Old 14th May 2014, 16:23   #91
kaustubh_vaze's Avatar
Default Re: Palio Brake Upgrade
Adevnture/Linea 257 MM discs, Calipers, Pads are required for the upgrade. Been using it since 4 years. Works like a charm.
It can be swapped on and off.
In fact some of the Bangalore guys come down to Pune to my mechanic to get their cars serviced. You can ask them Bangy boys on the whereabouts and get this done in Pune itself.
kaustubh_vaze is offline   (1) Thanks Reply With Quote
Old 20th May 2014, 17:19   #92
Thanked: 110 Times
It can be easily swapped and only one issue is to find out Adventure caliper and bracket. Some guys told me non ABS of punto caliper is same as adventure only the bracket support is different. I am yet to fix the rear assembly but the braking prowess of the front setup is very good, infact when I drive others palio I end up nail biting stop which was an history in my car.
If you are in Bangalore you can contact Sunnyboi who had changed both front and rear to Advy setup on his S10
You can refer this thread I have completed my brake upgrade. Dont know its offensive to cross quote another forum but it will solve most of the mystery in palio brake upgrade.
http://myfiatworld.com/showthread.php?t=832
vijaycool is offline   Reply With Quote
Brake fluid/Parking Brake Indicator light- Is this a problem? santosh.s Technical Stuff 10 7th June 2017 14:02
Paint for disc brake pads & rear brake drums VC12 Modifications & Accessories 8 25th October 2011 17:18
Disk Brake to normal brake change? ramki067 Motorbikes 10 7th August 2008 14:19
Only brake OR clutch+brake swiftcrazy Technical Stuff 8 10th July 2007 23:19
Which is the right Sequence Clutch-Brake Or Brake-Clutch ankura12 Technical Stuff 2 9th July 2007 10:02
