Closed Thread
Old 6th March 2009, 12:58   #181
Jaggu's Avatar
Thanked: 7,461 Times
Originally Posted by crazydiablo View Post
No I am not going in for DMS, just looking at things. I dont even have that kinda budget for the suspension.
Jaggu, tom is very happy with the DMS, as he has posted recently.
I would probably looking at local options or at the max Konis. Konis Sports are retailing at around 32K plus installation.
Tom doesnt drive the car on roads so he is happy, on tarmac regular usage the sailing is choppy that it will hurt
Your choice is good.
Jaggu is offline
Old 9th March 2009, 22:07   #182
crazydiablo's Avatar
Thanked: 21 Times
Local options are not turning up anything fruitful. Nobody can guarantee, how hard the new setup is going to be. There is no guarantee on how long it will last. The costs are not that cheap either. Another that bugs is that the Baleno shocks are gas charged.
crazydiablo is offline
Old 10th March 2009, 01:25   #183
v1p3r's Avatar
Thanked: 26 Times
Most higher-end Indian cars have gas-charged fronts, if not all 4. Local options almost always involve draining the gas, revalving the dampers and using oil instead.
v1p3r is offline
Old 10th March 2009, 01:32   #184
theMAG's Avatar
Thanked: 1,470 Times
You're going through the same discovery Riju went through when he was looking for stiffer suspension options. You both could share notes.
theMAG is offline
Old 10th March 2009, 01:43   #185
binz's Avatar
Thanked: 411 Times
Mohit, why don't you get a strut brace fabricated along with the brace that is mounted underneath the front suspension(Sorry i dont remember what its called) .. Its supposed to make a notable difference during turn ins etc .. Its not going to cost a bomb.Why don't you give it a shot?
Edit:Ill be getting it made as soon as im done with my boards.
binz is offline
Old 10th March 2009, 03:32   #186
abhik's Avatar
That underside strut you are referring to is called as a "Sway Bar". But does it really help having a strut brace and a sway bar together, i mean for street use we are just looking at controlled bodyroll i.e lesser lateral movement and stiffer suspensions to control up-down or pitch and yaw(more apt for aeronautics but dont we like to fly low.)
With a strut brace and sway bar the handling will be suitable for track use and i doubt two of them together would really make a difference.
Plus i have also heard that sway bars are difficult to fit on most available Indian car models. So thats why strut braces are an easier option. Automech i believe sells them for INR 2300 a piece.
BTW where are you going to get them made from maybe i and others can order through you.
abhik is offline
Old 10th March 2009, 08:58   #187
raajks's Avatar
Thanked: 117 Times
Ask someone from the Rally circle to pick it up from Methods.
It would be lot cheaper from 32K+.
You can check with Sanjay Agarwal and see if he can help you on this.
raajks is offline
Old 10th March 2009, 10:23   #188
binz's Avatar
Thanked: 411 Times
Ah now I remember,I was recommended only a sway bar, by a baleno veteran.
As far as getting them made,you need the car to be present since the sub-frame needs to be removed,measurements taken etc.
If its a baleno then Id be more than happy to help.
binz is offline
Old 10th March 2009, 13:47   #189
Thanked: 21 Times
@V1p3r: Exactly what I thought. Dont know the quality of revalving or the reliability of the rebuild.
Yeah Mahesh, thats true. I need to talk to him. Actually I have gone through his thread innumerable times and he had come to the coclusion of pedders in the end. However he did not go through the conversion.
Binz, actually that was what was recommended to me and am searching for that also. Actually was looking at the OMP strut brace for Baleno. They have one but am not sure if they have discontinued it or not. Need to check with the OMP dealer in bangalore. As for sway bars, I am in two minds. There are none thats readily available.
Any idea what metal is used for making the strut brace and the sway bar. Is the strut brace adjustable. How do you ensure that the new sway bar is more stiffer than the old one?
Old 11th March 2009, 01:58   #190
ananthkamath's Avatar
Thanked: 46 Times
For the record, a sway bar is the american term for anti-roll bar. Its a torsion spring that typically attaches to the lower control arms from left to right, and increases the roll stiffness of the vehicle, thus acting like a stiffer coil spring only when the car rolls.
I'm not sure if that's what binz and abhik are referring to. To me it looked like they were talking about something that stiffens the suspension mounting structure, not the actual suspension itself.
Most indian cars already have an anti-roll bar. If a stiffer bar is available, that's the best way to improve body control in my opinion.
ananthkamath is offline
Old 11th March 2009, 08:43   #191
ScarySkulls's Avatar
Thanked: 19 Times
Mohith, Don't go the thicker anti-roll bar route. If you must, no more than half mm extra in the front. Strut brace is definately a better idea. Keep looking for one.
Did you try PMing Eapen? I notice he's in Bangalore. Why not go and check out his car sometime? Any other cars you checked out?
ScarySkulls is offline
Old 11th March 2009, 12:01   #192
Thanked: 21 Times
Ok before I go the anti-roll bar route, I will get a good strut brace. I have pmed eapen, lets see if he responds.
Old 11th March 2009, 13:07   #193
nitrous's Avatar
Thanked: 282 Times
While I agree that a Strut brace is vital and is another link in the chain, I feel it is very much overrated.
Keep it at the bottom of the upgrade list.
My recommendation for the first upgrade in the handling section: Koni sport yellow(adjustables).
Inserts cost 34k for a set (acc. to Eapen).Add another 2k for getting them onto the strut body.
Set the front and rear at the softest setting and drive the car around.
Based on the feedback, you could harden the rears by a click or two.
Warning: A bad Suspension setup can be very DANGEROUS.
Lift-off oversteer,etc. can just be very unforgiving. So, be cautious wrt the setup.
nitrous is offline
Old 11th March 2009, 13:14   #194
iceman91's Avatar
Thanked: 22 Times
Agree with Nitrous, It is vital but much lower on the list.
In an earlier thread to I have mentioned, I dont have a strut brace and never felt the need for it. The difference is very very minor as compared to other mods that can improve handling.
iceman91 is offline
Old 11th March 2009, 17:15   #195
Thanked: 21 Times
Ok so that does it, strut brace goes down the priority list, and good dampers move up. Not seen many baleno guys run strut brace also, although lots of city guys do run it.
Closed Thread
Engineering Students build India's 1st Solar-Powered Vehicle S2!!! Technical Stuff 0 9th July 2014 16:42
Latest RDDreams RD350 shibu Motorbikes 38 25th July 2013 12:32
The Frankenbike Build: My Honda CBR 600 F3 Build-Off ap10046 Superbikes & Imports 16 16th July 2013 14:26
My T-RX - Street Build from RX135 (Update & Pics on Pg.2) furioussphinx Motorbikes 37 23rd July 2010 09:39
