Old 14th July 2008, 12:46   #16
sanjaymugur's Avatar
Thanked: 53 Times
Originally Posted by ms001 View Post
thanks for the information Sanjay , will check it out , i have a R 1 5 , every 3-4 washes the chains get dry and makes disturbing noises,caus its open.
you need to apply the cleaner before the wash, spray the cleaner on chain & leave it for 10 -15 mins.. then water wash & allow the chain to dry & then apply chain lube.. i think this is the right procedure.. correct me if i am wrong..
gladiator RS also has similar chain to R 1 5...
sanjaymugur is offline   Reply With Quote
Old 14th July 2008, 12:57   #17
ms001's Avatar
Thanked: 63 Times
yes this seems to be the correct procedure,
i did not find cherry automobiles on just dial..
ms001 is offline   Reply With Quote
Old 14th July 2008, 17:52   #18
Thanked: 53 Times
Rajesh Agrawal/Bp Sharma
+(91)-(80)-26676876,26676379,41114243
+(91)-9972577110,9844142944
+(91)-(80)-41312147
tyres@cherryagencies.com
otr@cherryagencies.com
No.115, Nxt To Nandini Hotel,nr Minerva Circle, Lalbagh Fort Road, Bangalore - 560004
Old 14th July 2008, 17:59   #19
hyper123's Avatar
i got motul chain cleaner & chain lube for my YAMAHA gladiator RS... all imported pack.. they are really good...
How much did you pay for the cleaner and lube?
hyper123 is offline   Reply With Quote
Old 14th July 2008, 18:06   #20
Thanked: 53 Times
motul chain cleaner + motul chain lube = Rs.840/-
Old 15th July 2008, 12:45   #21
ms001's Avatar
Thanked: 63 Times
thanks for teh information Sanjay i contated then it is avalilable Rs 800+
,will try to collect it on the weekend
Mod's Note: Do not quote the whole post unnecessarily when all you want to say is Thank you. Quote removed.
Old 19th November 2008, 17:54   #22
zerocritical's Avatar
I got Shell Helix Ultra 5w40 fo my swift petrol. Now wondering if this one suits it because company recomends 15w40(if i am not mistaken). Can some one pls confirm.
BTW I got it for 2700 for 4ltrs.
Also is there an Expiry date for these synthetic engine oils?
zerocritical is offline   Reply With Quote
Old 19th November 2008, 18:51   #23
vikram_d's Avatar
Thanked: 940 Times
5w40 works fine on the swift. No need to worry. I used it a couple of times on my car.
Old 19th November 2008, 21:27   #24
gd1418's Avatar
Thanked: 656 Times
Does the temperature drop as much to necessitate 5W40? This grade of oil is meant for cooler chimes at higher altitudes. 15W40 would work perfectly fine for you. Have you tried Mobil 1?
Old 19th November 2008, 22:45   #25
Temp doesnt drop so much but i do go to hill stations often.. the dealer recommended me this one.. I havent tried Mobil1 as yet but will surely try in the next service..
Can some1 pls tell me if there's an expiry for synthetic oils... I have about 1.5 liters left when i used in my skoda about 3 yrs back..
Old 19th November 2008, 23:32   #26
vikram_d's Avatar
Thanked: 940 Times
GD sir the problem is that Shell ultra helix 15w40 is not available easily. Everywhere in Bangalore I have seen only 5w40.
Old 19th November 2008, 23:36   #27
Swifty2008's Avatar
For my Swift Petrol, Mobil 1 support recommended 0w40.
Swifty2008 is offline   Reply With Quote
Old 24th June 2009, 11:39   #28
Sportsmind's Avatar
Thanked: 28 Times
Wink Moving to Mobil1 ful syn
I was planning to move to fully synthetic engine oil on my next service. From the various forums on this topic, the recommeded one by most bhpians seems to be mobil1. Now i also understand an engine flush is essential when i do this change over. Could someone suggest the best place in Blore where i can get a proper flush, with the use of right lubs and then move to mobil1. half the guys dont even know what the engine flush is here. suggest, and also what will be cost for the whole stuff with mobil1.
Sportsmind is offline   Reply With Quote
Old 24th June 2009, 11:58   #29
mahadev_kc's Avatar
Thanked: 25 Times
If you need Selenia, you can goto Concorde Motors, Mysore Road, service centre and buy the same.
They have Selenia Motor K 5W40 Fully synthitic oil. It is available in 5lts can and I think in 1lts can too (though I'm not sure).
I bought 5lts can for 2200/- and I guess for a 1ltr bottle it may cost around 550/-
This synthetic oil is being used in FIAT Linea Petrol.
mahadev_kc is offline   Reply With Quote
Old 29th September 2009, 13:03   #30
shock's Avatar
Hi Friends,
I called up a shop in JC road and they were quoting 850 rs/litre for Mobil 1. Is that a right price? Please PM me with contact details from where I can get Mobil1 in Bangalore. I am very much afraid about the fake products. So send me any contacts you personally know or is trust worthy.
Many Thanks
shock is offline   Reply With Quote
ARTICLE: Synthetic oil vs Mineral oil GTO On modifying a car 4885 17th July 2018 23:34
Where to buy Mobil1 / Castrol Synthetic Oil in Mumbai? Max Shifting gears 27 14th June 2015 23:41
Where can I get 10W40 Synthetic oil for a Ducati 749 in Hyderabad or Bangalore Scooby STi Superbikes & Imports 6 24th April 2009 19:21
Oil change..Synthetic, where to source DRC Technical Stuff 21 2nd December 2007 15:00
Synthetic Oil karthik247 Technical Stuff 10 8th November 2005 18:02
