Old 28th July 2008, 15:13   #16
watashi75's Avatar
Thanked: 7 Times
Do I need to install an LPG kit in my car for cooking?
watashi75 is offline   Reply With Quote
Old 28th July 2008, 15:14   #17
sbasak's Avatar
I've often placed my food over an aluminum foil and put it over the bonnet after a long journey to make it warm before eating. It does serve the purpose.
I also tried boiling eggs on engine heat but failed. Heat over the bonnet is not enough to boil egg. For that I had to put it directly over the engine and as soon as I opened the bonnet, engine became cool quickly before boiling the egg
Of course, I could have tried by running the engine while boiling, but decided it's not worth of burning petrol for boiling eggs!
Theoretically it will always be possible. It is same as cooking in a kerosene stove. However, engine is designed to contain the flame inside rather than outside so it will not be efficient compared to cooking in stove/gas.
sbasak is offline   Reply With Quote
Old 28th July 2008, 17:26   #18
An equally weird idea. can we have a mini windmill on top of the car that can charge the car battery?
suvi is offline   Reply With Quote
Old 28th July 2008, 18:36   #19
Thanked: 235 Times
I guess if you remove the cylinder head, you can do some deep fries too.
To make a bulls-eye, place the egg carefully in the exhaust, start the car and wait with your plate at a distance.
Torqy is offline   Reply With Quote
Old 28th July 2008, 19:16   #20
vivekiny2k's Avatar
Thanked: 163 Times
Originally Posted by SuperSyn View Post
PS: I am speculating here, but you must be a product of IIT-Delhi, right? Currently working with Mahindra or Tata, perhaps?
talking of utility, i used my cars dash (facing sun) to dry my son't pants that he wet on a slide, it had rained previous day. didn't take more than 15 mins. the area under the glass is very hot and can easily be used to heat MTR type packed food.
in cold countries we are content with using the heat to heat the car compartment.
vivekiny2k is offline   Reply With Quote
Old 28th July 2008, 19:19   #21
sbasak's Avatar
Not weird In many commercial airliners, if generator fails, they have small windmill like device on wings, which rotate on flow of air and generates enough electricity to power the crucial components of aircraft.
Old 28th July 2008, 21:22   #22
Mpower's Avatar
Thanked: 1,682 Times
I'd like to warm my coffee when I drive to work in the morning. Its always cools down and then tastes bad.
Old 29th July 2008, 01:08   #23
abhik's Avatar
Originally Posted by gd1418 View Post
While applauding this 'genius' thought in this era of global warming, my "scientific" mind wandered to the results of the cooker ovrturning inside the engine compartment or the number of whistles the cooker would give out to indicate the completion of cooking and last but not the least, will the extreme heat radiated will have any harmful effects..
What if the car has a turbo? Then woul'nt it be a problem as one can confuse the BOV with the pressure cooker whistle????
abhik is offline   Reply With Quote
Old 29th July 2008, 05:27   #24
Rehaan's Avatar
Thanked: 22,610 Times
Originally Posted by speedzak View Post
..."Dude! I stepped too much on gas last night and the chapattis got burnt"....
Hillarious Zak.
Maybe something more conventional then > Lillian Vernon: Plug-In Commuter's Warming/Cooling Mug
or
12 Volt Can Cooler And Warmer, Automotive at old-fashioned-values.com
cya
R
Old 29th July 2008, 07:59   #25
It has been a very interesting topic for the past two days. Thanks to every one, I do'nt think the present car can be modified to cook or fry. This may require newly designed car which can fit a cooker or a heating vessel.
BTW I am just a science graduate with passion to science and technology.
-Deva
deva kuduvalli is offline   Reply With Quote
Old 5th August 2008, 21:19   #26
drjanakpatel's Avatar
Thanked: 31 Times
certainly we can make omlette. put an aluminium foil on heated engine and then make omlette on it. could be useful in the middle of nowhere. but there also u require eggs.
drjanakpatel is offline   Reply With Quote
Old 9th August 2008, 16:56   #27
hell boy's Avatar
LOL i have a car which have enough space in the engine bay to cook rice,tea ,eggs etc (my contessa) will try it with eggs for sure..
hell boy is offline   Reply With Quote
Old 16th January 2010, 20:57   #28
Rehaan's Avatar
Bumping an old thread with a fairly unique product :
Exhaust Burger! - Stick it in the exhaust pipe...
Source : exhaust burger - designboom
cya
R
Old 16th January 2010, 23:22   #29
pranavt's Avatar
Thanked: 272 Times
Yeah, with extra cheese and carbon monoxide. Burgers never tasted better. Don't expect anyone else to eat it either
Oh, and in a country where every 3rd speed bump causes the exhaust and underbody to rub. You will drop your burger on the road long before this contraption serves its purpose.
Tim Cook betrays his ignorance, says `Europe' is a term made up by Americans vasudeva Shifting gears 14 12th February 2014 12:46
The heat is on, way too on! Car overheating at low RPM sankidude Technical Stuff 3 8th January 2012 11:31
Insulating car from external heat harry2223 Technical Stuff 12 21st June 2009 12:01
Are You A Good Cook ? narayan Shifting gears 1 3rd February 2009 19:22
