed gear box Vs. overhauling the existing XDP4.9 engine and add a 5 speed gear box !! How effective would be the second option ?
Is 45K a reasonable price to pay for the XD3P engine & 5 speed gear box ?
Need some guidance in this matter.
Thanks in advance.
KD
Old 24th October 2010, 22:47   #34
jeepster's Avatar
Thanked: 1,036 Times
my opinion is overhaul your xd3p & get a good BA10 gearbox.
or if you have some extra time & money you can go for Nissan, isuzu or other Engine+GB options too.
http://www.team-bhp.com/forum/4x4-ve...40-reborn.html (MM540 Reborn)
http://www.team-bhp.com/forum/4x4-ve...del-mm540.html (New Purchase - Army disposal 2001 model MM540)
http://www.team-bhp.com/forum/modifications-accessories/84983-jeep-wrangler-jk-automatic-conversion.html
http://www.team-bhp.com/forum/modifications-accessories/8517-what-new-engine-jeep.html
http://www.team-bhp.com/forum/modifications-accessories/35098-installing-5-speed-tranny-mm540-mm550.html
rgds,
Nikhil
please copy & past above links. some of them are not working.
jeepster is offline   Reply With Quote
Old 25th October 2010, 09:50   #35
Hi Jeepster,
Thanks for the inputs. My existing engine is a XDP4.90 and not a XD3P. I am actually looking for a XD3P engine and 5 speed gear box.
My mech says he'll be able to mate a 5 speed gearbox to my existing XDP4.90 engine, so if I can look at buying only the gearbox as well.
KD
Old 25th October 2010, 11:49   #36
4x4addict's Avatar
Thanked: 2,669 Times
Hi Jeepster,
5-Speed can be mated using an adapter plate. You can pick up only the gearbox if you don't need the engine gearbox combo.
4x4addict is online now   Reply With Quote
Old 25th October 2010, 14:51   #37
@ 4x4addict - Thanks. I'll start the search for a 5-speed gearbox.
My existing gearbox has a problem, when I engage first gear and accelerate, the jeep makes a noise like a loaded lorry although the noise is not there in the other gears. Mech says this can be rectified by overhauling the gearbox.
But nothing like getting a 5-speed gearbox. Any idea where I can get one ? And cost ?
KD
Old 28th October 2010, 18:37   #38
jeepster's Avatar
the best person to contact will be ex670c.
Old 13th November 2010, 15:15   #39
melsingh's Avatar
Smile
KD
Hi, I think all MM540s have the same problem over a period in time, don't worry, it's a common complaint.
I've just put in a 5-speed Scorpio GB to my existing 2.1 Peugeot and it works just fine...I can get anywhere from 90-110 or even more (haven't pushed that hard till date), but there were some minor adjustments that had to be done and some trial runs to and fro from B'lore to Ooty to get it right. I still feel there is more that the engine can do with a slightly better ratio but I'm content mate...
I got mine for 29k with all repairs, the starter and flywheel (Armada Grand) along with the beds, etc. I don't know if this is a good deal, but it was sourced close to Coimbatore. Do let me know if you're interested, PM me and I'll call up a few guys that sourced it for me...Cheers!!!
melsingh is offline   Reply With Quote
Old 26th December 2010, 19:28   #40
Default Re: Need help Regarding MM540/550
Hi
I am getting an Isuzu 5-speed gear box from the Bangalore gujri for about 6K. Its from a Contessa. The guy selling it to me says its in good shape and does'nt need any repairs, can be mated to the engine using an adaptor plate which he will source for me if possible.
Mine is a MM540 2WD with a Peugeot 2112 cc engine.
Apart from the adaptor plate, what else will I need to buy/modify in order to mate the gearbox to the engine ? The guy was talking about differential gear ratios to be changed, shortening the propeller shaft and some more technical gobbledegook which I did'nt understand.
Can someone please guide me in this ?
Thanks in advance
KD
Old 27th December 2010, 09:23   #41
4x4addict's Avatar
@KD:
Apart from the adapter plate you will need to shorten the rear prop shaft as the BA10 is a long gearbox compared to the KMT90 you have. I don't have the exact gear ratios of the Isuzu BA10 configuration in the contessa. Don't change the differential ratio until you have driven the vehicle with the new gearbox and tested the performance.
You are already on the 4.88 OEM mm540 diff ration. The next option is 5.38 which will be too short and you will loose the benefit of having made your jeep a 5 speed.
Stick with the current ration and use it for a while before you decide.
Old 27th December 2010, 10:36   #42
@ 4x4addict : You mean retain the existing 4.88 diff ratio with the new gearbox ?
What do you mean when you say 5.38 would be too short ? Will low end power be reduced if I change it to 5.38 ?
All I am looking at is some top end speed. With the existing 4-speed gearbox I am not able to do more than 70 kmph.
Any idea how much these modifications would cost ? Adaptor plate, shortening the prop shaft, tinkering work, etc.,
KD
Old 27th December 2010, 13:31   #43
Red Liner's Avatar
Thanked: 1,482 Times
KD
Your top end speed will reduce. Your pick-up will increase. If you want more top end speed and not much low end grunt, then move to the ratios available across 3.xx
Red Liner is offline   Reply With Quote
Old 27th December 2010, 21:03   #44
4x4addict's Avatar
I suggest stick with the 4.88 or go down to 4.27 at the most. Anything less than that and your 61 bhp peugot engine will not be able to move the jeep at a decent pace.
Old 27th December 2010, 23:18   #45
shekaran's Avatar
Thanked: 63 Times
am waiting eagerly to know the results of mating the isuzu gb with xdp ???
KD sir, how was the results of the boric acid powder treatment ? did you use in the differential and test the drive ? whats the mileage gains ? pls post detailed results of the engine, gerabox, and also the differentials.
HAPPY NEW YEAR WISHES TO ALL TEAM BHPIANS !!!
shekaran is offline   Reply With Quote
Power Steering on an MM540/550 jeep DirtyDan 4x4 Technical 56 5th May 2018 20:25
MM540/550, Army fenders made available! fazalaliadil 4x4 Vehicles 57 9th November 2015 19:45
The elusive MM540 / 550. EDIT: New Search for ex-Army 550 on page 9 IronWolf 4x4 Vehicles 146 13th February 2015 23:02
MM540-4WD wish list - what you really want in your MM540-4WD? DHABHAR.BEHRAM 4x4 Vehicles 299 7th January 2010 13:02
