Old 25th July 2008, 23:14   #1
Default The old FIAT 1100 body with a Palio 1.6 engine
Recently an idea has been poping up in my mind every now and then.
Every time i think about it and discuss it with my friend (and a fellow BHPian), he suggests that this is not possible and asks me to scrap the idea.
What I have in my mind is to buy an old scrap Fiat 1100 and merge it with the Palio 1.6 MPFI engine. If not this, then go for the Palio 1.2 engine.
Before anybody blasts out the possibilities i would like to say that if done and completed, it would not be used for Racing or any sort of stunts.
Keeping in mind the modifications to the Chassis, a bit to the body and maybe a whole new set of axels from the Palio itself (axels only if required) what do the Bhpian's think of this crazy idea.
avi.k is offline   Reply With Quote
Old 26th July 2008, 00:23   #2
pawan's Avatar
only problem you would have is the gear box as the palio is a fwd and the 1100 is a rwd.
i would suggest a baleno engine with a gypsy gear box.
pawan is offline   Reply With Quote
Old 26th July 2008, 00:58   #3
Thanked: 152 Times
Here is a Fiat with a Gypsy Engine and geearbox. Hope it gives you inspiration for the same!!
Cyrus43 is offline   Reply With Quote
Old 28th July 2008, 17:19   #4
vinit.merchant's Avatar
Thanked: 939 Times
The reason for this being that in Palio, most things are electronically controlled, via the ECU. So even though theoritically it might be possible to fit the 1.6 engine into the Fiat 1100, I think practically it is not a very feasible option.
You can go in for some other engine. Like Cyrus suggested, go in for a Gypsy engine. There are other options available as well. Esteem Engine is another one.
vinit.merchant is offline   Reply With Quote
The lovely Premier Padmini S1 (Fiat 1100-D) Ram The Indian Car Scene 393 28th May 2018 15:40
A Fiat 500 Abarth made from human body & body paint dharmeshmahajan The International Automotive Scene 5 25th October 2013 14:47
1978 - Fiat 1100 || 2010 - Fiat Grande Punto Emotion MJD! Sujith1100 Test-Drives & Initial Ownership Reports 146 25th October 2011 21:53
Problem with replacement FIAT Palio body panels Rahulkool Technical Stuff 6 11th November 2008 11:21
Banglore grave keepers R selling body & body parts _Crazi4Speed_ Shifting gears 0 1st October 2004 03:16
