Old 8th March 2005, 01:37   #1
Question Need Help! - E-zen
Hi guys. this is for the gurus.
i have just bought a esteem engine , want to fit it a zen. need some advice. 1) are all three mountings same. 2) is the zen gear box housing direct fit to the esteem engine. 3) will the zen carb work on the 1.3 engine.4) what about the clutch plate and pressure
plate.
superpower is offline   Reply With Quote
Old 8th March 2005, 06:49   #2
Vulken Auto's Avatar
Thanked: 87 Times
Thumbs up
i have just bought a esteem engine , want to fit it a zen. .
how much did you get it for??
contact ICEMAN !!!!!!! Hes good with zens,.... balenos
Vulken Auto is online now   Reply With Quote
Old 8th March 2005, 09:59   #3
iceman91's Avatar
Thanked: 22 Times
yes it is east to fit into a zen. teh gearbox too is a straight match. the carb of a zen will be too small for the engine, you can use it but teh performance wil no be upto the mark. use the esteem manifold and carb. better option.
iceman91 is offline   Reply With Quote
Old 9th March 2005, 00:02   #4
hey iceman ,
thanx a lot for the quick reply. i will buy a esteem carb . do you think putting a four valve head of the MPFi esteem is a better option. the intake manifold can be made for the esteem carb. what about the exhaust.
Is the MPFI head of the esteem and zen identical.
Old 9th March 2005, 11:28   #5
iceman91's Avatar
Thanked: 22 Times
yes the heads are identical except the valve sizes and little bit of the flow design. also a 16valve on a carb bottom requires quite a bit of work..do you think your mechanic is capable of handling it. also the head has different ports so teh inlet and exhaust manifolds will be different.
Need help with my Zen predator Technical Stuff 32 4th July 2013 22:21
Need ur help guys for zen mods !! SiMoN Modifications & Accessories 1 3rd October 2006 20:49
hey...im new, im lost and i need help with my zen!!! ghostrider4385 Technical Stuff 36 22nd December 2005 15:15
Need Help To Upgrade Zen Music Sys... greddy In-Car Entertainment 1 29th April 2005 13:53
Finding an Aluminum spoiler for a Zen - Need help vance0712 Modifications & Accessories 3 21st January 2005 14:18
