Old 26th September 2008, 00:34   #16
autopsyche's Avatar
Thanked: 13 Times
Cyrus, Magnaflow doesnt, but Remus and Milltek Sport do make catbacks which are available here.
autopsyche is offline   Reply With Quote
Old 26th September 2008, 04:26   #17
Piper Exhausts make a complete bolt on exhaust system for the skoda vrs which starts from the downpipe,amazing craftsmanship,hope i could help,cheers,happy revving..!
dragger is offline   Reply With Quote
Old 26th September 2008, 13:52   #18
evo
evo's Avatar
Thanked: 23 Times
Since we are on this, whats the real world difference between a catback and the full exhaust?
evo is offline   Reply With Quote
Old 26th September 2008, 14:06   #19
navin's Avatar
Thanked: 3,880 Times
All I would do is ensure that the car is tuned to perfrom like the spec sheet. Even you get 130+ bhp where rubber meets the road you are doing fine.
Old 26th September 2008, 14:52   #20
evo
evo's Avatar
Thanked: 23 Times
@navin: Pls can you elaborate on the "tuned to perform like the spec sheet" bit. thanks.
Old 26th September 2008, 15:10   #21
planet_rocker's Avatar
Thanked: 365 Times
@ evo - i think he meant that the car should be "well tuned" in stock form.
hope you are enjoying the phase 1 remap!!
planet_rocker is offline   Reply With Quote
Old 27th September 2008, 11:29   #22
evo
evo's Avatar
Thanked: 23 Times
Aha, ok.
Yes , the remap is lots of fun, though I have become a bully because of it!
Old 27th September 2008, 12:04   #23
abhik's Avatar
Cat-Back: Removes stock exhaust restrictions after the catalytic converter. In most cases these would namely include the cat-con, mid-muffler and end-can. These can either be removed completely or replaced with high-flow ones, namely bigger dia intermediate pipes, high flow cat-con, high flow mid-muffler and end-can with less restricted fins/meshes/resonators etc.
Marginal increase in performance.
Louder exhaust note.
The headers remain stock.
"Full Exhaust" or Free-Flow Exhaust(FFE): Includes the above plus a re-designed set of headers to increase top-end or low-end or mid-range grunt or a mix by playing around with the dia of the pipes.
The "playing around" bit however is not that simple, the dia has to be calculated based on the exhaust port dia etc., else you end up with a loss of performance,basically torque.
Best complimented by a High-flow air filter to see a decent amount of performance increse as compared to stock.
The rev-counter/tachometer will best tell you how freely and easily the engine revs.
abhik is offline   Reply With Quote
Old 28th September 2008, 03:59   #24
v1p3r's Avatar
Thanked: 26 Times
You could try hooking up a boost controller, dial in a little more pressure, should be good for some extra whp. Make sure you take it to someone good, or it's bye-bye bhp instead.
Its got a bullet-proof engine that lugs like a train and gallops in a hurry.
It's got a crap piece of engineering that needs a turbo to put out just about as much power as an NA Civic. This despite 5 valves per cylinder. And let's not even mention sludge formation after 80k kms. But that's just my personal opinion, since I'm a Japaholic until I can afford a Lamborghini! I've seen some pretty mad RSs, that spin wheels even shifting into 4th gear.
Old 28th September 2008, 09:23   #25
kutlee's Avatar
Thanked: 194 Times
thats . reminds me of a midnight in Blore.
kutlee is offline   Reply With Quote
Old 28th September 2008, 12:13   #26
evo
evo's Avatar
Thanked: 23 Times
Aha, thank you very much!
Old 28th September 2008, 17:12   #27
The_Warrior's Avatar
Originally Posted by kutlee View Post
That "L" from the number plate can be removed to make a special number plate.
that was a good one!
The_Warrior is offline   Reply With Quote
Integrating maps & bluetooth with stock audio system of Skoda Laura L&K 2011 Paco In-Car Entertainment 2 13th December 2011 14:06
H&R Springs On Stock Shocks For A Skoda RS HAFI Modifications & Accessories 15 7th May 2010 05:54
Performance Mods for Premier Padmini using the stock engine D.V.R Modifications & Accessories 14 20th April 2010 17:38
Skoda Laura's stock ICE krazykul In-Car Entertainment 25 25th October 2009 14:09
