| LinkBack | Thread Tools | Search this Thread |
| | #31 |
| BHPian Join Date: Apr 2004 Location: Udupi
Thanked: 22 Times
| Hi moralfibre i just took my car from the service station.this is the old tvs service station in udupi-it now services all cars and not only fiats after tata took over the service of fiats.but they still do a better job than the tata-fiat service centre. The mechanic was honest enough to say he had no idea about it as he had not yet done such a job in the past.he said we can try it out,but as Red pointed out it would mean i have to purchase the whole kit and take it to him which would mean waste of money if it is a failure!! |
| | #32 | |
| BHPian Join Date: Apr 2008 Location: on the move
Thanked: 11 Times
| Quote:
Nor does EBC , red, yellow, or green. I have tried to match up the Palio pad with everything in the EBC catalog with no luck. Who is N1 ? I have checked with Arush at Autopsyche doe not have anything for the Palio either. | |
| | #33 |
| BHPian Join Date: Aug 2008 Location: Mumbai
| | #34 |
| BHPian Join Date: Jul 2007 Location: Pune
Thanked: 18 Times
| Hello!! Any updates on the topic I'm having a tough time with the brakes in my Palio GTX. I just did a complete servicing on the brakes with a change in brake pads and everything, and it hasn't helped much.. Could someone suggest a good option to improve the braking in Palio as I'm playing with fire everytime I brake at speeds beyond 100 kmph.. |
| | #35 | |
| BANNED Join Date: Mar 2005 Location: Mumbai
| Quote:
Hi, Both Wilwood & D2 Racing have solutions for all cars. Its just a matter of knowing what to order. Viper | |
| | #36 |
Thanked: 22 Times
| Guys am not good at technical stuff but can these front discs work on indian palios?the website mentions it will on the 1.6 OMP 257.5mm Front Brake Discs FIAT PALIO & WEEKEND 1.6 on eBay, also, Fiat, Car Parts, Cars, Parts Vehicles (end time 07-Feb-09 15:35:34 GMT) |
| | #37 | |
Thanked: 11 Times
| Quote:
No they do not have solutions for "all cars". But, since you seem to be the expert on 'knowing what to order', please do post the appropriate parts for the Palio brakes. Last edited by Rehaan : 2nd February 2009 at 15:43. Reason: Lets stick to facts and questions. No allegations please. | |
| | #38 | |
| Quote:
Am sorry I offended your superior knowledge. To the best of my knowledge they do and am just making people aware of the same. I have no interest in arguing with you or anyone else on the forum. Viper Last edited by Rehaan : 2nd February 2009 at 15:43. Reason: quoted post edited. | |
| | #39 |
| Distinguished - BHPian ![]() | Personally, Unless a part is specifically designed for a car, I wouldn't mix and match different car parts on a certain car. Because Most times when parts are almost the same,the difference in design shows up under slightly spirited usage and becomes a problem and just money down the drain. Last edited by nitrous : 2nd February 2009 at 11:26. |
| | #40 |
| Nitrous, True to an extent. But for eg if the PCD is the only problem and that car is not listed you can always use a disc from another car with the same pcd & size without any issues. Viper |
| | #41 |
Thanked: 22 Times
| Guys has anyone gone through the link i posted?they are replacement brakes for the palio 1.6.not sure if they will work for india |
| | #42 | |
Thanked: 11 Times
| Quote:
I looked at the link that you posted, and I am not sure that these brake discs will offer much of a benefit over stock ones. Slotted and/or cross-drilled rotors may help in high performance applications where disc overheating is an issue. But this does not seem to be the problem for the Palio. The Palio needs brake pads with a higher coefficient of friction. Unfortunately, I have not been able to find any aftermarket pads. As I have posted earlier, my conclusion for living with the Palio brakes is to maintain them meticulously. This means resurfacing the rotors, using the best quality brake pads available through Fiat, making sure that the caliper pins are not sticking, flushing new DOT 4 brake fluid, and do the same for the rear brakes. Regards, | |
| | #43 |
| BHPian Join Date: Jun 2007 Location: Bangalore
| Hi Guys, Am looking out for a brake liner(rear wheel - drum) for my 1.6 GTX(with ABS). was told by the dealer that brake liner for ABS is different from the other ones. Is this true? He also told me that it is hard to get brake liner for the ABS type. I tried calling up concorde motors in bangalore and they seem to be not aware of this and said they will check. I need to do this at the earliest possible as without changing the liner it seems like not possible to take it for a drive in city/long drives Please help |
| | #44 | |
Thanked: 22 Times
| Quote:
How frequently to do all this?as per manufacturer specifications or more frequently? regards | |
| | #45 |
| BHPian Join Date: Jan 2008 Location: ludhiana
| hello friends i have a fiat petra 1.6 done 83000km .now i also find its braking little weak. got my regular service done and the bite has improved a little but still not upto the mark .i got the brake pads changed last year. what can be done to improve the braking . do u know of any after marked brake pads which are better than oem. when does one need to change the brake discs .or drum linning changed |
Similar Threads | ||||
| Baleno Brake upgrade options | crazydiablo | Modifications & Accessories | 27 | 19th August 2011 01:24 |
| Palio Brake pads for ABS | ravikn | Modifications & Accessories | 2 | 6th March 2009 08:29 |
| Palio Mods (TC, ECM, & Rear Disc Brake Conversion) | sbfx | Modifications & Accessories | 37 | 25th May 2007 20:11 |
