Old 15th March 2005, 11:36   #1
arjab's Avatar
Thanked: 1,198 Times
Default Rear Discs on Zen
seeking advise on how to fit rear discs to the Zen....will the Esteem one's go ? How to modify the stub axle ?
arjab is offline   Reply With Quote
Old 15th March 2005, 11:51   #2
Harrie's Avatar
Thanked: 20 Times
the zens on kari speed way (the track in coimbatore) use a m-800 disc at the rear if i remember it right. i'll see if i can find out more info about it.
Harrie is offline   Reply With Quote
Old 15th March 2005, 12:25   #3
iceman91's Avatar
Thanked: 22 Times
you can fix the discs at the rear but need some work to be done for your handbrake.
iceman91 is offline   Reply With Quote
Old 15th March 2005, 16:40   #4
aveek's Avatar
Question
Hey, can you do this easily on any car? Or will it prove to be very costly? Was thinking of putting them on the back of my Honda... Iceman, I've seen your car brake from a ditance(other side of the road ) quite quickly. What setup and brakes do you have??
aveek is offline   Reply With Quote
Old 15th March 2005, 16:49   #5
iceman91's Avatar
Thanked: 22 Times
you need to buy the front set of rotors and brake assembly which you can get in the gujri for 6-10k then you need to spend around 4 to 5k on its fitting which dom can do.
my car has good braking??? thats news to me too i find it a little sluggish compared to teh honda...love the way hjonda stops.
Old 15th March 2005, 19:04   #6
aveek's Avatar
The Honda does, but never having driven your car, I wouldn't know really... hehe... it did loook pretty neat when your car braked tho...
would ddom also be able to source a good set of brakes, or would I have to do that seperately? cause I'd prefer it if I knew that the brakes were of good quality an all...
Old 16th March 2005, 10:06   #7
iceman91's Avatar
Thanked: 22 Times
yeah you can come to dom or me any time. it will all be taken care of and given to you in proper working condition.
give me a call some time and you can check the baleno out.
i use my gears as well while braking gives me a better control...at teh cost of my clutch..but am runnign a performance clutch so it kinda covers it.
Why drums in rear and discs in front ? abhaybakshi Technical Stuff 25 20th August 2017 16:40
Swift - Wheel Discs and Brake Pad problems ravi23 Technical Stuff 25 18th August 2010 15:07
DTS Sampler discs... anyone? kvish Gadgets, Computers & Software 7 9th April 2007 10:37
Are Cross Drilled / Slotted Brake Discs Available For A Esteem ?? Tool Modifications & Accessories 2 27th December 2006 02:38
BLU RAy discs Shrikar Gadgets, Computers & Software 7 14th June 2005 12:17
