Old 20th June 2012, 23:20   #106
aoussie's Avatar
Default Re: Push Button Start / Ignition
Originally Posted by k_shanz View Post
Just got my ignition start button today. The kit contains a toggle switch and a press button with red light in it. In my kit i have to turn key by one step and the rest did on the toggle switch and button. When i hold the button the light on it burns. To stop the engine i have to close the toggle switch flap. It look so special, i always had a dream of such kind of startup kit. Fix it and enjoy.
can you please tell me where did you purchase the kit from.
thanx.
aoussie is offline   Reply With Quote
Old 26th June 2012, 02:06   #107
k_shanz's Avatar
Thanked: 64 Times
thanx.
I brought it from Coimbatore. I think its more than 3 years now so don`t remember the exact price. Guess its under 2.5k.
If you want one search it online, they can be cheaper i believe.
k_shanz is offline   (1) Thanks Reply With Quote
Old 2nd July 2012, 22:44   #108
quadra's Avatar
Thanked: 58 Times
Here is a DIY video on youtube for this
quadra is offline   (2) Thanks Reply With Quote
Old 4th July 2012, 20:27   #109
aoussie's Avatar
Thank you for the link.
but i am looking for the wiring diagram for indica. which i have not found on the net. service centre isn't helping and nor are the local guys. dead end.
can anyone please guide as to where i can get the wiring diagram for the indica.
Old 6th July 2012, 16:59   #110
scopriobharath's Avatar
Thanked: 1,259 Times
You will definetly NOT get car specific diagrams. It is almost practically impossible to draw the parent wiring diagram and then an insert on how to wire this system for every car model available.
So a workaround for this is to use the "logic" behind a push button starter. I do not have a diagram but if you can explain this logic to any auto electrician, he would be able to help.
Ask the electrician to:
  • Open the steering console and find the ignition key assembly. It contains numerous wires and two of them lead to the starter motor (Electrician can identify it).
  • Splice those wires (will void warranty) and take a "parallel connection" from those wires and connect them to the push start button module.
  • Affix the module at some convenient location and Voila you are done.
Its simple and straightforward, but if the job is done haphazardly, it might lead to a short circuit. Ensure the splicing is well insulated.
scopriobharath is offline   (2) Thanks Reply With Quote
Old 6th December 2012, 11:48   #111
searchingheaven's Avatar
Thanked: 1,365 Times
Originally Posted by knp View Post
I think that it's overpriced. You can get a similar or even a better one for 500/- from Dealextreme.
DealExtreme: $11.99 Blue Indicator Light Engine Push-Start Button Set for Auto-Refitting (DC 12V)
Does dealextreme ship to India? If yes, what about import duties and other costs? Did you install the product in your car?
searchingheaven is offline   Reply With Quote
Old 28th January 2013, 21:38   #112
aoussie's Avatar
thank you so much for the reply. sorry for the delayed response. i did try what you said and the electrician blew the fuse box. not very sure about trying it without a wiring diagram. so am going to try and get a proper diagram. thank you so much.
Old 28th January 2013, 22:05   #113
Nope - Dealextreme do not ship to india. YOu get similar products in india itself. It is not worth buying from USA.
Nope - i did not install on my Santro as i am skeptical about cutting wires. . Couple of dealers told me they might need to splice the wires, which put me off.
scopriobharath is offline   Reply With Quote
Old 28th July 2013, 10:36   #114
Thanked: 32 Times
@scoprioBharath & @searchingHeaven
DealExtreme definitely ships to India, I have ordered plenty of stuff from them ranging from crazy cheap stuff like keychains to high end electronic stuff too. I have received each and every one of them, there are delays sometimes but have got all products within 30 days.
I ordered this product "Start Button Red" Similar to the one used in the MightCarMod's Video.
Order was placed on 6/7/2013 & i got it on 27/7/2013 no custom duty or anything, most of the time it clears without you being charged for it but if its something costly that you might get the attention from the custom duty department.
Anyways now back to the topic, I have a 2010 Maruti Suzuki SX4 on which i want to install this start button, any idea's on how to get it done? my mechanic shop guy said he has never done it before so I need to find someone with experience.
The concept seems simple as the Ignition switch is just a 3 way switch but finding the correct wires would be difficult.
dreamz_mak is offline   Reply With Quote
Old 28th July 2013, 12:18   #115
latentpotential's Avatar
Thanked: 380 Times
For 250 Rs you should be able to get the parts and assembly catalog at a large service center of Maruti. If you are a regular, you may just borrow it and xerox out the relevant pages instead.
In my case, I was asked to avoid the push button start on my Swift since the car has Airbags, and they are not sure if it can 'interfere' in any manner with the modification in terms of electronics. While I took it with a pinch of salt of course, I never went for the mod, considering the safety feature is more important than something which is just a novelty, and often goes away after some time.
latentpotential is offline   Reply With Quote
Niken Gear Knob With engine start button? swarnava.m Modifications & Accessories 3 25th May 2012 15:07
Swift VXI : Flat battery. Push start didn't work? amitk2kin Technical Stuff 29 28th May 2011 14:33
Button start and Horn problem amtak Motorbikes 3 23rd August 2010 12:20
Use of Push Button Starter mithun Technical Stuff 33 8th December 2007 23:45
