Old 2nd May 2005, 13:18   #31
jesal's Avatar
Originally Posted by Sahil
This push button start things is pretty slick. I wanna get it put in my accord as it has two cigratte lighters too and I can get the orignal honda start red button from the handa website. But the only drawback is that no more valet parking coz those fools wont know how to start the car. Also need to find a good professional to do this for me, dont trust everyone with my accord.
u can still keep the original start pattern as well. push buttoon will be the other option not the main one. i have got a cheap button have to hook it some soon sometime now
jesal is offline   Reply With Quote
Old 2nd May 2005, 13:26   #32
Sahil's Avatar
Thanked: 2,718 Times
So basically u have the option of turning the key once which activates the button light and then using the button to start or turn the key twice and the car starts like before?
Do let me know how your think works out jesal so that i can order my honda button asap and get it back to bombay.
Old 2nd May 2005, 23:17   #33
jesal's Avatar
its to be used normally. once when the acc mode is there and then the second turn. after that u either press the button or start it manually. how much is the button for there on handa. check out this brand called longacre kick ass switches they have,
Old 3rd May 2005, 01:38   #34
Sahil's Avatar
The switch is for 40$ from the handa website. Checked out the langacre switches, they are good but i still prefer the honda one, its simple and sporty...fits the bill well.
Old 25th June 2005, 01:40   #35
revtech's Avatar
Thanked: 35 Times
hey jesal
any news on the button start.did you finally get it done or not.and sahil what about you ??
Rev
revtech is offline   Reply With Quote
Old 7th October 2005, 00:26   #36
Thanked: 11 Times
Default Where Can I Find It ?
Hello Everybody,
After Going Through PSYCHO'S Engine Start Button Guide, I Am Definately Going For One.
So I Want To Buy Red Engine Start Button Switch.
Can Any One Help Me?
Where Can i Buy It?
Address And Phone Number Will Be A Great Help.
Thx In Advance
Mugen_Power
Mugen_Power is offline   Reply With Quote
Old 5th August 2008, 14:38   #37
vinayvtec's Avatar
Thanked: 9 Times
Question Wanted some inputs on the push button ignition.
Hi Team, please help me in understanding the push button ignition, I have seen most of the racing cars with this type of ignition.
1. I want to know how much it would cost.
2. Will it harm the car engine or cause of any electrical issue.
3. What are the advantage and disadvantages of this type of ignition.
vinayvtec is offline   Reply With Quote
Old 5th August 2008, 17:17   #38
Thanked: 103,675 Times
Probably Rs.200 for the cheapest one, and then upward depending on brand. My Jeep had one temporarily fitted (cheap one). I can tell you that it was fun to use
Nothing to do with the engine. No problem with the electricals either, as long as it is properly installed.
Looks and wow factor. Thats it. First car I drove that had the engine start button was the S2000. Sitting with your legs stretched flat, small steering wheel, short throw 6 speed and that red button staring in your face was really something else.
Old 5th August 2008, 17:18   #39
greenhorn's Avatar
Thanked: 1,519 Times
Disadvantages: (obviously) Possible loss of electrical warranty ?
Old 5th August 2008, 17:54   #40
Srini76's Avatar
Thanked: 70 Times
Is it a straight forward install GTO ? and if anybody could tell me where i can source on in India it might be of interest , I am interested in the WOW factor !!! and if the switched is in "ON" position can the car be push started (Low Battery Scenario) ? Logically it should be but i prefer to know from the experts in the forum !!
Srini76 is offline   Reply With Quote
Old 5th August 2008, 18:01   #41
abhinav.gupta88's Avatar
Thanked: 310 Times
Where can you get one?
Old 5th August 2008, 20:53   #42
iceman91's Avatar
Thanked: 22 Times
You get branded ones starting at 4k. I had one installed years ago was a branded one...dont remember the brand though..
Any electrician can install it. need some splicing to be done to the ignition key unit. Have the option of using the key as well as the button or just the button or you need the key to switch it on then use the button to start the engine..
iceman91 is offline   Reply With Quote
Old 5th August 2008, 21:13   #43
Vid6639's Avatar
Thanked: 21,086 Times
If you ask Sideways, Ishan, Ford Rocam and Sam, they will advise never to put that on. It gave so many problems in the JBL swifts. The check engine light kept coming on and the push start would not work after that.
Old 5th August 2008, 21:21   #44
iraghava's Avatar
Thanked: 156 Times
Yup, it was a pain in the backside on YetiOne when we drove it to Bombay & later on too. At times it would simply refuse to function & we would either have to push start the car or disconnect the battery & reset the ECU to get it started again.
I wouldn't get one if I were you.
Old 5th August 2008, 21:56   #45
Thad E Ginathom's Avatar
Thanked: 8,377 Times
It's only a switch, so whether it is placed on the key or separately is not going to make any difference, in principle.
When I was a child, all cars had separate starter switches (Err... they also carried starting handles, for when the battery failed!).
Then it became so much smarter and more modern to combine the switch into the ignition. Now people are thinking its groovy to have a switch!
My doubt would be security. You could be screwing up any immobiliser fitted by messing around with the starter/ignition switching. You might render the car easier to steal --- or possibly not able to start ever again!!!
Niken Gear Knob With engine start button? swarnava.m Modifications & Accessories 3 25th May 2012 15:07
Swift VXI : Flat battery. Push start didn't work? amitk2kin Technical Stuff 29 28th May 2011 14:33
Button start and Horn problem amtak Motorbikes 3 23rd August 2010 12:20
Use of Push Button Starter mithun Technical Stuff 33 8th December 2007 23:45
