| LinkBack | Thread Tools | Search this Thread |
| | #1 |
| BHPian Join Date: Apr 2007 Location: Cochin
| helooo, >Is it possible to fit a power steering unit in a maruti gypsy/gypsy king? >can maruti esteem's power steering unit be used? >is it a difficult task? / will this conversion be trouble free? >how much will it cost approximately? i found that someone had mentioned in another gypsy thread that some of the gypsy's came with factory fitted air conditioner. can someone clarify this? thank you. |
| | #2 |
| Senior - BHPian | Already being discussed elsewhere. yes can be done Costs you anywhere from 10k-20k depending on the source for parts and labour. Nothing in life is risk free or trouble free, depends on ones definition of "trouble" and "difficult" ![]() |
| | #3 |
| Senior - BHPian | Yes, it could be converted to PS. Here is a power steering setup pictures of Gypsy using the Koyo unit (made in Japan). I found this Gypsy in my mechanic's garage, I guess the total cost should not be above 20K. |
| | #4 |
| Newbie Join Date: Sep 2008 Location: krishnagiri
| yes it is possible to fix power steering in gypsy.try going in for Suzuki jimny's P.S kit it will be a good fit for gypsy.further it is not possible to fix esteem's P.S kit as it is rack and pinion. |
| | #5 | ||
| BHPian Join Date: Feb 2005 Location: Trivandrum
Thanked: 9 Times
| Quote:
If you want to use indigenous components, go for TATA sierra's unit. Steering will be feather light. | ||
| | #6 | |
| BHPian Join Date: Apr 2009 Location: Delhi
| Quote:
Very helpful info. Have been considering buying the new MPFI engine Gypsy but lack of AC and power steering was bothering me. Any idea where the Jimny steering box is available (in or around Delhi?) and mechanics who do a good job fixing it? Why do you say keep oil pump handy? Is Tata Sierra unit still available and does it fit well on Gypsy? Would love to hear experiences of people who have fitted PS and whether it is working fine (+ does it void your manufacturer's warranty?) Thanks | |
| | #7 |
| Newbie Join Date: Apr 2007 Location: Mysore
| Can any one suggest me about auto garage in Bangalore, Coimbatore or around who could help me out for power steering fitment to my Tata Spacio? |
| | #8 |
| BANNED Join Date: May 2008 Location: Nagpur
Thanked: 144 Times
| Hi All I have done a hydraulic power steering conversion of my of the two gypsies that I purchased from the Army. The modification was executed in Nagpur and the parts were sourced from Delhi. Post fitting, I have driven the gypsy for around 400 kms and I have come across some issues that I want to discuss with you all. Firstly , at high speeds, the steering is easily movable . It desn't get hard at high speeds. I understand that this is a common occurance with most hydraulic power steering systems, but I wanted to know if there was some way the steering could be made hard at high speeds with my current setup. The next issue which is bothering me is a certain noise which is coming from the steering pump-belt assembly when I am doing a full lock on the left side. Here are some photos and videos to show how I built my power steering setup and some videos which point out to the noise that I am referring to. the third video describes the noise best. Could you go through the videos and let me know what is wrong and what is the solution for this. regards, Dr. Abheek Ghosh P.S : I must thank the person in the last pic for her extreme patience and help with the execution of this mod. Three cheers to you. |
| | #9 | |
| Team-BHP Support ![]() | Hi Abheek, Quote:
| | #10 |
Thanked: 144 Times
| Hi Rush Thanks for your inputs. Tyre changing is on cards very soon. These are the tyres that I got with the vehicle from the Army. Will try out your suggestion regarding recalibrating the mechanism and post a report here soon. What did you think about the noise from the assembly ? I am more concerned about that. Others who have a similar setup in their vehicles kindly help me out. regards, Dr. Abheek Ghosh |
| | #11 |
Thanked: 144 Times
| I spoke to the mechanic who did the initial workup on the 2 gypsies and he is of the opinion that if I reduce the size of the pulley of the steering pump, I should not get the sounds at low rpm . His logic is even at low engine speeds, the small size of the pulley will provide adequate rpm to the steering pump. I am confused by this . Can you help me out here and show me the way. regards, Abheek |
| | #12 |
Thanked: 144 Times
| Pics will say more than words.. Experts kindly comment. regards, Abheek |
| | #13 | ||
| Team-BHP Support ![]() | Quote:
| | #14 |
Thanked: 144 Times
| @mpower Whining noise at full lock in normal in HPS cars. (check other cars to compare noise level) I will certainly take your suggestion and check out the noise levels of other cars @mpower The pump is basically pushing a full load. Just make sure you dont hold it there for too long. If you want you can fabricate a mechanical stop. What do you mean by pump is pushing a full load ? What is a mechanical stop and how can i use it in my setup ? @mpower Reducing dia of pump pulley (driven pulley) will speed up the pump not slow it down. I think you need to go the other way to reduce boost.[/quote] My understanding of the situation is : low engine rpm ---> low Ps pump rpm ----> Less hydraulic fluid being pumped by ps pump ----> stress on the whole ps unit due to less hydraulic fluid being circulated in it ----> some amount of heating happening inside due to this ------> Abnormal noise coming out !!! if i decrease pulley size ----> high pump rpm despite low engine rpm --------> adequate hydraulic being pumped internally irrespective of situation -----> the noise should go away (but whining may increase) (if at all the noise is coming from the pump) Please correct me if i am wrong ![]() Additionally could there be any other source from where this noise may be coming from. One mechanic suggested me to do an overhauling of the suspension and he said that will help. How this will help is the question ? Refer to the video taken under the vehicle . Could the noise be coming from elsewhere ? regards, Abheek |
| | #15 | ||
| BHPian | Quote:
These Koyo units are used one and it seems there is some problem with the PS pump that you have. Why do not you simply procure one more PS pump from Mayapuri and check if the sound has gone. It should not cost you more than 2-2.5 K. Last edited by DesertKing : 23rd July 2009 at 04:29. | ||
Similar Threads | ||||
| Maruti Esteem - Non Power Steering to Power Steering | udit78 | Modifications & Accessories | 14 | 4th May 2011 13:29 |
| PICS : Gypsy with power steering + Airconditioner | wbd8779 | 4x4 Vehicles | 27 | 2nd December 2010 20:31 |
| Power steering to manual steering? | ramzsys | Technical Stuff | 18 | 11th August 2010 23:16 |
| Electric Power Steering Vs. Hydraulic Power Steering | joseph5600 | Technical Stuff | 3 | 19th November 2007 19:56 |
| Please suggest - power windows, power steering from one Esteem to another | pramodkumar | Technical Stuff | 4 | 1st September 2006 09:19 |
