Old 22nd July 2008, 18:39   #1
Thanked: 420 Times
Default Engine Immobilizer for Safari 2.2 VTT Lx
I am new over here, Thanks to Team BHP I have booked my Tata Safari 2.2 VTT Dicor Lx Quartz Black on Monday and hope to take delivery on Thursday or Friday morning. I searched on Team BHP and got to know about Xenos and AutoCop Engine Immobilizer and Security System ( XS-8500 ) in one of the ownership threads of Safari Dicor Lx but there was no info on any recommendation and also not sure if XS-8500 is actually an immobilizer or just an impact sensor. I enquired at few shops in Koramangla but got no clear answer.
I talked to the dealer for fitting the Engine Immobilizer but got the response that it is not possible , Actually I asked if this will void the warranty or not but both sales guy and the person at necessaries desk of Concord replied that it is impossible to fit an after market engine immobilizer in Safari. I do not understand any logic behind
this. I inquired on few shops in Koramangla area but got not clear answer.
So I have following questions to Safari Gurus here.
1. Can Engine immobilizer be fitted in Safari as after market fitments , I know that people get them fitted in other vehicals and same principal on Warrenty should apply for Safari if it is possible to fit.
2. Suggest some good models and shops in Bangalore where I can get them fitted. I understand that Xenos is favored here but would like recommendation on Model and a competent shop in Bangalore where it can be fitted.
Amit
amitk26 is offline   Reply With Quote
Old 22nd July 2008, 20:03   #2
dkamath's Avatar
Thanked: 116 Times
Hi amitk26, congrats on your purchase!
There's a thread in which Rahulk76 had mentioned about the Minda immobilizer, and which plugged in effortlessly into the Safari LX. You can try getting info on this, possibly from the Minda regional office on JC Road.
dkamath is offline   Reply With Quote
Old 22nd July 2008, 20:33   #3
condor's Avatar
Thanked: 4,895 Times
Engine immobilizer is standard on the EX & VX. Since you have a LX, check with Minda if it can be retrofitted into the LX. Tata uses Minda remote locks & immobilizer is integrated into these.
condor is online now   (1) Thanks Reply With Quote
Old 23rd July 2008, 11:43   #4
Thanked: 420 Times
Thanks Condor and Dkamath , I will search more on Minda Immobilizer and remote locking.
Old 24th July 2008, 11:07   #5
Thanked: 420 Times
Condor,
I tried the Minda Service Engineer mobile number you PMed phone was picked by a Kannada speaking lady and the alternative number she gave was permanently swictehd off , I will look for Minda stuff on JC road.
Amit
Old 27th August 2010, 12:51   #6
Default Tata Safari 2.2 Security system locks after battery change
Hi, I changed the battery of my tata safari 2.2 purchased 2.5 years back, now there was some problem with battery drainage and I called Amaron person and he put in a standby battery, but the moment he connected another battery the siren and security system of the car got activated and there is a lock symbol on the dashboard.
We tried different combination's to turn off the alarm but no success, called Tata people and they say to contact Minda as they can reset the lock, I am sure this must be a common issue or will come to all the new safari owners when changing the battery outside of Tata showroom.
I asked a Tata person and he told me to remove the Siren relay, connect the battery (which turns on the blinker lights in solid state) and then sit inside the car, lock all the doors and then press unlock button repeatedly, but of no use.
Can anyone suggest how to reset the alarm or a solution to this issue?
Thanks in advance.
Alind is offline   Reply With Quote
Old 27th August 2010, 13:05   #7
tsk1979's Avatar
Thanked: 16,420 Times
You need to open up your user manual, and look for the secret code. After that follow the instructions on reset unlock
Old 5th December 2016, 16:01   #8
Turbo_Torq's Avatar
Thanked: 67 Times
Default Re: Engine Immobilizer for Safari 2.2 VTT Lx
Sorry to necropost but can this code be found elsewhere than the user manual?
Turbo_Torq is offline   Reply With Quote
Swift DDIS SVS Light turns Off only after engine starts(ECU records immobilizer code) tush Technical Stuff 58 10th November 2014 20:51
Tata Safari 2.2 stolen this morning (DL3C A Y 4878) [immobilizer beaten?!] whatcanthisbe Technical Stuff 78 16th May 2011 19:37
Need Advice: New Safari 2.2 LX VTT or Safari 2008 3.0 Top Model? alexnazim SUVs, MUVs & 4x4s 150 1st December 2009 11:20
Immobilizer - Worth it?? Nimz Modifications & Accessories 46 9th May 2008 21:07
Failing lights and immobilizer in an accent tmanish76 Technical Stuff 7 20th December 2007 15:52
