Closed Thread
Old 28th February 2009, 20:48   #151
abhik's Avatar
The cost of these dampers and coilovers is so high, which is the same reason i too am refraining from it for some time due to lack of Vit M.
I was thinking if only the springs could be stiffened or we could get just stiffened springs to go over the stock shock absorber to improve the OHC's handling. Do any of the above companies make just stiffer springs to go over stock shock absorbers with minimal height difference? should work out to be cheaper aswell.
abhik is offline
Old 1st March 2009, 02:04   #152
ananthkamath's Avatar
Thanked: 63 Times
Stiffer spring + stock damper = FAIL. If you want a bouncy springy ride with crappy handling then its the way to go.
For the street a stock-like spring rate and appropriate damping is what would work. From the sound of it this is a huge hole in the market.
What say MPower----??
ananthkamath is offline
Old 1st March 2009, 09:44   #153
navpreet318's Avatar
Thanked: 894 Times
What about koni FSD.I personally haven't experienced them but have heard from a few sources that they are very comfortable shocks.
Could someone who has used it throw some light on the koni FSDs.
navpreet318 is offline
Old 1st March 2009, 12:28   #154
nitrous's Avatar
Thanked: 285 Times
OT:
Originally Posted by rippergeo
I heard about the used HKS set. for some one like me who thinks konis are expensive... the 90k for a used set of HKS sunds like a cruel joke.
I have not heard good things about D2 racing.
This is exactly what I mean by "no demand".
Suspension systems cost! I believe Koni inserts are absolute VFM.
nitrous is offline
Old 1st March 2009, 19:11   #155
v1p3r's Avatar
Thanked: 27 Times
Bugger somewhere else you've said they are ridiculously priced in India, and only make sense hand-carried from abroad.
Expensive, limited application range, and I don't think they're that hot.
v1p3r is offline
Old 1st March 2009, 19:41   #156
Mpower's Avatar
Thanked: 1,687 Times
yup, stiffer springs w/ stock damper = underdamped..&
stock springs w/ stiffer damper = overdamped...but this gives the sensation of being stiffer overall with good body control and so is used quite commonly.
Imported is expensive, but since labor is cheap what we need is some smart buggers who can take apart a stock shock, add some shims and washers and voila you have a stiffer shock.
Mpower is offline
Old 1st March 2009, 22:53   #157
abhik's Avatar
You got me confused a little here, if the end result is the above statement in bold then is'nt it kind of what we are looking for?
The trouble is where to find such a smart bugger.
Can anybody tell me if the Ikon's damper and sprigns bear any similarity to the OHCs, just had a crazy idea of swapping them according to the set-up. I mean i am sort of desparate here. OHC with 195/55 R15(i know its a wrong upsize it should be 50 profile) is still pathetic, so much so that i am scared to take it beyond 100kmph narrowly escaped two freak accidents, whereas Ikon with stock tyres and rims was a beauty even at 175kmph, so confident and poised no swaying drama at all, the Honda as compared is a drama queen.
Sorry! to hi-jack Crazy Diablo's thread but i hope you guys relate and understand my desparation if anybody has ever bothered to compare Ikon's and OHC's handling. Plus i thought its a related discussion so might help CrazyDiablo and others too.
And talking about spring rate here as Ananth put it "For the street a stock-like spring rate and appropriate damping is what would work."
Does'nt spring rate differ with every car? So if the stock spring rate is too soft how would damping help? And for dampers we are mainly looking at rebound so if the stock dampers have a slower rebound then would'nt the car bounce around less with stiffer springs?
abhik is offline
Old 2nd March 2009, 09:10   #158
crazydiablo's Avatar
Thanked: 21 Times
Thanks guys, this suspension talk might help me also. But for most of us the decision is decided by our wallets. I cannot spend more on suspension than I have spend for the mods.
Nitrous: Absolutely agree,if you dont have a way of putting down that power, then the whole exercise is useless. Koni as you suggested is the only good VFM option.
Thanks Ironwolf, Clutch is doing very well. Brake I need to test if for some more time to come to a good conclusion. Initial feel is very good, infact too good.
Anant: You are spot on. Oh I could not agree more.
Navpreet: FSD are not avalable for small indian cars like mine.
crazydiablo is offline
Old 2nd March 2009, 10:13   #159
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
Originally Posted by vikram_d View Post
You have paid a higher price for it. I bought it for 7k. It has done about 10k kms on my car now.
Originally Posted by iceman91 View Post
yes 10.5k is a bit tooo much.
also the brake pads.
Hhhmmm. Now we all know whom to go to to get our clutches from . Vikram, Vasu anna says your clutch is not the same one as Mohit's, perhaps you should check once with him.
Amit, I was told the stage 1 clutch has 4 springs (the earlier one I had in my car) and this one with the 6 springs is the stage 2?
Mohit, so when we heading out for a drive?
mclaren1885 is offline
Old 2nd March 2009, 10:41   #160
iceman91's Avatar
Thanked: 22 Times
I dont think the number of springs differentiates the stages.
iceman91 is offline
Old 2nd March 2009, 11:14   #161
vikram_d's Avatar
Thanked: 940 Times
It is the same clutch. The pricing might be varying because I bought it 4 months back.
vikram_d is offline
Old 2nd March 2009, 16:21   #162
Thanked: 894 Times
Mohith I faintly Ron posting a review of a Koni FSD equipped esteem.He said he really liked it.soft on normal driving and stiffer as turns progress.
if they're available for the esteem,they should be for the baleno as well.
Old 2nd March 2009, 20:25   #163
Ricky_63's Avatar
Thanked: 394 Times
Question
Don't even dream about coilovers for street/highway use. They're bloody stiff.
Infact, come watch the races and you can find these cars jumping over the tiny undulations on the race track.
Surprisingly here in the North. Coilovers are considered a "statement" I think. People use them for street use. But from what you say, it seems like it is a total waste
Ricky_63 is offline
Old 2nd March 2009, 20:32   #164
v1p3r's Avatar
Thanked: 27 Times
Coilovers offer you the added advantage of ride height control, which is why they're considered a 'statement'. I have yet to see a stock car that necessitates the use of coilovers on street when regular inserts or damper+spring combos are available.
v1p3r is offline
Old 3rd March 2009, 09:35   #165
Ricky_63's Avatar
Thanked: 394 Times
Agree with what you say. But the "added advantage" of height adjustment ?? Never ever seen or heard anyone adjusting ride height.
Cheer
Ricky_63 is offline
Closed Thread
Engineering Students build India's 1st Solar-Powered Vehicle S2!!! Technical Stuff 0 9th July 2014 16:42
Latest RDDreams RD350 shibu Motorbikes 38 25th July 2013 12:32
The Frankenbike Build: My Honda CBR 600 F3 Build-Off ap10046 Superbikes & Imports 16 16th July 2013 14:26
My T-RX - Street Build from RX135 (Update & Pics on Pg.2) furioussphinx Motorbikes 37 23rd July 2010 09:39
